05-03-2017, 01:15 AM | #451 | |
Re: 8 lug wheels - what's on YOUR truck?
I am taking a different approach to the problem now...I am currently in the process of switching out the DANA 60 open diff rear for a 14 bolt Full floater off an 87 1 ton. The hub seems to be a good bit less protrusive and may allow for hub caps and will definitely allow for screw-on center caps....now I'm stuck with 1.5 inch spacers .... |
05-03-2017, 01:37 AM | #452 |
Collector of Projects
I'm pretty sure you have to find center caps from a dually truck to be deep enough to have clearance for H2 wheel....
This site has some measurements... http://www.hubcaps-wheelcovers.com/c...enter_caps.htm |
05-06-2017, 06:44 AM | #453 |
Wheel Vintiques 82 Series 16 x 8 with 285/75 Goodyear DuraTracs
Waiting to do hubcaps for now. I have N.O.S. I don't want to run till the truck is cherry. Thinking about making a pair of fronts from some #2s in stainless I have
05-06-2017, 07:33 AM | #454 |
Started loosely assembling my 8ft step bed in anticipation of getting the wack fitting beat fleetside off.
I can raise the floor with the stepper and make it fit on the dump frame easier than a fleet....plus I like the stepper look better on a 4x4. Picked up another sport comp water temp guage since my old one went south and a small tach. The kid has this same tach in his truck and its nice, not big and bulky. I plan on getting the new pto cables hooked up this week I have one on allready but I gotta build brackets for the pto and dump valve. I've been looking too build some duel's off my manifolds but wow is it gonna be tight with the pto in the way, just might be easier too put the y pipe back on. Oh and cleaned up a oe front bumper and started putting it on. I'm thinking for now oe bumper and grill guard till I can find a winch. Also grabbed this square body c member and skid plate this week from the jy gonna try too make it work. I need to find some lift blocks and u bolts for the rear to level this thing out. The 205's look good there tim. Could a swore I was on the wdydtyttt thread...whoops
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. Last edited by midniteblues; 05-06-2017 at 07:49 AM. |
05-21-2017, 05:40 PM | #455 |
'05 ish Dodge 17" rims early 2000's center caps
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
05-21-2017, 07:43 PM | #456 |
I've thought about getting a set of those. I wasn't sure about whether the offset would require spacers. Good thing about Dodge rims is that Dodge still uses Dana axles, so they should fit over the center bore hole.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
07-01-2017, 11:14 AM | #457 |
I came up on these 17" late model factory GMC wheels & went for them.
07-01-2017, 11:20 AM | #458 | |
Nice, how did it work with the rear axle stubs? Have you used spacers?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
07-01-2017, 11:52 AM | #459 |
Yep. One & a half inch spacers. If they have their own set of studs, I call them adapters, & these do. I just get nervous about using adapters. I want to change out to 9/16" studs, just for piece of mind.
07-22-2017, 03:04 PM | #460 | |
Please tell me about the conversion kit needed... I have a 1970 C20 Camper Special with 8-lug wheels. I am considering getting the same Sliverado wheels you show in your photo.
07-22-2017, 10:26 PM | #461 | |
Also, if your axle is a Dana you may need to purchase spacers for the rear wheels. I think 1/2" usually will do it. Then the studs would likely need to be replaced with a longer version. Here are some eBay listings showing the options: All 32, 1/2"- http://www.ebay.com/itm/32-LUG-NUTS-...270283?vxp=mtr All 32, 9/16"- http://www.ebay.com/itm/32-LUG-NUTS-...item3ae5d4da01 He also sells lots of 16 and occasionally has a listing for a mixed lot of 16 of each size. |
07-23-2017, 04:26 AM | #462 |
Here's what I am thinking of running.
[/url] Not my trucks just an example on trucks [/url] |
07-28-2017, 10:26 PM | #463 |
Cool Truck
Nice, thats my truck you used as an example. I've had those rims on there for 6 years now.
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
07-28-2017, 10:31 PM | #464 |
Haha hope I didn't bother ya reusing it but yeah it's such a good look. One thing I've noticed with these old trucks you gotta be careful what you run on em or it just won't look right. But when I saw them on your truck and it looked good I knew which ones to get. If you have any other pics I'd like to see some more!
11-03-2017, 12:16 AM | #465 | |
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
11-04-2017, 09:22 AM | #466 |
vision wheels just came out with a bunch of new wheels. i would highly recommend checking them out as they have an affordable, yet attractive selection for our 8 lugs!
http://www.visionwheel.com/wheels/5459/vision-off-road
keep on building. http://67-72chevytrucks.com/vboard/s...d.php?t=680094 2017 GMC Canyon diesel 1968 Chevrolet C20 1970 Mercedes 280S (WTB 1968 4wd barn door suburban) |
11-04-2017, 05:11 PM | #467 |
17×7 steels off an '03-'12 Dodge Ram. Not sure how I like them. Might order some beauty rings for a cheap fix until I can afford something shiny.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
11-04-2017, 05:14 PM | #468 |
Got to show off my spare tire
11-04-2017, 05:34 PM | #469 |
Here is what I'm running, AR23s.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. Last edited by Don Quixote; 11-04-2017 at 05:36 PM. Reason: One photo does not apply. |
11-04-2017, 06:14 PM | #470 | ||
Still trying too hard in the styling department. Give those guys a chill pill and ask them to design a clean simple wheel with smooth rims. Something that doesn't look like it's made out of a bunch of pieces and riveted all together. So funny that Outlaws and Outlaw IIs (copied after Centerlines) were ever so popular till people started disliking the fake rivets. Now it's hard to find wheels that don't have fake rivets and the better companies that made the wheels tat got people away from Outlaw IIs are out of business (Centerline, Weld...). And those are the companies that took us to billet and drop forged quality wheels.
11-04-2017, 07:29 PM | #471 | |
As for those Vision wheels, I saw one style that had the right design, but I'm not into chrome or black wheels.
11-04-2017, 09:48 PM | #472 |
11-04-2017, 10:04 PM | #473 | |
Posted via Mobile Device |
12-30-2017, 05:18 AM | #474 |
Has anyone run the OEM Alcoa dually wheels that come on the new Dodges? I'm picking up a set for cheap off my local classifieds next week. I'd like to run them on my 1978 K35. Any idea what I'll need to use for lug nuts, and where I can buy them?
I've attached a pic for reference.
1987 R10 Chev Suburban 6.2L Diesel 1984 Frame 1990 Body V20 Chev Suburban 6.2L Diesel Banks Turbo |
12-30-2017, 06:22 AM | #475 |
I started out with nothing - and I still have most of it |
