Old 02-26-2012, 12:08 PM   #26
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: The Dakota Cadillac (68 K20 w/ Cummins)
I just noticed the mirrors on your burb. I'm not quite sure I like them yet.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-26-2012, 01:00 PM   #27
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
You can hate them if you want to, I know I do. Somebody did a lot of work to make mounting brackets and drill a huge hole in the middle for some fugly mirrors.
I'm going with 68 style mirrors as soon as my bodywork starts (might be a year or three). I've got to paint my dad's El Camino, my Nova, and then it's the Burb's turn.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 02-26-2012, 01:03 PM   #28
Dieselwrencher
I know how that goes man! At least they're function able for now. That's what matters until you get tired of looking at them.
Ryan
Old 02-27-2012, 01:49 AM   #29
1leglance
I am really liking your build and taking notes for mine..
All you stick shift guys...what about us auto loving folks?
1leglance is offline   Reply With Quote
Old 02-27-2012, 10:58 AM   #30
jbclassix
Junk Yartist
jbclassix's Avatar
what gears are you running in your truck? are they the stock 4.57?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 02-27-2012, 05:09 PM   #31
lowrollin70gmc
Too many projects
Can't help you there, it seems like it takes a lot more money to have an automatic hold up to the torque of these motors and I love having three pedals. Of my 4 vehicles, there's one 3 speed, one 5 speed, and two 6 speeds (and an extra 5 speed sitting in the garage).
Running 3.55 up front and 3.73 out back just for the challenge! Actually I need to regear the dana 60 to 3.73 up front and I'll be swapping the rear dana 60 to a newer 10.5AAM 14 bolt for the disc brakes and integral parking brake plus the additional width I need to clear my wheels.
With the low rpm torque and 3000 rpm redline (stock) of these motors, anything above a 3.73 really cuts down the highway mileage and potential and having the granny first helps off the line when needed.
Andrew
Old 02-27-2012, 06:15 PM   #32
Dieselwrencher
If you're going with a newer rear axle, you may want to try to find some different off set wheels. I have an 01 D80 in the back of my Longhorn, and the rear tires hang out of the box sides pretty far. I can live with it, but other people think it looks weird.
Ryan
Old 02-28-2012, 05:29 PM   #33
lowrollin70gmc
Too many projects
I'm going to scout for axles with a tape measure in hand looking for 67"-69" WMS to match my Dodge front end of 67.5" (I think my stock rear is 63-65" but I'll measure before looking). The 17s I'm running right now have quite a bit of backspacing (they're off of a 2005 Dodge). Right now the tire rubs the inner wheel lip after about an inch of compression so something has to happen and I'm hoping for 2" of width additional on each side.
It's just hard to figure out the WMS of newer axles as everybody quotes the older 14bolt and I don't think they're the same width.
Andrew
Old 02-28-2012, 05:31 PM   #34
Dieselwrencher
I thought about going to a 14bolt in the back of my Longhorn, but I want the strength the D80 offers. And I'm on a tigh budget so building a new axle when I already have the D80 that's ready to go is a moot point. I just have to deal with the rear tire stance.
Ryan
Old 02-28-2012, 10:06 PM   #35
jbclassix
Junk Yartist
jbclassix's Avatar
See pics below
I disgree with a dana 80 being any stronger than a 14B. Heavier, but not stronger.
IMO a 14 bolt is dirt cheap and cheaper than dirt to build. If you have a Dana 80 laying around, definitely cheaper to use! BTW, that was the 3rd axle under that truck.
This is just my opinion... to each his own... 14bolts are actually my 2nd favorite rear axle.
-Jeremy
Rebuilding an NP205
Old 02-28-2012, 10:53 PM   #36
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
What were they doing for that to happen? Looks like there was no oil in the axle.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-28-2012, 11:29 PM   #37
Dieselwrencher
Show me any 14 bolt that will hold 1250hp + and 2,000 plus ft lbs of tourque +. I'm talking non AAM axles here too. That failure could have been a lot of things. No gear lube, improper pre load on bearings, I could go on and on. But I've been around truck pulling too long to believe a 14 bolt will out last a dana 80. If it were true, you'd see them in 90% of the pulling trucks. But you don't, and for a reason.
Ryan
Old 02-29-2012, 01:23 AM   #38
jbclassix
Junk Yartist
jbclassix's Avatar
Hey! I think I found a touchy spot for Ryan
As for that axle failure... I have no clue, no one on my shift ever drove that truck.
So, do I really know if a 14Bolt (10.5) is stronger than a Dana 80? Hell no!
Anything that I have ever messed with over 1200hp (and not over 60 Liters) has been in a top fuel hydro. No axles there!
The only reason I prefer the 14B is they are a dime a dozen, which translates into Broke-Jeremy-Can-Afford-It!
I'll really make you mad now, I would take an Eaton HO72 over a 14B any day!
But hey, I'll never own anything that makes enough HP to even touch an Eaton...
By the way, my Dana housing spreader doesn't like Dana 80s either!
Anyways, Lowrollin, You got any pictures of where your shift lever sits? Now that I hijacked it...
-Jeremy
Rebuilding an NP205
Old 02-29-2012, 03:41 PM   #39
Dieselwrencher
Not mad at all. I hear this from the early GM guys all the time. And then when their built 14b breaks constantly, they wonder why. For normal abuse and hauling, heck yeah, a 14b will work great. But I plan on doing things occasionally the normal guy won't. I like the HO52's and 72's too. But the parts are getting harder and harder to find for them. Last year some friends of ours went through 5 sets of ring and pinions alone. Not counting axles and what ever else they broke. This was a HO72 in a first gen dodge with 700-800hp. They're going to a D80 now.
Sorry for the jack Lowrollin!
Ryan
Old 02-29-2012, 04:03 PM   #40
lowrollin70gmc
Too many projects
It's all good, and this is the only picture I currently have of the shifter location. It's not too bad, but I'll have to make a new hump as this one is too short and has had three different transmissions/shifters hacked in different locations.
I only plan on 300-350hp and 700-800 ft/lbs so I think the 14 bolt will work. No tractor pulls, no rock crawling, and no goosenecks (that would be a sight on a burb),
She'll be a winter daily driver as well as an all purpose hunting, snow/mud rig with 10k lbs max payload. That's why I want to keep a high belly and low center of gravity. Might even keep stockish bumpers on it.
Andrew
Old 02-29-2012, 04:10 PM   #41
Dieselwrencher
That sounds like a cool place to be. That's how my truck build plan started, then it kept getting out of hand.
Ryan
Old 02-29-2012, 10:46 PM   #42
jbclassix
Junk Yartist
jbclassix's Avatar
vintage boot looks good!
-Jeremy
Rebuilding an NP205
Old 02-29-2012, 11:59 PM   #43
Dieselwrencher
That reminds me I have to find or build a shift handle for mine too. dang it.
Ryan
Old 03-10-2012, 02:55 AM   #44
lowrollin70gmc
Too many projects
I hear you there, I'm trying to figure out a t-case shifter and handle.
Options:
Fabricate bracket to attach dodge shifter to the side of the NV5600 but that trans is so wide that passengers would kick the dang thing!
Make a cable shifter with stock pattern and mount in front of trans shifter.
Twin stick it and make / buy a cable shifter and mount in front of trans shifter.
I lean towards the twin stick so that I know what exactly my front and rear drivelines are doing. The stock shifter always had me guessing and I would normally get under the truck and play with the front driveshaft to make sure I was in 2Hi not 4Hi. I wouldn't modify the rails at all as I don't need front low, but rear low would be nice.
Andrew
Old 05-17-2012, 12:48 AM   #45
lowrollin70gmc
Too many projects
Finally back in SoDak and working on the burb. Currently swapping an 05 Edit: 11.5 AAM for the disc brake/parking brake combo as well as a couple extra inches of width to have the tires clear the inner fender. Also picked up some 37x12.5x16.5 Baja A/Ts for future fun times on black steelies.
I should get the shackle flip and axle tacked up tomorrow and I'll show some progress pictures.
I weighed it this morning, are there any guesses for the weight? I unhooked the trailer on the second scale plate so I have true vehicle and trailer weight.
Best guess gets free crusty 4" lift blocks!!! Just stop by and help wrench and pick them up on the way out. Offer also includes free beer/soda to any parties willing to help anyways.
Andrew
Old 05-17-2012, 01:24 AM   #46
Dieselwrencher
6800lbs
Ryan
Old 05-17-2012, 01:44 AM   #47
mosesburb
I had a V-8
mosesburb's Avatar
6600lbs
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 05-17-2012, 10:52 PM   #48
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
6914.52lbs lol
Tony
Old 05-17-2012, 11:10 PM   #49
FrankieD
FrankieD's Avatar
5950lbs
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 05-18-2012, 08:42 PM   #50
lowrollin70gmc
Too many projects
Well, of the three guesses, FrankieD has some new crusty lift blocks! Genuine steel vintage units! She weighed 6200lbs with me in it and low fuel, so I'd estimate 6300 with a full load of fuel and no passenger (I'm 180 and additional 40 gal at 7lbs per gal is 280 lbs).
Now I will be adding more weight with an interior and other small things it's missing.
But for pictures:
edit: 11.5AAM in place, spring plates from DIY4x welded in place currently mocking up shock mounts.
Shackle flip installed, still need to throw some bushings in the springs.
And debating keeping this tank in the long run, 50 gallons of diesel will let me cover huge distances.
Finally, the BAJA A/Ts I picked up before I moved back to the Dakotas. It'll take a little trimming to fit the 37s at my current lift but I'll make it happen eventually.
Andrew
