#26 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: New Member w/72 K5 blazer
Too far gone....you need to sell it to me!
That's a clean K5 that looks great. My 2 cents based on my recent K20 resto: take A LOT of photos before tearing into it; use the correct flat paint atop the dash; have the black bolts/screws/nuts, hood hinges, hood latches, upper metal rad tube, door latches, and AC vac pod bracket zinc phosphate coated rather than painted; don't throw anything away; if motor is original skip the decking on a rebuild so as to preserve the stamped codes that denote use in a K5; and start a build thread we can follow. Good luck!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#27 |
#28 |
#29 |
Here is my Green blazer coming in yesterday evening . I was waiting seem like forever . Kept looking out the window while watching the Buckeye game LOL...
![]() Posted via Mobile Device |
#30 |
#31 | |
I was planning to power coat the above mentioned pieces, would you suggest zinc phosphate first and then power coat?
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
#32 |
Carpe manana
Somewhere on my K20 build thread linked below I have a pic of phosphate coated (or "Parkerized") door latches. Once coated as such the parts are good to go and approximate what GM did. I would not add a powder coat nor would I powder coat items (like door latches) that will see some wear/abuse.
#33 | |
What part of San Jose are you in? I'm on the south side right by the In N out burger
#34 | |
#35 |
Im in West SJ by Campbell. My brother lives on that side of town. One day when I get my truck back together Ill have to cruise by
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#36 |
Likewise. As much as looks good from the outside, mines a mechanical mess right now. motor leaks from multiple areas, transmission, and TC leak as well. I could try and fix those issues, but if I have the motor, tranny and TC out, I might as well do frame off, so I'm going to hold out until I'm ready do a frame off restor
#37 | |
I now see which parts you are referencing mentioned above. However, please forgive me for being a rookie, but I don't know which of these parts you're referring to: "AC vac pod bracket" Thanks, Mike
#38 | |
Mike
#39 |
Carpe manana
Great question - this bracket is specific to 4wd trucks/blazers with A/C. If you look at your engine pic above (the one that shows the fiberglass A/C box bolted to the firewall) you'll notice on the inner side a plastic round "ball" thing. That's the vac pod - the bracket it bolts to is the one I reference. 2wd trucks and non-A/C 4wds do not have that bracket. Can be a PITA to find if you need one.
#40 |
Thanks, DeadheadNM
#41 |
Like wise dark green ... As for now just trying to get it started . It's must be one of three things no spark fuel pump or the junk holly carb lol....keep in touch bro..
#42 |
Welcome too the board and congrats on your find. I like the color too. Sure the blue and orange ones are sharp, but dark olive looks sharp.
Your Blazer feels familiar to me..... It's pretty similar to mine! ![]() Posted via Mobile Device
68 Chev SWB 2WD w/'95 LT1, 6spd, 4:56, 17" whls - family owned since 1973. 70 GMC LWB 4WD w/RAMJET 350, 4spd, 4inch lift, 33" tires, Warn Winch 72 Chev Blazer CST, 350, TH350, 4WD, factory A/C, tilt, radio delete, 77K miles, orig. paint/interior |
#43 |
MEMBER OF THE JUNK MAN CLUB
nice SURVIVOR!!
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS.. ![]() |
#44 |
@Hoffa - That's a sweet looking blazer you got there. Digging the color for sure!
Thanks, 468bigblock
#45 |
My green machine will be for sale shortly once I get it up and going and looking good
