Old 07-16-2009, 08:37 AM   #26
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: !!!!5.3 Vortec Swap Started!!!!
Originally Posted by Shon View Post
Then you will need the vette filter/reg set up.
Yep, and here is one from a 99 Vette sick454. They run $34 from rockauto.com
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-26-2009, 12:14 PM   #27
mcbassin
Still Learning
mcbassin's Avatar
I really like what your doing here I have always wondered how hard it would be to do. One thought I had years ago when I got my 1999 brand new, I wounder how hard it would be to chop it right at the cab and graft the whole frame and all to a 69 frame? I think you are going about it right.
mcbassin is offline   Reply With Quote
Old 07-26-2009, 12:51 PM   #28
caja_larga
why are there two pipes on the inlet?
caja_larga is offline   Reply With Quote
Old 07-26-2009, 02:44 PM   #29
Ackattack
Ackattack's Avatar
one is the supply line, the other is the return line back to the tank
Ackattack is offline   Reply With Quote
Old 09-02-2009, 10:34 PM   #30
jasonhall
jasonhall's Avatar
How does that filter work. ive got one out on my tank. would i just run one line to the filter and two lines out to the motor?thanks jason
jasonhall is offline   Reply With Quote
Old 01-18-2010, 10:27 PM   #31
sick454
sick454's Avatar
Originally Posted by jkade View Post
You can get a good trans cooler from the local parts store. If I remeber right I took a hose from a new model truck and cut the compression sleeve off and had the parts store put the fitting on a hose for the old steering box. Get a radiator and a set of fans from a 98-01 fbody if you want to go cheap. Get a walbro 255 inline pump and a 97 up corvette filter/regulator and you can use your blazer tank. The corvette filter/regulator is easy to make work.
So got the filter/reg set up from a 99 vette. Now how do i connect everythig to my fuel system. I have TWO fuel lines running from the tank, up to the engine compartment. One i had connected to the fuel pump running the old 454. The other i never used. not sure what the second line was for. I have had the tank down and it connects to the pick up assembly??? This seems to be the one think I am dreading doing. Not sure why, I'm not sure were to put the pump, cut and splice into my existing lines, remove and replace with different fuel lines. HELP me please.
sick454 is offline   Reply With Quote
Old 01-19-2010, 06:30 AM   #32
Shon
The one line that is coming from the tank that is actually going INTO the tank is where you put your pump and then the vette unit. and from the vette unit you will run the return line to your tank and the other one up to the fuel rail.
you want the pump probably as close to the tank as possible, I have mine mounted on the frame rail.
You will want to go to Napa or the like and get some dorman brand hard line that snaps into that vette unit and then I used rubber EFI hose and clamped it on those hard lines using the EFI clamps too.
That other line you say is going to your tank is a vent tube probably. if that is the only vent tube to the tank I would leave it alone but if you have more than one you 'MIGHT' can use it as the return line. I just ran a new line and my tank behind the seat is an emissions tank so it has a nipple on the filler neck I put the return line to.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 01-20-2010, 08:37 PM   #33
gus
do you have to replaced the gas tank sending unit for an (inside tank) electric fuel pump?
or you just have to get the vette fuel pressure regulator and an electric fuel pump to run them on your existing fuel lines that run through the frame?
Im starting this weeken the swap, will post pics soon !
gus is offline   Reply With Quote
Old 01-20-2010, 08:40 PM   #34
Shon
I am using the stock tank and sending unit and the stock gauges.
I am using the hard line from the tank and then put the rubber EFI hose on it to the pump and then line to the vette FFPR and then more rubber line to the fuel rail.
I was going to use the lines in the rail but didnt like where it ended and how i would have to route it.
Old 02-19-2010, 08:33 AM   #35
eagleuh1
eagleuh1's Avatar
Any updates ? I'm at about this point myself. I've got my engine(2005 5.3 and 4l60e) sitting in frame. Waiting on reply for headers. Still haven't done the fuel tank yet. Got to get headers, make sure they fit and then cut the drive shaft to fit. Would like to see how yours came out on the gas tank setup. LS1Tech.com has a lot of info on the gas setup as far as the corvette filter reg and fittings in their FAQ section. Good luck with yours. Jim
eagleuh1 is offline   Reply With Quote
Old 02-19-2010, 11:42 AM   #36
tallhoedude
ROCKWELL 5 TON CLUB !!
tallhoedude's Avatar
Originally Posted by sick454 View Post
Yes, I live in the Wichita, KS area and just kept checking with the local scrap yard owners until i found the ones I wanted. the 4L60E transmission came from a company in Topeka and if you have a local shop to ship it to, they will ship it for free. Here is there website.
http://www.lkqcorp.com/home/home.asp
Good luck, hope they can help you out too.
Shane
ive gotten several low miles 5.3s and 6.0s from LKQ for a steal!
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!"
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=221935
1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS
HINT:NEW NAME "K5ontheROCKS!"
tallhoedude is offline   Reply With Quote
Old 02-19-2010, 08:48 PM   #37
sick454
sick454's Avatar
Well I have not gotten very far because of the weather. been really cold here lately. I will be taking alot of pictures and post them when i do the tank and fuel pump set up. Thanks for the luck.
Old 02-20-2010, 08:19 AM   #38
eagleuh1
eagleuh1's Avatar
I'm at a stand still on mine now. Ordered the headers but won't be in till next week at earliest.
Old 02-20-2010, 10:57 AM   #39
Normy71
Looking good!
Any one have a picture of fuel pressure regulator on there 5.3 I'm not sure if I have one or not?
What did you decide on a trans cooler?
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 02-21-2010, 04:34 PM   #40
Shon
Originally Posted by Normy71 View Post
Looking good!
if your fuel rail has 2 connections then the bigger one is the feed and the smaller is the return, that round thing on the rail is the FPR, if you only have 1 then you do not have a FPR on the rail.
Old 03-20-2010, 05:03 PM   #41
sick454
sick454's Avatar
OK, I got all the fittings, hoses and clamps to install the fuel system, except one. I am having a hard time finding one connection. The connection from the Walbro 255 fuel pump outlet. It looks like it has a back flow prevention valve on it. and if i put a hose and clamp on it, it will cover the holes. not sure what the problem would be, but i can't find a connetion for it. ANYONE have any advice?????
Old 08-24-2010, 08:34 PM   #42
sick454
sick454's Avatar
Well, It has been a minute since I have been on here. I have some updates. I have all the fuel system installed, transmission shaft was shortened an installed. All the wiring is installed, However it still needs to be cleaned up a bit. Electric fans and transmission cooler are installed. PCM is mounted AND It STARTS!!!! haven't left the garage yet, still need some gauges to monitor a few vitals, and exhaust installed. but here is the motor in its running condition.
I know the wiring needs to be cleaned up a bit and I need the covers for the intake and vave covers. But it RUNS, FINALLY
Old 08-24-2010, 08:56 PM   #43
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Congrats on getting it running cant wait to see some burn outs.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-24-2010, 09:46 PM   #44
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
glad to hear you got it running!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-25-2010, 05:27 PM   #45
eagleuh1
eagleuh1's Avatar
Good deal. Looks good in there. Did you have to notch the frame any to use the exhaust manifolds?
Old 08-25-2010, 05:56 PM   #46
mcbassin
Still Learning
mcbassin's Avatar
Awesome progress! Glad to see you got it installed! thanks for sharing the pictures!
Old 08-25-2010, 08:11 PM   #47
sick454
sick454's Avatar
I did Notch it a little on the passangers side. but put some plates in fore and aft of the notch to strengthen it alittle.
Old 08-26-2010, 02:27 PM   #48
Puropedo
Looks great! Glad to hear you got it running... Can you post some close up pics of where you notch the frame, also what engine mounting plates did you used? Thanks.
Puropedo is offline   Reply With Quote
Old 08-27-2010, 09:01 AM   #49
sick454
sick454's Avatar
Thanks Bro. I have some pictures of the area where I notched the frame on the first page of this thread. I'll take some more this weekend.
As for the plates. I toke some cardboard stuck it to the block traced out the plate. Married it up to the motor mount, then cut it out with a plasma, drille the holes and bolted it all back up. For the other side I just flipped the templete. Pretty easy. I used a 1/4 inch steel plate. Hense the need for the plasma cutter.
Thanks every everyone for the help and congrats. This swap would be alot harder with out this forum!
Old 08-30-2010, 11:11 PM   #50
sick454
sick454's Avatar
OK, I need some more help. I installed some universal 4 wire Bosch Oxygen sensors. the problem is I guessed at the wiring(attached). Well I actually used the diagram I got from LS1tech.com. The bosch 02 wires are: two white, one black and one grey.
However since then, my truck is running like crap. It seams to be in LIMP mode. The tranny acts like it is slipping in first and second on the top end of the RPM range right before it shifts. And I get a mild popping from the exhaust now.
Has anyone installed these 02 sensors? How did you connect them? the engine is a 2007 classic silverado 5.3 with the 4L60E tranny.
Now prior to the 02 sensors the tranny was strong and shifted fine, just since then has it gotten this way.
