Old 09-25-2013, 02:29 PM   #26
chase@ridetech
chase@ridetech's Avatar
Re: RideTech's New C10 CoilOver Kits
Originally Posted by oldspowered67C10 View Post
Wow, that upper mount sure looks familiar!http://67-72chevytrucks.com/vboard/s...d.php?t=266485
I guess great minds think alike. wish we would have seen that a few months ago when when we designing where this kit, would have saved us some time
chase@ridetech is offline   Reply With Quote
Old 09-25-2013, 02:44 PM   #27
chase@ridetech
Originally Posted by darkhorse970 View Post
I'm interested in the amount of adjustability in these setups. How low can it go from stock height with drop spindles and a c-notch in the rear?
here is our truck at ride height. with the coil over system as a bolt in, you wont be able to go any lower than this without bed modifications or crossmember modifications
Old 09-25-2013, 02:46 PM   #28
chase@ridetech
Got any straight on side shots of your shop truck?
does the above image work?
I can run out in a little while and get a more direct side shot
Old 09-25-2013, 03:54 PM   #29
fastbagged68
fastbagged68's Avatar
Is that with drop spindles?
What size is the tire?
What is the measurement from the front cab mount to ground?
Sorry for the questions, just trying to figure out if it will get me to where I want to be sitting
fastbagged68 is offline   Reply With Quote
Old 09-25-2013, 04:48 PM   #30
chase@ridetech
Here is a side shot of one of the guys that works here. he has the full coil over kit on it.
Old 09-25-2013, 04:50 PM   #31
chase@ridetech
the green truck has our complete kit with drop spindles
the tire size is 245 40 18 on front and 275 35 18 on rear
i will have to get the other measurment for you later
Old 09-25-2013, 06:51 PM   #32
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks like the wheel is in the stock/oem position.
About 3/4"-1" too far back in the wheel opening.
Just a thing I hate about these trucks.
(my opinion)
Porterbuilt and Hotchkis have addressed this.
Keith
Convert to disc brakes.
Old 09-26-2013, 01:51 PM   #33
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Is it the angle of the shot? (And I might be off a hair)
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-01-2013, 12:05 AM   #34
EPS3
We are getting ready to size the front up on the 73-87. I will keep you posted on the fitment.
They will use a factory style ball joints.
The arms are designed to utilize our sway bars.
I've read the primary difference beween 67-72 control arms and 73-87 control arms is the steel bushings were replaced with rubber bushings. The rubber bushings are softer for a smoother, but less controlled ride. Most tubular control arms use urethane, delrin, or other hard plastic bushings. I was also told that 73-87 control arms could be mounted on a 67-72 C10.
Can someone tell me why would Ridetech need to develop a different set up for the 73-87 C10?
EPS3 is offline   Reply With Quote
Old 10-03-2013, 04:22 PM   #35
chase@ridetech
We just need to confirm fitment for the new upper mount.
Old 10-03-2013, 04:25 PM   #36
chase@ridetech
we also use delrin with 13% teflon bushings in our new control arms
Old 10-03-2013, 04:31 PM   #37
EPS3
Thanks for the info.
1) Do the upper and lower bushings match stock C10 spindle?
2) Will your arms work with the stock 73-87 spindles?
3) Is it correct the $1400 kit does not include the coilover shocks?
4) Is it possible to buy the upper bracket alone if we already have arms, and if so, what would be the cost?
Old 10-10-2013, 02:40 PM   #38
marolf101x
-no, our control arms use Delrin self lubricating bushings, so you cannot use OE bushings.
Yes, the difference is in the ball joint. We select the ball joints based on the platform year you order. If you are using spindles from a year other than the trucks manufacture date just let us know what year the spindles came from and we'll match it up.
That is correct. As we offer many different shock options it's best to sell the two separately. This allows you to choose whatever shock option is best for your build.
The upper bracket is not available separately as the shock length is critical. So you need to use our new arms to make sure the dimensions are correct.
marolf101x is offline   Reply With Quote
Old 10-10-2013, 04:46 PM   #39
Dano69c10
Dano69c10's Avatar
Is the centering of the wheels, in the wheel-well, going to be addressed by RideTech?
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 10-11-2013, 08:17 AM   #40
marolf101x
The wheel is centered in the wheel well. The pic above just makes it look like it's not.
I'm on my phone so I cannot add a pic.
Old 10-11-2013, 09:08 AM   #41
chase@ridetech
here is the straight on of the shop truck
Old 10-11-2013, 09:59 AM   #42
lolife99
lolife99's Avatar
What "my eyes" see,... is the space behind the tire is smaller than the space in front of the tire.
Not seen as much with a static drop.
If it was bagged,... it would look even worse air'd out.
Just a personal preference in looks.
Keith
Old 10-11-2013, 09:30 PM   #43
Reyals Bemus
lolife- sayin' it how it is! I like that about you.
Reyals Bemus is offline   Reply With Quote
Old 10-11-2013, 09:39 PM   #44
lolife99
lolife99's Avatar
Ha.
Sometimes I say too much.
Just voice my opinion,... and try to remind that it is just my opinion.
If anything,... "I prefer" the wheel a little forward,... in the wheel opening.
Ridetech make a QUALITY product and has for MANY years.
Keith
Old 10-11-2013, 10:29 PM   #45
CHRIS67GMC
CHRIS67GMC's Avatar
I have seen the truck in person the tires must be turned some. They did center them back up when the kit was built.
CHRIS67GMC is offline   Reply With Quote
Old 10-16-2013, 01:21 AM   #46
familyfast64
familyfast64's Avatar
I think there charging entirely to much for making slight alterations to a 50year design. And most of the credit goes to ol' hot rodders who have been addressing these issues for years.
That being said, it definitely looks good and must save some people lots of headaches. Not to mention irs way nice to stumble across your stuff or the like used on craigslist for next to nothing!
Live and let live
familyfast64 is offline   Reply With Quote
Old 04-23-2014, 01:23 AM   #47
gutt_72
Whatever happened with this?
gutt_72 is offline   Reply With Quote
Old 10-09-2014, 07:40 PM   #48
dkauffman05
dkauffman05's Avatar
im really interested in this kit but kinda wish it sat a little lower at ride height .
dkauffman05 is offline   Reply With Quote
Old 10-13-2014, 04:48 PM   #49
Kook87
Kook87's Avatar
whats the general consensus and feed back on this kit? I am about to make a final decision between this and air. I really don't need air as I like the stance I currently have but it rides rough.
Kook87 is offline   Reply With Quote
Old 10-13-2014, 05:01 PM   #50
CHRIS67GMC
CHRIS67GMC's Avatar
You will have a nice ride with this kit and handle well. If you get the hq shocks you can dial it in.
