Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-02-2007, 10:36 PM   #26
eedgell
It's the air up here
eedgell's Avatar
Re: ex-Navy 68 K10 build thread
I am no millitary man, but I appreciate you who are. With out you guys, we are all done! My wife is ex-Navy though, stationed at miramar VF 124 [house of pain]. We will be watching your build. Nice score, and good luck.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 07-10-2007, 07:58 AM   #27
kyoung
Progress pictures from the weekend 7/10/07
Got the engine removed..
kyoung is offline   Reply With Quote
Old 07-10-2007, 08:01 AM   #28
kyoung
Couple frame shots, also put the wheels back on and rolled her outside for pressure washing...
Old 07-10-2007, 08:04 AM   #29
kyoung
After the washing I rolled her back into the shop to finish the tear-down. The easy work is over, time to start bringing her back to life.
Old 07-10-2007, 08:41 AM   #30
msgross
msgross's Avatar
lookin good, I take it that the engine isn't original (spin-on oil filter?) and what is this part? Did someone add a some reinforcement to the frame?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-10-2007, 08:55 AM   #31
kyoung
Correct on the engine...it originally had a six cylinder and someone in the past put in the sb 350.
I'm not sure what is up with that frame support. When I got the truck it had a big homemade wench type bumper on it. I wonder if the support was put on there for that reason. I looked over the front part of the frame and have not found any cracks.
I bought some of the primer and chassis paint you recommended. I am cleaning the frame now and will apply it soon.
Old 07-10-2007, 09:32 AM   #32
msgross
msgross's Avatar
that primer sticks best when it's been sandblasted...
good luck
The Garage:
Old 07-10-2007, 09:33 AM   #33
71tahoe
71tahoe's Avatar
Since it is only on the driver's side it looks like reinforcement for the steering sector part of the frame. Any retired military mechanics on the board? Know of any MWOs for this?
71tahoe is offline   Reply With Quote
Old 07-10-2007, 09:33 AM   #34
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Your rolling right along!
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 07-10-2007, 10:46 AM   #35
RedZ71
Junior Member
RedZ71's Avatar
i like that blue... reminds me of F4U Corsairs
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
Old 07-10-2007, 12:27 PM   #36
Spanky_Pete
Too many trucks? Nah...
Spanky_Pete's Avatar
Looking good. I appreciate all of you guys that are documenting your tear down/rebuilds. It will help me out a lot as I start to dig into my newly acquired '68 4x4.
Spanky_Pete is offline   Reply With Quote
Old 07-10-2007, 12:34 PM   #37
kyoung
My build thread will be around for a LONG time! The tear down was pretty quick but I believe the rebuild will be rather lengthly, depending on available funds!!!
Congratulations on the '68 4x4, I'll keep an eye out for your build thread
Old 07-10-2007, 12:47 PM   #38
screamin_eagle
screamin_eagle's Avatar
what else do you have laying around that shop you can lift with that cherrie picker. nice progress way to be gung ho swaby.
screamin_eagle is offline   Reply With Quote
Old 07-10-2007, 12:56 PM   #39
Nice work on the disassembly. Truck looks real good for a project.
So how long did the shop last before you christened the floor with motor drippins?
I think mine lasted about an hour
Old 07-10-2007, 01:20 PM   #40
kyoung
It went from nice to nasty as soon as I rolled in the truck, it was leaking every possible fluid it could.
Old 07-10-2007, 02:02 PM   #41
RedZ71
Junior Member
RedZ71's Avatar
haha yeah, tear downs seem to be significantly less expensive than the build-ups!
Jonathan
1971 LB C10 Custom
Old 07-11-2007, 07:55 AM   #42
kyoung
71tahoe, you were correct about the brace being for reinforcement of the steering sector of the frame. While prepping the frame for primer last night I saw there are some minor cracks around the mounting holes for the power steering. I believe I can weld these up and it'll be OK. I think I'll leave the angle iron braces on the frame anyway.
Old 07-11-2007, 08:05 AM   #43
71tahoe
71tahoe's Avatar
I know the 4X4s are subjected to a lot more stress and this can happen. I thought it would be neat if this was done as a modification work order before the Navy got rid of it but it was probably one of the subsequent POs.
Old 07-11-2007, 08:32 AM   #44
msgross
msgross's Avatar
Are you adding power steering? If so then you might want to look into ORD's weld-on steering brace. With a little modification it will also fix the no "dimple" issue and no "raised pads" that us 68 K-10 owners have to tackle. A newer power steering box won't bolt up to that frame without spacers.
Are you keeping the front axle or adding a newer one with discs? (highly recommend, it bolts right in)
The Garage:
Old 07-11-2007, 08:43 AM   #45
kyoung
The truck already has power steering but it leaks really bad and will have to be replaced or can these units be rebuilt?
Yes, I am swapping the front axle for one with discs.
Old 07-11-2007, 10:09 AM   #46
msgross
msgross's Avatar
I would find the leak and replace that part... Don't know about rebuilding but you can buy good used one's for pretty low prices.. Do you have a closer pic of the steering box installed on your frame? That was more than likely added when the engine was and thus resulted on your cracking. They probably used spacers....
The Garage:
Old 07-11-2007, 10:24 AM   #47
kyoung
I remember taking the steering box off and it DID have spacers. So I guess this power steering WAS NOT factory?
I looked at the ORD bracket you mentioned earlier and this might be an option.
Old 07-11-2007, 10:32 AM   #48
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
i was stationed at millington for a school, then off to norfolk...i should have stayed in,,would be over 18 years now...oh well...anyway cool truck...man your cherry picker got a work out on tear down...cant wait to see the finished truck
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 07-11-2007, 10:43 AM   #49
kyoung
Oh yeah, the cherry picker was necessary. For the money, one of the better shop purchases I have made.
I'm not sure if Millington is even a Naval base anymore. I was there in 1981 and I believe at that time it was the largest inland Navy base.
Old 07-11-2007, 01:19 PM   #50
msgross
msgross's Avatar
I don't believe that power steering was an option for a 68 4x4. 2WD had a ram assist power steering option that you see every once in awhile. Those types of steering boxes can be found all day long on any 70's truck. The frames had rasied pads (instead of spacers) and a dimple in the frame rail to accept the box. There was still an issue with frame cracking so now you see the bolt-on and weld-on patches....
The Garage:
