Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-29-2009, 11:08 PM   #26
1987_3/4ton_chevy
Cowboy Up
Re: Project: 1971 Chevy K10 (56K Warning.....65 large pics!!!)
worked on it again today, got all the brake lines and starting ripping into the brakes (what a greese pit lol).
Slowly but but getting a nice start one it for only working on it for three days
1971 chevy k10 *Under the Knife*
Chris Cary
1987_3/4ton_chevy is offline   Reply With Quote
Old 04-30-2009, 05:58 PM   #27
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
now now chris...the brakes arent greasy....only the bearing assembly in the hub!!
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 05-01-2009, 08:23 AM   #28
1987_3/4ton_chevy
Cowboy Up
lol thats what i was meaning...
question for you guys, that cross member that is right in front of the rear axle is either cut or rusted out. Does anyone one know if that goes straight across or does it come up and then go back down or dp down? any one know what i am asking? lol
Chris Cary
Old 05-02-2009, 12:24 AM   #29
72blue
72blue's Avatar
It is pretty much strait but with some recess in the center. I would recommend getting one from a parts truck, it will have to be a leaf spring truck though...if I am wrong someone will let you know. BTW, great start, I did same and took 3 yrs like MR GROSS. Was just gonna b a quickie resto though. LOL. Keep on it and you will have it faster, just keep in mind that if you modify lots of things that it takes longer to set it all up like for example different axles from other model trucks or big block, newer style tranny and aftermarket interior from other rigs that will require fab work. That being said, others could do all that super quick, but me the "jack of all master of none" and redoing several things more than once took way longer than planned.
James
James
72blue is offline   Reply With Quote
Old 05-02-2009, 09:44 PM   #30
1987_3/4ton_chevy
Cowboy Up
Thanks for the advice. Is this piece something that a welding company can do?
Chris Cary
Old 05-02-2009, 10:24 PM   #31
msgross
msgross's Avatar
I would find someone cutting up a frame and just replace it..
try 6t727t2 in NJ and maybe he has one... it's like 16 rivets though..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-03-2009, 05:48 AM   #32
CARZ1968
Bowties from Birth
CARZ1968's Avatar
WOW! I would go with a better cab and part the good pieces of your cab (roof,firewall,dash)to recoup some of the cost of the new one.Plenty of people on this board need that stuff.Good luck fellas
68 K10 Burb aka "da bomb"
72 C10 SWB Highlander
97 30th anniv. Z28 Conv
99 Chevy Crew 454
11 Traverse AWD
CARZ1968 is offline   Reply With Quote
Old 05-21-2013, 10:06 PM   #33
71'4wdK10
71'4wdK10's Avatar
And new bed! or NOS bed
71'4wdK10 is offline   Reply With Quote
