#451 |
Re: Power Steering Adapter Plates
Captain I need a power steering adapter plate and a steering coupler for a 64. thanks
#452 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
PM sent with ordering/payment info
#453 |
How do I purchase one ?
#454 |
The 60-66 GMC/Pontiac guy....
Captain. .. would you be willing to send out just the outside plate? I need to do something on a 62 I have..
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#455 |
60-66 Nut
That info is in post #1 of this thread.
I sent you an email as requested in your PM ![]()
#456 |
60-66 Nut
The outside plate is all I sell. The inside plate my competitors include with their kits in not necessary in my opinion. My Suburban has over 120,000 miles with no issues and neither have the hundreds of the adapter plates I have sold. Just let me know.
#457 |
![]() Join Date: Nov 2011
Hi, I told a gentleman in our car club about your adapter. He does not have internet. He would like to contact you by phone. Please give me your phone number and I will pass it on.
Regards, Jim B |
#458 |
![]() Join Date: Aug 2013
i need a PS bracket from my 66 K10, the box is off a 67-72 4x4. thks...
#459 | |
60-66 Nut
I will send you a PM Jim B
I replied to your PM pimpston65.
#460 |
I would like to purchase a plate, flange and tube for my '66 C10. Pump is off a '69.
Thanks Rich rallen@gicx-ray.com |
#461 |
steering box - not pump duh
#462 |
![]() Join Date: Jan 2012
I would like to get a plate and tube and flange for my 67 Captain, thanks.
#463 |
60-66 Nut
Is your '67 a C series or a K series truck?
This steering box adapter plate is not needed on a C series truck. All that is needed is four 1/4" spacers. I can provide those spacers if you like. The cost will depend on whether you want them straight from the laser or if you want me to clean them up. If your '67 is a K series, then yes you do need this adapter plate. The tube and flange should not be needed either, if you have an original steering column. Here are a couple pics of a '67 C series frame with the 1/4" spacers stitch welded in place.
#464 |
is the 73-87 steering gear the only one that will work with this bracket? i'm planning on using the steering components from a 93 C1500, so i'm wondering if i can use the steering gear from the same truck, or do i have to source one from a earlier truck?
#465 |
60-66 Nut
The steering boxes from the '68-'86 C10,20 and 30 as well as the '87-'91 R1500,2500 and 3500 will work. The '88 and up C1500 steering and front suspension is completely different and will in no way work on a '60-'86 C10. I recommend the '73-'87 components as they are very easy to find in good used condition.
#466 |
okay, sorry. i had my truck chassis mixed up. forgot about the Suburban chassis staying on the old chassis till 91. i read about doing the 6 lug rotors from a R2500 and was thinking they had already gone to the GMT400 chassis.
#467 | |
found this on this site... i knew i had read something about using GMT400 parts.
#468 |
60-66 Nut
That conversion has shown to have alignment issues and is no longer recommended. Although the original posters of that conversion claim to not have had those issues.This is talked about later on in that thread
#469 |
gotcha. i wanting to do the ps and power disc brake swap all at the same time. i've read so many different ways of doing the conversion, they are all starting to run together lol. i'm debating on swapping to 73-87 lug 5 and getting your bracket to mount the Impala calipers, or getting the 6 lug rotors from ECE for 73-87 and your 6 lug rear brackets.
#470 |
Captain,
I have a 72 C10, which doesn't require the bracket, but I can't find the bolt sizing/specs used for the power steering gear box. I've also explored all the local junkyards but with no luck. Any info would help and possible places to get them, thanks! |
#471 | |
60-66 Nut
The threads in a power steering box are 7/16"-14. On a stock application you can get away with a 1-1/2" or 1-1/4" length in a Grade 8. You will also need either a split lock washer or a L9 SAE flat washer. You should be able to get these at a local fastener supply or a good hardware store.
#472 |
I now have powersteering on my 64 now with captainfabs bracket and a steering box off an 85 suburban.
#473 |
60-66 Nut
Thanks for posting pics of your installation.....looks good
#474 |
CaptainFab,
I have seen your brackets in place (at Chris's in Apache Junction AZ) and they look great. I am following protocol in posting first, then sending a PM to get the power steering bracket, and axle perches coming my way. I am building a 63 GMC. I have a complete (66 wrecked) as a donor to pull the trailing arms off of as well as 2 73 to 87 parts trucks. One of them is a 1/2 ton which will be donating the front crossmember assembly and the rear axle.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#475 |
60-66 Nut
