Old 04-30-2012, 12:04 AM   #26
rmvlt1100
rmvlt1100's Avatar
Re: 1966 Custom SB - This is Blanca
You have a nice looking build going on there. You started with a clean truck other then the frame repairs that turned out great. I had the same issue with CPP, I just keep calling them and they shipped the order minus the back ordered parts. Good luck on the rest of the build and will keep checking back on the progress.
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Old 04-30-2012, 12:58 AM   #27
Dinos63
chevy only
Dinos63's Avatar
great thread welcome kat!! trucks going to be sweet
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 05-01-2012, 09:17 AM   #28
63sbssbbw
UCA63
63sbssbbw's Avatar
Nice job on the frame repair
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 05-06-2012, 12:55 AM   #29
Cherryforever
Bit of progress... tomorrow should be a good day to get stuff done.
1966 C10 Shortbox - Full CPP build
http://67-72chevytrucks.com/vboard/s...d.php?t=519829
Cherryforever is offline   Reply With Quote
Old 05-06-2012, 01:47 AM   #30
C@rnut001
Your truck is looking great and you are making some awesome and fast progress on it. Keep up the excellent work and keep us posted on your progress. Looks like you will make a good truck an excellent one!
C@rnut001 is offline   Reply With Quote
Old 05-06-2012, 07:50 PM   #31
mMad Dawg
Sean good looking truck. Hope you dont get the surprise I did . If you got your stuff delivered by UPS expect another bill in the mail about a month after you got your stuff. I ordered some stuff from Classic Parts. 85.00 for parts plus 35.00 shipping from them. Ups wanted an additional 65.00 for GST brokerage,and cod charge because I didn't have an account with them. By the way the box weighed 2 pounds. No wonder guys are picking there stuff up at Sweetgrass. Sorry about the rant. I may see you at some car shows in the area. I live in Calgary too. Gord
mMad Dawg is offline   Reply With Quote
Old 05-06-2012, 08:51 PM   #32
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Just spent some time looking through your build thread. Why people think it's ok to butcher a frame rather than..... buy the right headers???!!!
Looks good.
Looking forward to seeing it go back together.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 05-06-2012, 11:53 PM   #33
Cherryforever
Thanks for the replies guys. I ended up ordering through a dealer to avoid brokerage on this order. No worries on the rant I feel your pain. I've been shipping stuff to the boarder the last while to avoid all the hassle! Look forward to meeting you at a show here and there Gord!
Frame is ... making progress, I'm not sure why this guy took so many shortcuts. Just in a hurry I guess.
I have 5 15 hour days ahead of me to get this pretty much to the point of only wiring left .. wish me luck.
I also bolted up the 383 today with a help of a friend.
Old 05-13-2012, 11:26 AM   #34
Cherryforever
So I made some progress, Some snags on the way. Ready to do the rear brakes, in the picture they are just mocked up so I could measure my back spacing. I have no idea what rear end this truck has. Its about a 3.5:1 rotation from pinion to axle spin. Hes welded on the track bar mount, the backing pads for my rear brake mounts are off on the holes, I can't get two bolts in. just one. The studs are larger in over all diameter to the point where the new rotors dont fit over.
So now I'm looking at finding a 66 10 bolt rear. Motor and trans are good, front and rear suspension are done but just mocked up since I will have to swap out rear ends. I'd like to get the motor in today.
Tomorrow I go back to work for two weeks, I'm hoping I can this together when I get back so I can enjoy the summer with it!
Heres a pic of the frame right now.
Old 05-13-2012, 11:56 AM   #35
66ChevyMax
66ChevyMax's Avatar
Sweet, I love clean chassis
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 05-13-2012, 12:13 PM   #36
rustbucket66
For the rear end ratio, just take some emery to the input shaft that the yoke is on. There should be two numbers stamped on there. One is for number of teeth on the crown gear, the other is how many teeth on the pinion gear. Divide the smaller number into the bigger number, and you'll have your ratio.
Might be handy when buying a rear end also.
rustbucket66 is offline   Reply With Quote
Old 05-13-2012, 12:28 PM   #37
66-PMD-GMC
66-PMD-GMC's Avatar
Did GM use 10 bolts in trucks in 66??
Projects..
440CID 2X4 Pontiac
Old 02-27-2013, 05:16 PM   #38
Cherryforever
Re: 1966 Custom SB - Porterbuilt and Bagged Build
So I've had the truck for a year now, I decided I wanted to be laying body. We started renoing and been planing out wedding. Now I've finally got back into it.
Old 02-27-2013, 06:33 PM   #39
Slammed66
Needs a Big Block
Slammed66's Avatar
I dig this build......
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 02-27-2013, 08:24 PM   #40
66-PMD-GMC
66-PMD-GMC's Avatar
This is a cool build.
I do not, however, understand what trimming your cross member accomplished.
You didn't relocate the mounting surfaces for the frame so I am a little lost on that one.
:doh: I see it now..... never mind..
Projects..
440CID 2X4 Pontiac
Old 02-28-2013, 06:58 PM   #41
aggie91
I'm just glad to be here!
aggie91's Avatar
Just went though your build. You did a great job on repairing the butchery on that frame. The mostly complete chassis looks great. I hope to see more progress soon.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-28-2013, 07:02 PM   #42
DLOE65
DLOE65's Avatar
awesome work!
DLOE65 is offline   Reply With Quote
Old 03-18-2013, 12:35 PM   #43
Cherryforever
I've renamed the truck Cherryforever after my dads 1952 Willys he built for 20 years. I have something lined up for the interior to make it special.
I'm home for two weeks and plan to get as much done as I can. I'll post more pics as I go.
Old 03-18-2013, 02:05 PM   #44
baggedbigblock
HOLY FA&$*#@!!! I love the wheel and tire combo. Please please post some specs. 17x10 17x8?? what the wheel and tire specs. I am ordering soon as I was going to run chrome smoothies 15x8 w 3" WWW, but this is looking killer. Any fender/bed on pics w the wheels?
baggedbigblock is offline   Reply With Quote
Old 03-18-2013, 02:14 PM   #45
McMurphy
McMurphy's Avatar
Looking good so far !!
I just noticed the odd placement of your radio antenna, did you do that?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 03-18-2013, 02:41 PM   #46
WillieloRidez
WillieloRidez's Avatar
sweet truck man nice work so far! Im digging the cragars and whitewalls!
WillieloRidez Drive em in Drag em out!
Projects:
1956 Chevrolet 210 2dr post
58 chevrolet 2dr delray
58 chevrolet belair 4dr hardtop
1965 Chevelle big block 4spd
88 crewcab 1/2 ton long bed aka STRETCH Lt1-4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=388445
WillieloRidez is offline   Reply With Quote
Old 03-18-2013, 03:40 PM   #47
dr69burb
dr69burb's Avatar
Looks good I like it.
Baggin 64 lwb project
http://67-72chevytrucks.com/vboard/s...d.php?t=537406
dr69burb is offline   Reply With Quote
Old 04-04-2013, 12:10 PM   #48
Cherryforever
Hey guys, a friend of mine with Bergwerk Photography came by and took some shots for me. I think they turned out really well.
My dahs has been changed since along with me shaving the wirewall.
Old 04-04-2013, 12:20 PM   #49
aggie91
aggie91's Avatar
Very cool pictures! Those tires are different than the ones you posted earlier in the thread. What are the specs on these?
Karl
The LST Challenge:
Old 04-04-2013, 12:24 PM   #50
Jmorales3181
Jmorales3181's Avatar
Wow...,this is looking beautiful! Nice job! What size are those wheels?
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
