Old 06-25-2012, 01:53 AM   #26
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1988 Suburban "V Rig" Gets Cummins Power
Originally Posted by 1985-GMC View Post
Nice project! Are you using the first gen intercooler, and what exactly are they widening on it?
Thanks. Yes, it is a first gen intercooler. I had the inside width from in between the inlet and outlet, widened 4.25'' so the intercooler will fit around the radiator support main braces. But still fit in between the head lamps and turn signals on the 88-91 set ups.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-25-2012, 07:40 AM   #27
greguw
Looks great Dieselwrencher ... I used a aluminum intercooler out of a 2000 ford powerstroke , I cut and angled the inlet and outlet seems to work fine . I have seen guys use the 1st and 2nd gen intercoolers and that works fine also .
greguw is offline   Reply With Quote
Old 06-25-2012, 03:27 PM   #28
Dieselwrencher
Thanks Greg. I have a 7.3 intercooler, but it wasn't nearly wide enough. I didn't think of doing what you did, that is a good option though.
Today I got the dodge D60 under it. The owner wants to use the dodge steering box, so some mods to the steering shaft will be required. But the box its' self bolts directly on the frame. He is trying to find a pitman arm for a 6" lift for the dodge box. He is also looking for a steering box brace. I have to make some mods to the sway bar mounts, but I'm going to try and retain the chevy sway bar. Tomorrow I might try to do the rear axle. We'll see.
Ryan
Old 06-25-2012, 09:20 PM   #29
greguw
Thats why I had to cut and angle the inlet and outlet , worked fine with using the stock AC condenser .
I have use the 1st and 2nd gen but ran into fit issues doing a AC set up .
I think either way you will have to modify the core support .
Progress looks great ,look forward to seeing more ... Glad mine is done ...LOL
Old 06-25-2012, 09:38 PM   #30
Car'n'Guitars
Car'n'Guitars's Avatar
I want a Cummins in a Chevy truck, but I guess I can settle for the one in our Dodge.. someday. Cool build.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 06-25-2012, 10:24 PM   #31
Mattman2010
Mattman2010's Avatar
looking good bud, im sure the rear axle will be a lot more fun than the front was.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 06-25-2012, 11:16 PM   #32
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Ok cool, that's what I thought. Lets see some pictures when you get it back.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 06-27-2012, 04:14 PM   #33
Dieselwrencher
I've been working on welding the inside of the cross member and boxing it. I have it all welded up, now just to finish grind it, drill a couple more holes, and get it back in the burb.
Ryan
Old 06-27-2012, 04:56 PM   #34
Mattman2010
Looking good Ryan!
Build Thread
Build Thread
Thread
Old 06-27-2012, 05:30 PM   #35
Dieselwrencher
Originally Posted by Mattman2010 View Post
Looking good Ryan!
Thanks Matt!
Ryan
Old 06-28-2012, 04:14 PM   #36
Dieselwrencher
Today I sweated my butt off grinding and welding the cross member up. 98* out, real nice. Oh yeah, and absolutely no breeze. Dang it man! this weekend some time I'm going to try to get the engine work done, and paint the engine so it can go in for the final time.
We got the D70 out from under the donor dodge, and the owner started cleaning it up prepping it to go in.
Ryan
Old 06-28-2012, 04:20 PM   #37
Mattman2010
Looking good man. Is the sway bar going to get hooked up? Or does it not line up because of the 1/4 inch difference in spring spacing?
Build Thread
Build Thread
Thread
Old 06-28-2012, 04:23 PM   #38
Dieselwrencher
The sway bar isn't hooked up yet because if you use a dodge axle, you need the upper retaining plates too. So I'm going to have to modify the sway bar mounting points. In other words, I can't just bolt it on like the chevy one was originally.
Ryan
Old 06-28-2012, 04:27 PM   #39
Mattman2010
That makes sense.
Build Thread
Build Thread
Thread
Old 06-28-2012, 10:31 PM   #40
v30crewcab
v30crewcab's Avatar
that crossmember looks like it sticks down alot! how much lift is he going to run? might just be a visual thing.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 06-29-2012, 12:04 AM   #41
6lcummins
The truck has a 6" iirc.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 06-29-2012, 12:09 AM   #42
Mattman2010
That's what I remember Ryan telling me was 6 inches.
Build Thread
Build Thread
Thread
Old 06-29-2012, 12:19 AM   #43
63chevyll
gets board easy.......
63chevyll's Avatar
Great work and cool build. In case you havent found a steering box brace, the ones from off road design are the best. Ive used many and its really worth the $60 or $70 for it instead of fabbing one
63chevyll is offline   Reply With Quote
Old 07-02-2012, 12:42 AM   #44
Dieselwrencher
It looks like it, but there is still plenty of clearance.
Yep 6" before the dodge D60 which probably raised it another 1 1/2" in the front.
Thanks. It'll be a work horse for sure. The owner ordered one and it may have been from ORD. We should see it this week.
Ryan
Old 07-10-2012, 03:29 PM   #45
Dieselwrencher
The steering box brace showed up last week, last Thursday I power washed the front axle and under the body. I tried to get every nook and cranny I could. I also did the frame more too. This week the fuel lines should be in as well as the new brake lines. I've been working on the engine getting it ready to go. 8 out of 12 exhaust manifold bolts broke off, all the internal bolts that secure the gear housing to the block were loose, and there was no tab on the KDP. Also the crankshaft had bad pitting on the sealing surface for the rear main seal. I had to install a sleeve and different seal on it. Now the pan and front cover are back on. Tomorrow I'm going to install a new tappet cover gasket, clean the engine again, and paint it. Oh yeah, I already advanced the timing on the injection pump, and the engine is getting a little bigger injector. Getting closer...........
Ryan
Old 07-10-2012, 07:07 PM   #46
Mattman2010
You have been busy, sure sounds like that motor needed some work.
Build Thread
Build Thread
Thread
Old 07-11-2012, 07:12 PM   #47
Dieselwrencher
Just typical maintenance and things you want to check when you are un sure how the engine has been maintained.
Today I installed a new tappet cover gasket, and removed the injection pump. I forgot it is getting a 3k gsk in it. Tomorrow I'm hoping to paint the engine. We'll see.
Ryan
Old 07-12-2012, 03:16 PM   #48
Mattman2010
True, but those exhaust manifold bolts dont sound like any fun.
Build Thread
Build Thread
Thread
Old 07-12-2012, 03:23 PM   #49
6lcummins
It's a 12V head atleast, the 24V's are more fun for drill bolts out of.
"STOCK"
ASSEMBLY THREAD
Old 07-12-2012, 03:51 PM   #50
Mattman2010
I've never seen the difference between the 12 and 24 valve heads besides thr valves themselves.
Build Thread
Build Thread
Thread
