Old 11-04-2013, 11:30 AM   #426
Low Elco
Re: Crusty Rusty Leaky Squeaky 67 Step
Fusor 122 is the hi-tech stuff- can be seen here-
http://67-72chevytrucks.com/vboard/s...=575769&page=7
I got the Lord Stuff at Auto Color and Equipment, the paint store I use on 23rd between Noland and Lee's Summit rd on the North side.
Well, hell. I just figured out Lord makes Fusor. Gaah.
Anyway, the easy standard caulk gun stuff is Fusor 800 EZ, and it is. A little messy, wear gloves, mineral spirits on a finger slicks the whole channel right up nice. Get extra shoot tubes. It's what we used on Yeller. Uncle Matt got all zen and did it right over the first crap I put on while I was wigging out and handing him stuff like a squirrel on meth. Sometimes cooler heads must prevail!
Your work is looking great! Can't wait for the next installment!
Ps- don't forget to look down into the holes there on the top of the cowl and inspect the heck out of that seam-especially on the pass. side. Sneaky sneaky rust there, big leak later. Found it there big time but almost unnoticeable on Yeller. Keep it up!
Low Elco is offline   Reply With Quote
Old 11-08-2013, 11:40 AM   #427
hgs_notes
GEARHEAD
hgs_notes's Avatar
I'm late to the party but jumping on the band wagon now. I scrolled through most of the build this morning and you're doing some real nice work. Watching guys like you always makes me feel like a hack, but maybe over time some of the finer points to doing this work will sink in and I can at least aspire to greatness. And thanks to you I have a few more tools added to my watch list on ebay.
hgs_notes is offline   Reply With Quote
Old 11-08-2013, 12:05 PM   #428
69CST-V
69CST-V's Avatar
Originally Posted by Vic1947 View Post
Bryce,
After several days of cure time, the adhesive does not appear to be exhibiting any shrinkage. The cured consistency reminds me of plastic. It can be scratched, but pressing on it with a screwdriver blade doesn't leave an impression. However, it isn't so hard I'm worried it will chip or crack. Seems to have some flexibility. Time will tell, but there's a ton of shops out there using it for all types of panels, so that says a lot.
Thanks for the information. Truck is coming along very nicely. Looking forward to more posts.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 11-08-2013, 12:11 PM   #429
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the firewall and roof. This cab will be as close to perfect as you can get when done. Keep the pictures coming.
mcbassin is offline   Reply With Quote
Old 11-09-2013, 05:58 PM   #430
Vic1947
Vic1947's Avatar
Thanks, HG. I scrolled thru your build and you did a great job. I've always liked that shade of blue.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 11-09-2013, 06:15 PM   #431
Vic1947
Vic1947's Avatar
I've been puttering around with stuff that needs to be done, but doesn't have as much impact as big body panels. I decided to reinstall the accessories on the front of the engine and was in the process of giving the brackets a tune-up when I was hit by Moore's Law. If more is better, too much ought to be just right. While attempting to give the nickel plating a satin look, I spent too much time on the front of the AC bracket with the glass beads. Long story short, I ruined it and one other piece as well. Costly mistake, but I've decided to send them to Jonathon for powder coating and call it good.
The front of the fan pulley was bothering me, so I dug around in the scrap bin and found a piece of aluminum that I'd machined a long time ago as a steering wheel adapter for my 57 Ford. With a little work it became a cover for the front of the pulley which looks much better than four bolts and the pilot. Also finished welding out the patch in the dash where the stereo head will go.
Today was probably the last day the temperature will permit painting for a while. I needed to get the last of the pulleys painted and while I was at it, I went ahead and squirted the driveshaft and the shocks. I'll be glad I did it when the cold weather hits next week.
Victor
Old 11-09-2013, 08:10 PM   #432
Xeen
Xeen's Avatar
Everything looks great Vic.
I can't wait to see the rest of the cab work.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 11-11-2013, 11:25 AM   #433
Low Elco
Lookin great Vic!
Old 11-11-2013, 11:43 AM   #434
jlsanborn
jlsanborn's Avatar
Awesome idea on the pump pulley cover! Looks clean.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 11-12-2013, 05:14 PM   #435
Vic1947
Vic1947's Avatar
After the paint cured on the parts, I figured to quickly reinstall them and get back on the cab. Not to be. When I mounted up the first Monroe SensaTrac shock, the increased barrel diameter immediately interfered with the axle tube. It looked like if I moved the top of the shock back, it would correct the problem, but after several mods, I'd moved it back 1/2" and only had about .100" between the shock and the axle tube. So the only practical solution was to move the bottom shock mounts forward.
Once again the scrap bin came to the rescue as I was able to find two pieces of 1/2" x 1-1/2" x 3" material that miraculously had two 1/2" holes in just the right spots. The task became much easier at that point. I mocked up the pieces and marked the angle that I needed. I then calmped them on the mill and removed .240" of material to offset them flush with the existing mounting eye. Used the corner rounder to make them a bit prettier and then installed them. Pictures below are before paint and you can see they are supported on the front and the bottom of the existing mount areas. With a 1/2" bolt torqued to 95 ft/lbs, they aren't going anywhere. With the shocks in the front hole, I now have plenty of clearance between the shock barrel and the axle tube.
I also went down to the tire store this morning and had the tires dismounted. Headed to Eagle Stripping tomorrow to have the front of all four wheels blasted back down to bare aluminum. When I get them back, I'll use Glisten PC to coat them. It's crystal clear and will not cause the rims to turn grey like they did with the clear powder coating.
Victor
Old 11-12-2013, 05:30 PM   #436
69CST-V
69CST-V's Avatar
Great problem solving Vic. Getting closer.
Bryce
Company Trucks
Old 11-12-2013, 07:51 PM   #437
swamp rat
swamp rat's Avatar
Oh the things i could do with a mill! Cool mod!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-12-2013, 08:11 PM   #438
Pick
Pick's Avatar
Very nicely done! You amaze me with your elegantly simple but NICE solutions.
1968 SWB Stepside "Bella coming home" "Bella's Build Thread"
A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack
Pick is offline   Reply With Quote
Old 11-13-2013, 02:05 PM   #439
Low Elco
Lookin good- the extra vertical should make 'em work!
Old 11-13-2013, 03:03 PM   #440
jlsanborn
jlsanborn's Avatar
Very nice work! Corner rounder??? Is that quarter round tooling for your mill? Anxious to see the clear coat on the wheels. My factory alloys on the Silverardo are looking shabby
Old 11-13-2013, 03:15 PM   #441
Vic1947
Vic1947's Avatar
Thanks, and yes, the corner rounder goes in the mill. Typically if a part is in an out of the way spot and I need to round the corners, I use the disc/belt sander to approximate the radius I want. However, if I have more than one to do, sometimes it's easier (and more precise) to grab up a corner radius tool and let the mill do the heavy lifting.
The wheels are at Eagle Stripping as of this morning along with several other pieces. Hope to have them back by next week. Meanwhile, the weatherman says the temps are supposed to be in the low 70's on Sunday, so I may do a couple of test pieces with the Glisten PC to see how it works. Will post pics of the results.
Victor
Old 11-13-2013, 03:18 PM   #442
Vic1947
Vic1947's Avatar
Yep, I remember you suggesting that I relocate the bottom mounts, but I thought I could get by without it. Then the SensaTracs sent me off the cliff and I had no choice. But I'm much happier with the results now.
Victor
Old 11-14-2013, 11:12 AM   #443
knomadd
knomadd's Avatar
I wish I had a mill. You make some pretty cool parts when you need a solution to a problem. I'd love to be able to do that kind of stuff.
As always, NICE WORK!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 11-14-2013, 12:17 PM   #444
mcbassin
Still Learning
mcbassin's Avatar
That paint looks great!
Old 11-14-2013, 01:29 PM   #445
Vic1947
Vic1947's Avatar
Thanks, Duane. This is the third mill I've owned and it works pretty well for my stuff, which is mostly small. It's not very expensive, but the tooling always ends up being the budget buster.
While we're wishing for stuff, I'd love to have a GTO like yours. It's my favorite year and model. We had a couple of 69 Judges when we lived in Missouri City, TX back in the 70's. Picture below was taken up at the track in Porter, TX. We used the stock appearing one to tow the race car.
Victor
Old 11-14-2013, 01:39 PM   #446
Vic1947
Vic1947's Avatar
Thanks, Mike. Me and painting go WAY back. Nowadays, though, I have to work myself into the mood to do it. Plus, my shop isn't really setup very well for paint work, so I mainly stick to small stuff or primer.
Victor
Old 11-14-2013, 07:27 PM   #447
Vic1947
Vic1947's Avatar
Finished welding out the patch for the speaker grille. Took a long time to stitch it together, but still had to use pins to pull out a few low places and the hammer and dolly in others. Makes me wonder how the long welds on the bed will go. No use fretting over it, will cross that bridge when I come to it. Used the Dremel tool to cut out an opening for the center A/C outlet. The plastic duct that fastens to the back of it is resting on the top of the stereo bracket. If the stereo opening was 1/8" higher, I'd be hosed. Sometimes it's better to be lucky than good.
Victor
Old 11-14-2013, 08:37 PM   #448
69CST-V
69CST-V's Avatar
Looking good. Nice steady pace you got going. Won't be long if ya keep it up.
Bryce
Company Trucks
Old 11-15-2013, 07:34 PM   #449
Vic1947
Vic1947's Avatar
Today I cut the remainder of the old floor out. Used the plasma cutter to remove most of the rear floor brace and then cut the spotwelds from the inside. Doing it this way means I can use the spotwelder like the factory. Cleaned some of the grunge off the back of the cab sheetmetal and dragged the new floor over and set in place to see what I was faced with.
Victor
Old 11-15-2013, 07:47 PM   #450
Vic1947
Vic1947's Avatar
With the floor pan resting in the correct location at the back of the cab, it was immediately obvious there's a mismatch between the outer edges of the floor and the bottoms of the A-pillars ...like about 1-1/2" total. The tunnel was bumped up against the brace due to planning two steps ahead instead of three or four. However, the fix was to make a bridge to clear the hump. I clamped it in place instead of welding it in case I need to spread the A-pillars. Right now I'm wishing I had the firewall back so I can compare the flanges where they meet. However, I don't recall there being a big gap at the bottom where the firewall meets the kick panels.
I did some research on the forum on installing a full floor, but most of the fitment issues were between the firewall flange and the floor, not that the floor was wider than the spread between the bottoms of the A-pillars. Will have to wait until the firewall is back to see what I'm going to have to adjust. (As in pie cut, hammer, port-a-power, heat, bend, curse and etc.)
Victor
