Old 06-30-2015, 05:33 PM   #451
Kim57
Kim57's Avatar
Re: 58 TRUK intro
Originally Posted by _Ogre View Post
shaving the cowl vent eliminates the entrance hole for water that destroy our cabs
the rust found in; front cab corners, vents and hinge pockets can usually be attributed to this vent
i always recommend shaving the vent
kim did it the right way, i cheated and used longhair filler to plug the vents and then welded the panel in
my original intent was to leave the vent loose so that it was removable
you can see the screws in this pic
I welded mine all the way in.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-30-2015, 06:54 PM   #452
samples45
samples45's Avatar
Re: 58 TRUK intro
thanks guys!
samples45 is offline   Reply With Quote
Old 09-10-2015, 04:14 PM   #453
roger55
roger55's Avatar
Re: 58 TRUK intro
Thanks for responding to me about the radiator fan questions on the other site.
When you say you did those 95+ degree power tours and didn't overheat, do you know what the actual temperatures you run in-town and on the highway at those 95 outside temps?
It would be helpful for me to compare those with the temperatures I'm getting with mine at 95 out.
P.S.
It's about time I make a post and get subscribed to your build thread. Magnificent truck btw.
roger55 is offline   Reply With Quote
Old 09-11-2015, 08:25 AM   #454
bowt1ed
Re: 58 TRUK intro
Hey Ogre,
Since you didn't weld it in entirely, what did you use to seal it in. Seam sealer under edges? Thanks, Jim
bowt1ed is offline   Reply With Quote
Old 09-11-2015, 02:55 PM   #455
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
i seam sealed the top edge that goes under the windshield and the bottom edge that is screwed
the sides were welded and finished off with filler
shop air compressor timer
Old 09-11-2015, 03:29 PM   #456
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
P.S.
i run a stock gauge that has the C----H it's a little difficult to determine the actual temperature
this is where it typically runs in the lower end towards C- i figure this is right around 185 or 190*
seeing as it goes to there and never goes higher, in town or hiway, summer or winter
i also run ac so the fan is on when the ac is on
and i might have lied a little when i said truk never overheated
my fan relay came unplugged from the temp sensor on the first power tour on a 104* day
driving in stop 'n go traffic, i was steaming when i pulled up to a stop light
the gauge was almost on H at that point, but i was also running a 8 lb cap, now i run a 16 lb cap
i believe my radiator, shroud and fan all came from brothers, drop shipped from US radiator
i run my fan relay temp sensor in my lower radiator hose coming out of my radiator
in a short piece of ss 1.5'' exhaust tube with half a ss 3/8'' coupling welded in
having the sensor after the radiator allows the radiator to do it's job before turning the fan on
having it before the radiator, the fan will always be on
and thank you. it's also a lot of fun
Old 09-14-2015, 09:30 AM   #457
bowt1ed
Re: 58 TRUK intro
Old 04-07-2016, 06:52 AM   #458
dug224
dug224's Avatar
Re: 58 TRUK intro
Ogre: Just reviewed your creative fiberglass work as I prepare to build my center console. Current plan is to use the center portion of the Envoy console which includes 2 cup holders, a slot of the e-brake and the hole and boot for the shifter. I will need to fabricate forward to the dash and rearward to the cab wall. I'll use wood for this. My question is....have you ever installed fiberglass directly onto plastic? I really like the factory console shapes and want to retain them. thx dug
dug224 is offline   Reply With Quote
Old 04-07-2016, 01:34 PM   #459
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
the resin might eat into the plastic, i'd do a test piece to confirm compatibility
i'd also scuff the plastic with some 80 grit sandpaper to give it some bite
Old 04-25-2016, 02:33 AM   #460
Harley03joe
Re: 58 TRUK intro
as it is now.
OGRE Heres My 31 Ford Bronson Yellow Frame Off Resto
Enjoy
Harley03joe
Harley03joe is offline   Reply With Quote
Old 05-31-2016, 12:02 PM   #461
DearBoss
Re: 58 TRUK intro
Ogre, All your work looks great and it a beautiful truck.
I was wondering how you mounted your fiberglass kick panels to the body, I didn't see any screws visible but I might have just not looked hard enough.
- DearBoss
Currently building 59' Chevy Fleetside, 383 stroker
DearBoss is offline   Reply With Quote
Old 05-31-2016, 11:32 PM   #462
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
if your referring to the kick speaker panels
all the screws are in the speaker holes
one in the tweeter hole and two in the speaker hole
Old 09-25-2016, 01:32 PM   #463
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
the cost of front end accessory brackets is stupid expensive, as many of you know i preach build your own
i had my alternator out to replace the regulator this week and took a few pics of the bracket
everything was cut out with a 4.5'' grinder with a cut off wheel and a drill press for holes
3/16'' flat plate, some 3/8'' thick wall tubing for spacers and an adjuster bar i had laying around
it may be a little too industrial for some, but it has worked flawlessly for 30k miles
here's the view from the front, same basic location as the original generator
side view with alt removed
front view
3 bolts and spacers that go into the vortec head
the thought/design process is pretty simple:
start with a cardboard template of the head bolt locations
transfer to the main plate, lay out the mounting bolt locations, then the alternator bolt location to clear the head
trim plate to a nice shape and fabricate the actual alternator mount, i traced the main plate to make the shape of the smaller plate
for the spacers i estimated the length and bolted it up to check belt alignment, then adjusted the length to fit
i tack welded the spacers on while the bracket was bolted to the motor
for the adjusting bracket i cut the slotted end off a bracket i had, bolted it to the alternator and welded 1'' angle down to reach an existing bolt
no extreme engineering or autocad drawing needed, just designed and fabricated on the motor
fabricating your own brackets allows you to place components where you want them, not where ''they'' want them
it started with my ac bracket, all the universal brackets mount the compressor way high to be universal
i wanted my compressor low and out of view when looking at the motor
Old 09-25-2016, 07:03 PM   #464
DransportGarage
DransportGarage's Avatar
Re: 58 TRUK intro
As always, a fine job, Ogre, and a fine tutorial!
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 09-26-2016, 08:07 AM   #465
Kim57
Kim57's Avatar
Re: 58 TRUK intro
Nice work on the bracket.
Kim
My build thread
Old 09-28-2016, 02:52 PM   #466
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
thanks guys, not much new stuff to show on a driver
Old 11-19-2016, 10:37 PM   #467
nail pounder
nail pounder's Avatar
Re: 58 TRUK intro
Hey Ogre, I just read all 19 pages if your thread, and I'm thoroughly impressed. That is one *****in' Truk. I appreciate your input on the questions I've posted on the board.
nail pounder is offline   Reply With Quote
Old 11-20-2016, 12:07 PM   #468
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
thanks for the comments
and the bump
Old 06-23-2017, 12:06 PM   #469
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
i went to the yipsi depot town car show for the first time
they block off depot town main drag for this nice smaller car show
no rain in 3 weeks here, guess what?
99% of the cars left in 2 minutes as the clouds rolled in
we went in and had tacos at maiz
Old 06-23-2017, 12:11 PM   #470
nail pounder
Re: 58 TRUK intro
Looking good as always Ogre!
Old 06-23-2017, 12:29 PM   #471
iowaboynca
iowaboynca's Avatar
Re: 58 TRUK intro
That's a nice pic with the clouds in the backdrop.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 06-23-2017, 01:12 PM   #472
OKGMC4
OKGMC4's Avatar
Re: 58 TRUK intro
Ya, great pic. Some people are wimps. When people see my 56 driven in the rain they get all bug eyed. Only thing I won't drive in is ice/ snow.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 06-23-2017, 03:45 PM   #473
DransportGarage
Re: 58 TRUK intro
Congrats on a great day out with Truk!
Bob
Old 06-23-2017, 06:28 PM   #474
Kim57
Kim57's Avatar
Re: 58 TRUK intro
Looks real good with the dark clouds in the background.
Kim
My build thread
Old 07-03-2017, 11:55 AM   #475
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
f' you photobucket for holding everybody's pictures for $399 ransom
i see short term gains for a soon to be closed photo sharing site
f' you photobucket
