12-26-2006, 08:40 PM | #26 |
Commander Taco Bello
Re: question about panhard bar
it is a stock LWB frame. It was a 3/4 ton, but the PO changed all of the suspension over to 1/2 ton.
the only mod to the frame that i will be doing is a CPP C-Notch kit.
12-26-2006, 09:23 PM | #27 |
cant help you on the measurement because my frame is no longer stock, but you might want to consider the ECE super track bar. It's a bolt on application and might suit you better than the SD weld-on. It requires your truck to have trailing arms. Not sure if you have leafs or not...
12-26-2006, 11:06 PM | #28 |
I have trailing arms.
i was actually thinking about the ECE kit because it had the shock relocators with it, but it seems that the SD one is a bit more beefy. I like that because i plan to have an engine with around 400hp in it by the end of next year. but, the ECE one is adjustable. thoughts? |
12-26-2006, 11:27 PM | #29 |
67-72 parts collector,…
ECE is plenty beefy! It's a bolt on! What more could you want. I have two of them. Just my 2 cents.
12-26-2006, 11:33 PM | #30 |
sold! :-) ordering it now from ECE and getting all of my rear air bag stuff from SD.
