Old 03-25-2010, 01:46 PM   #26
neo297
Re: 2004 yukon xl tranny slipping
Originally Posted by clinebarger View Post
Wow, now this super fluid keeps transmissions from burning up?
His 3-4 clutch failure is not fluid related. Low fluid level maybe but not the type
If the transmission gets hot enough to break down dexron III its toast anyway I dont care what fluids in it.
my fluids are checked regularly and levels were good there was no warning of impending failure in regards to any slippage or shifting issues. I have had a slight noise that no one was able to isolate( wheel bearings, tire ballance/wear patterns were checked and tranny fluid replaced with a new tranny filter just in case and the fluid was red and not burnt then, that was 3- months ago there was no metal found in pan but no change in noise after) that noise was intermitent almost a harmonic that would increase in volume with acceleration and decrease with deceleration but was not there with coasting. Then one day it drove to work fine and upon start up and heading home 3-4 started slipping like hell. 1-2 and reverse work fine.
neo297 is offline   Reply With Quote
Old 03-25-2010, 01:51 PM   #27
neo297
GM recommends Dexron III to 06. PM me if you want to and ill recommend some shops, 90 day warrenty is a joke.
I called the shop you reccomended Gregg quoted me 2100 for rebuilt with upgraded 3-4 clutches etc and rebuilt tc, turn key installed with 3 yr 75,000 mile warranty. I just have to limp it to him from here but the cost of rebuilt upgraded trannys with slightly less warranty#s online seem to be running in the 14- 1800$ range with me having to do the labor I think taking it there is the best option for me.
Old 03-25-2010, 02:35 PM   #28
lyrikz
PITbut
lyrikz's Avatar
I think we are just saying RUN the dex 6. Not saying thats what caused it.. Thats my opinion. But, wouldnt running an inferior fluid speed up the process of the clutches failing>?
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 03-25-2010, 04:48 PM   #29
clinebarger
I was just stating low fliud level can cause this
Sounds good
If he desides to run Dexron VI thats great, but a transmission shop is going to use DexIII because when you buy it in 55 gallon drums the price difference is alot more than 20 bucks. In my opinion DexVI will not make the transmission last longer.
clinebarger is offline   Reply With Quote
Old 03-25-2010, 05:46 PM   #30
lyrikz
PITbut
lyrikz's Avatar
Sounds good
Dex 6 is more money.. I just went through this. I found WOLFS HEAD ATF fluid is a match with Dex 6. If your at a shop, have them send you a barrel of that. It works great in TONNSSS of applications. Its only 1.5 more a quart. Something small like that.
and sold.
Old 03-25-2010, 06:39 PM   #31
neo297
I appreciate both of your input. I understand that the fluid was unlikely to be the culprit but just as I want to replace the trans with upgraded parts to reduce the likely hood of early failure it is a small price to pay to upgrade the fluid.
Old 03-25-2010, 07:29 PM   #32
truckdude239
truckdude239's Avatar
alright guys we gone on enough about what fluid it run. so let not argue about it anymore and give the op poster the info he needs.
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-26-2010, 12:18 AM   #33
neo297
Talking Re: 2004 yukon xl tranny slipping
I enjoy the back and forth just shows folks are passionate about their trucks and what they think is the best for them. I listen (read) and research but truly do thank those who take the time to try and help.
Paul
Old 03-27-2010, 07:56 AM   #34
truckdude239
okay i just wanted to make sure it didn't get out of hand. and that you got the info u needed
David fuller
2000 Tahoe 5.3l 378
Old 04-09-2010, 07:13 PM   #35
neo297
I just wanted to update I got my truck back from phoenix transmission in weatherford texas today and it runs great. They pulled my tranny put in their mater rebuild kit = clutches, extra clutch pack, steel rings, seals, gasket heavy duty torque converter,filter kit, bushing kit foreward sprag, epc solenoid 3-2 shift solenoid,tcc valve and sleeve, piston, 12qts atf (dexron 3)with 3yr 75,000 mile warranty they had the truck monday and finished it yesterday. I am very pleased with their service and turn around time. I saved $1200-1400 and have a much better warranty than any local shops here would give me. I do appreciate the responses to my initial request for help from all who replied.
Paul
Old 04-09-2010, 09:19 PM   #36
truckdude239
gald you got it fixed
David fuller
2000 Tahoe 5.3l 378
Old 04-12-2010, 10:02 AM   #37
lyrikz
PITbut
lyrikz's Avatar
Paul
Dex 3?
and sold.
Old 04-12-2010, 10:51 AM   #38
neo297
yes they say dex3 "multipurpose" not dex6
Old 04-12-2010, 10:53 AM   #39
lyrikz
PITbut
lyrikz's Avatar
OK...
If it was my rig, which i have an 05 Yukon XL, i would call the dealer and just give them your vin# and ask what fluid your trans takes.. Im like 97.9% positive its dex6.
It might not even really do anything by running dex3, but what if>????
and sold.
Old 04-12-2010, 10:56 AM   #40
neo297
So far it shifts smooth seems to accelerate stronger but twice it started chugging then died no check engine light almost like fuel starved. First time it restarted right away second it had to sit for about ten min then started right up both times it had been running on the highway 60-70 mph for at least 30 min I changed fuel filter about 5 months ago unsure what it is never had done this before. Shop said it had not done it to them and did not think it tranny related. alternator putting out 14 volts at idle battery about 12.5- 13 motor off .?
Old 04-12-2010, 10:57 AM   #41
lyrikz
PITbut
lyrikz's Avatar
Very common on those is the fuel pump. They either die intermittently or just go out 100%. Next time it wont start. Go bang on the gas tank really hard.. See if she fires up?
and sold.
Old 04-12-2010, 11:06 AM   #42
neo297
I was afraid of that when my 98 5.7 would need a new fuel filter you would lose passing power meaning if you pushed on the accelerator it would bog and lose power letting off would increase acceleration, as the demand for fuel increased i guess it could not get enough replacing the filter would cure the problem everytime. This was not acting the same way though so i was thinking it might be pump related.
Old 04-12-2010, 11:20 AM   #43
clinebarger
OK...
GM changed to dex6 in 2006. But the transmission is the same anyway so it doesnt matter. GM didnt change a thing in the 4L60E. If you have one of the new 6 speed autos then it matters
btw it says right on the dipstick what it had for factory fill.
Old 04-12-2010, 01:13 PM   #44
neo297
I am very happy with the tranny right now my wife just reminded me that this hesitation and dying did happen before i changed my fuel filter 4-5 months ago and when i did the filter was broken! The internal portion was loose and would slide back and forth you could shake it and it would rattle like hell. the new filter did not and the problem did not reoccur. The old filter was a fram i believe and so was the new onw i put on. I forgot about that being like that, i will change filters and see if this happens again.
Old 04-12-2010, 02:11 PM   #45
clinebarger
You need to get a fuel pressure gauge on it so you know what pressure your running, spec is (55-62 psi)
I agree with lyrikz, bang on the tank if it does not start, rubber mallet works best.
Old 04-12-2010, 03:00 PM   #46
neo297
I agree but with what happened before the internal component of the filter broke so looking into the end you could see this canister like piece moving around and the hole in it was lower than the outlet hole so as it moved it would block the opening so less or no fuel would get through so i would expect lower values in pressure at the fuel rail in any case a new filter is cheaper than a $300 pump as a first try, but i have no guages anyway can they be rented or borrowed from autozone o'reily etc? plus its so erratic i never know when it might happen so i guess i would need to buy some and keep in the truck.
Old 04-13-2010, 09:56 AM   #47
truckdude239
i hate fram plainn and simple they are cheap you'd be better witha gm filter or a puraltor filter
David fuller
2000 Tahoe 5.3l 378
Old 04-13-2010, 01:43 PM   #48
neo297
you know it is one of those things you go to autozone to get a number of items and get the filter they have on the shelf. I had totaly forgotten about the filter being broken when i took it off until my wife reminded me even my son who was helping knew it wasn't right for it to be broken never had i had a fuel filter break before I do not know if thats the case now I have been driving the truck for the last two days to see if it dies on me but so far no. When I get paid next week i'm going to replace it not with a fram!,then if it happens again i'll consider the pump as the next item to check. I do have to say the tranny is working well and will consider replacing with dex 6 when i need to service the tranny next. I believe the humming/harmonic noise i get from the front that did not change with the tranny fix may well be front pinion we will cross that bridge when we get there!
Old 04-18-2010, 08:34 PM   #49
steppside69
steppside69's Avatar
I was told that FRAM and PURALATOR are the same filters made at the same factory just painted the different names on them, May be wrong.
Eric
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 04-18-2010, 10:17 PM   #50
truckdude239
fram and puralator or most defiantly not the same filter ever cut them open? totaly diffrent filter
David fuller
2000 Tahoe 5.3l 378
