Old 09-12-2010, 09:09 AM   #26
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
Exc= Except
Or not including
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 10-03-2010, 09:17 AM   #27
1942
Originally Posted by 1Bad62Pro/Street View Post
Check the casting # on that 283 to see what year it is.
Also check the Large photos that I uploaded!
Vechicle Serial Number ID.
For Example my Truck is:
2C144N122375
http://www.americanclassic.com/paint_test.asp
Vin Decoding Results
VIN 2C144N122375
Model Year 1962
Chassis 2 Wheel Drive
Body Style Pickup
Series 1/2-Ton
Assembly Plant Norwood, OH
Sequential Number 122375
1/2-Ton Model Information
Model Description Wheelbase GVW
C1404 Stepside Pickup (6 1/2-ft) 115" 4,600
C1434 Fleetside Pickup (6 1/2-ft) 115" 4,600
C1504 Stepside Pickup (8-ft) 127" 4,600
C1534 Fleetside Pickup (8-ft) 127" 4,600
C1405 Panel (7 1/2-ft) 115" 4,600
C1402 Chassis-Cowl (6 1/2-ft) 115" 4,600
C1412 Chassis-Windshield (6 1/2-ft) 115" 4,600
K1404 4WD Stepside Pickup (6 1/2-ft) 115" 5,300
K1504 4WD Stepside Pickup (8-ft) 127" 5,300
K1434 4WD Fleetside Pickup (6 1/2-ft) 127" 5,300
K1534 4WD Fleetside Pickup (8-ft) 127" 5,300
K1405 4WD Panel (7 1/2-ft) 115" 5,300
K1406 4WD Carryall (Doors) 115" 5,300
K1416 4WD Carryall (Tailgate) 115" 5,300
K1403 4WD Chassis-Cab (6 1/2-ft) 115" 5,300
K1503 4WD Chassis-Cab (8-ft) 127" 5,600
1/2-Ton Engine Information
Code Cyl CID HP COMP Carb Trans
J 6 235 135 8.25:1 1-bbl Manual
JB 6 235 135 8.25:1 1-bbl Powerglide
JC 6 235 135 8.25:1 1-bbl Manual
M 8 283 160 8.5:1 2-bbl Manual
MA 8 283 160 8.5:1 2-bbl Powerglide
N/A 6 261 150 8.0:1 1-bbl N/A
Transmissions
Code Series Description Plant
C N/A Powerglide Cleveland
M N/A 3 Speed Muncie
W N/A 3 Speed HD Warner Gear
S N/A 3 Speed Commercial Saginaw
B N/A Powerglide (Corvair 95) Toledo
1/2-Ton Rear Axle Information
Code Ratio Plant
MA 3.90:1 Detroit Gear & Axle
MB 3.38:1 Detroit Gear & Axle
MC 3.90:1 (RPO) Detroit Gear & Axle
MD 3.90:1 Detroit Gear & Axle
ME 3.38:1 (RPO) Detroit Gear & Axle
MF 3.90:1 (RPO) Detroit Gear & Axle
MG 3.90:1 Detroit Gear & Axle
MT 4.11:1 (RPO) Detroit Gear & Axle
MU 4.11:1 (RPO) Detroit Gear & Axle
1962 Factory Color Codes
Code Description
500 Jet Black
502 Sea-Mist Jade
503 Glenwood Green
505 Woodland Green
507 Brigade Blue
508 Balboa Blue
510 Crystal Turquoise
514 Cardinal Red
516 Omaha Orange
519 Yuma Yellow
521 Pure White
522 Georgian Gray
526 Cameo White
528 Desert Beige
http://67-72chevytrucks.com/vboard/s...=316902&page=2
Do youn know where to find this list for a 63 model?
1942 is offline   Reply With Quote
Old 10-04-2010, 01:08 PM   #28
BSB1955
Now that is what I'm talking about. Very useful information, thanks Man!
BSB1955 is offline   Reply With Quote
Old 10-04-2010, 03:18 PM   #29
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
What is your VIN # ?
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 10-04-2010, 05:15 PM   #30
1942
I dont know, the truck is still in usa, i`m in norway..
i let you know the VIN when the truck is here
Old 10-05-2010, 05:48 AM   #31
1Bad62Pro/Street
Ok.
Since it's a '63 aerotruk63 has alot of knowledge on '63's so may can help you on restorations and other stuff.
Old 11-30-2010, 09:14 AM   #32
1Bad62Pro/Street
Exclamation Re: 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
To the top for the new kids on the block.
Old 12-19-2010, 04:21 PM   #33
edflores
So my ratio is under the panhard bar mount?
edflores is offline   Reply With Quote
Old 12-19-2010, 05:05 PM   #34
Bob Magana
I've been trying to find the info on my inline 6. The casting number is 3921988. Can't find info anywhere. Any help?
Bob Magana is offline   Reply With Quote
Old 12-19-2010, 06:41 PM   #35
1Bad62Pro/Street
Online engine resources (casting numbers, calculators, etc.)
http://67-72chevytrucks.com/vboard/s...d.php?t=382583
Check over there. Think I posted a section for the stovebolt I6's over there.
Chevy Six Cylinder Casting Numbers
1Bad62Pro/Street
http://67-72chevytrucks.com/vboard/s...d.php?t=356268
1960-1966 Wiring Diagram
http://cid-9169aad55cfc6d79.photos.l...20Diagram?uc=6
Old 12-19-2010, 07:24 PM   #36
Bob Magana
Im thinking that maybe my number is 3921968 instead of 3921988. I gonna have to recheck. But thanks for the helpful links!!!
Old 12-27-2010, 01:59 PM   #37
1Bad62Pro/Street
The 3921968 was used from 64 -76 Chevrolet/Olds (230-250CID)
Old 03-13-2011, 01:54 PM   #38
1Bad62Pro/Street
Tech Articles for 1955 - 1966 Chevy and GMC Trucks
http://www.oldchevytrucks.com/Articles/1955-1966.php
1960-1961 Chevy/GMC Trim Options:
http://67-72chevytrucks.com/vboard//...d.php?t=419180
Home Remedies
http://www.oldchevytrucks.com/Articles/Home-Remedies
Field Engineering
http://www.oldchevytrucks.com/Articl...ld-Engineering
Field Engineering Page 2
http://www.oldchevytrucks.com/Articl...ing_page-2.php
60-66 Drop Suspension & Handling:
http://www.gmcpauls.com/60-66_d&s.htm
Old 03-13-2011, 02:55 PM   #39
1Bad62Pro/Street
More F.Y.I. and goodies:
http://www.oldchevytrucks.com/blog/c...ticles/page/2/
SERIES WHEELBASE VEHICLE TYPE:
http://www.oldchevytrucks.com/blog/c...ical-articles/
http://www.oldchevytrucks.com/Techni...-1955-1966.asp
Last edited by 1Bad62Pro/Street; 01-11-2012 at 05:35 PM. Reason: http://www.oldchevytrucks.com/blog/category/technical-articles/
Old 03-13-2011, 03:34 PM   #40
1Bad62Pro/Street
GMC Stuff:
Tons of Pictures and info!
http://www.6066gmcguy.org/
Old 03-13-2011, 05:37 PM   #41
awbrown
well , I had no problem decoding my old truck ,it was 3C144Sxxx my other truck is a mystery , maybe I didnt read the pages right so help me out on this one ... The vin is 3C533Sxxxx the 533 has me scratching my head...
awbrown is offline   Reply With Quote
Old 03-16-2011, 10:10 PM   #42
awbrown
Well I spent some time working on the new 63 and did in fact confirm that the cab is from a 16000 lbs chassis ..I found the tag on the inside of the cab .. Does anyone know if a website exists for decodeing the trim etc for big trucks ?? From all i can gather it was a C-60 ,trim is X&X std paint is 0780 ..........
Old 03-17-2011, 11:10 AM   #43
1Bad62Pro/Street
Try here:
Where is my 60-66 Chevy or GMC vin number?
http://67-72chevytrucks.com/vboard/s...d.php?t=316902
Vin Number query
http://67-72chevytrucks.com/vboard/s...d.php?t=402078
Old 06-28-2011, 11:38 PM   #44
1Bad62Pro/Street
Talking Re: 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
Bump for the new fellars......
Old 01-11-2012, 05:30 PM   #45
1Bad62Pro/Street
Arrow Re: 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
Production numbers of the custom suburban and panels
http://67-72chevytrucks.com/vboard/s...d.php?t=502853
Old 01-24-2012, 11:10 AM   #46
1Bad62Pro/Street
GMC 1000-3000 Year & Model Identification
http://www.6066gmcguy.org/GMCID1.htm
GMC 3500-9500 Year & Model Information
http://www.6066gmcguy.org/TwoTon.htm
GMC's Truck Built V-6 Engine !
http://www.6066gmcguy.org/gmcv6a.htm
http://www.6066gmcguy.org/performance.htm
Translate your VIN number for you and narrow down just what year your truck should be. Go to the VIN Number Conversion Page http://www.6066gmcguy.org/VinNumber.htm of this site to find more info on this.
Old 02-08-2012, 10:32 PM   #47
stevenb
??? did you find out?
stevenb is offline   Reply With Quote
Old 02-14-2012, 10:16 AM   #48
1Bad62Pro/Street
Jim Carter tech articles 1955-66:
http://www.oldchevytrucks.com/blog/i...icles/1955-66/
Old 02-14-2012, 10:53 AM   #49
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Any one seen a "O" for the plant??? Its on my cab, and I have not seen that yet.
GMR-PERFORMANCE is offline   Reply With Quote
Old 02-14-2012, 11:19 AM   #50
1Bad62Pro/Street
Not sure about "O".
Chevy Chassis Identification LMC Trucks.
