Old 05-28-2014, 03:31 PM   #26
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: 66 Pro Street Build (Domeringer)
Going to tune in for the rest of the process!
I really like the direction!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-29-2014, 02:51 PM   #27
markeb01
Senior Enthusiast
markeb01's Avatar
That rear end setup looks killer!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-16-2014, 06:38 PM   #28
Gary V
Active Member
Gary V's Avatar
Hi All, Been pretty busy setting up shop, managed to make some progress. Here's some pics of the crossmember welded up and the 4 link frame tacked and squared to the jig... things should progress a little quicker now.
Best regards,
Gary
DOMERINGER BUILD
Gary V is offline   Reply With Quote
Old 07-03-2014, 08:54 AM   #29
Gary V
Active Member
Gary V's Avatar
Some frame progress pics...
Best regards,
Gary
DOMERINGER BUILD
Old 07-03-2014, 09:55 AM   #30
Jeff La
Unreal fab skills
Jeff La is offline   Reply With Quote
Old 07-05-2014, 09:35 PM   #31
Gary V
Active Member
Gary V's Avatar
Thank you Jeff... hope you all don't mind pics. Added some reinforcement from the frame to the crossmember, cut off and capped width. Rear end fab next .
Best regards,
Gary
DOMERINGER BUILD
Old 07-13-2014, 12:51 PM   #32
Gary V
Active Member
Gary V's Avatar
Has been a rough week... had a cold and then a stye in my eye... so didn't get a lot accomplished. Started making a jig for the 9" and should have it done by next weekend to go at it again. For those interested I will post a kind of step by step pictorial aimed at getting a braced 4 link rear fabricated properly. Some pics to start...
Looking through the drive shaft loop hole
Best regards,
Gary
DOMERINGER BUILD
Old 07-13-2014, 02:26 PM   #33
markeb01
Senior Enthusiast
markeb01's Avatar
Wow! I'm tuned in!
Old 08-02-2014, 07:27 PM   #34
Gary V
Active Member
Gary V's Avatar
Smile Re: 66 Pro Street Build (Domeringer)
When I decided to fab up my own 9" rear end, I went looking around on the net for some good instruction. Was kind of disappointed that no one had taken the time to document a how to. There were plenty of home made jigs for doing one thing or another. But not a start to finish... so here we go.
To recap we're using a 3.25 Strange Center Section (part no. H1112) and 3.25 X 1/4 Wall DOM Tube. The rear will also get a back brace and that is the main reason for this jig... will explain as we go along
We're going to have to deflect or bend the rear end axle tubes down on this jig when the back brace is welded to the tubes and housing. When the brace gets welded to the back along the length, the weld will actually pull or deflect the tubes to the rear. What we're going to do is deflect the rear before the welding process so that when the weld cools it comes back to where it needs to be.... hopefully
The Rear End Jig
We need a good straight rear end fabrication with concentric tubes . To accomplish that 4 bushings were machined to a slip fit for the ID of the 3.25 DOM Tube and the OD of a 2" TG&P (turned ground and polished) length of shaft that runs up the center to keep everything in line. I should mention that the last parts that get welded to the rear are the housing ends... so a different bushed version of this internal alignment jig will also get used later.
Finished the welding of the tubes to the center housing. Once everything cooled the shaft would turn and was easily removed! Mission accomplished! A straight concentric rear end assembly! This rear end could be used as is without the back brace but we're going to be putting some big horsepower to this heavy truck... so well add the brace.
Ok enough for today I need tomorrow I will finish the bend jig and post some more pics and info.
Best regards,
Gary
DOMERINGER BUILD
Old 08-02-2014, 10:50 PM   #35
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Gary,
It is one thing to just strike an arc and lay nice welds.
It is quite different to forecast the outcome & effects on what you are welding
Nice job on both!!
Many kudos to your skills, I guess this is what experience proves!
This is how good fab-work is performed!
Modges'66 is offline   Reply With Quote
Old 08-03-2014, 05:57 AM   #36
Bomp
Bomp's Avatar
Impressive build.
Late but Im in.
Bomp is offline   Reply With Quote
Old 08-03-2014, 01:59 PM   #37
markeb01
Senior Enthusiast
markeb01's Avatar
Thanks for taking the time to photo document all this. I’m sure this will prove helpful to many. The whole project is well beyond my skill set, but I really admire and enjoy watching the creation of fabricating art work.
Old 08-03-2014, 08:39 PM   #38
Gary V
Active Member
Gary V's Avatar
Originally Posted by Modges'66 View Post
Gary,
Nice job on both!!
Modges, This is the nicest thing anybody has ever said to me. Thank you very much!
Best regards,
Gary
DOMERINGER BUILD
Old 08-03-2014, 08:42 PM   #39
Gary V
Active Member
Gary V's Avatar
Originally Posted by Bomp View Post
Impressive build.
Late but Im in.
Hi Bomp, Have been following your creativity and great work for a while... been a little shy about posting. Thank you!
Best regards,
Gary
DOMERINGER BUILD
Old 08-03-2014, 08:46 PM   #40
Gary V
Active Member
Gary V's Avatar
Thank you markeb01! Been at it a long time. I really enjoy sharing the fab stuff and it keeps me motivated as well.
Best regards,
Gary
DOMERINGER BUILD
Old 08-03-2014, 08:50 PM   #41
Gary V
Active Member
Gary V's Avatar
Ok went at it today and got the rear end torture jig just about ready to go. Here's some pics... next week we add the back brace and get on to more fun stuff. I'm jigged out
Best regards,
Gary
DOMERINGER BUILD
Old 08-03-2014, 11:35 PM   #42
chevyrestoguy
chevyrestoguy's Avatar
Very nice, Gary! I love fabrication work, and to see it being done by someone of your high standard is especially enjoyable. I'm really liking all of the jigs you have and how you're using them. I have to say that frame is going to be one strong mofo. I can't wait to see more!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 08-04-2014, 06:31 AM   #43
dwcardfan
dwcardfan's Avatar
Very nice work Gary. That is going to be one sweet frame!
dwcardfan is offline   Reply With Quote
Old 08-13-2014, 04:32 AM   #44
Gary V
Active Member
Gary V's Avatar
Thank you! More jigs and fixtures soon!
Thank you!
Break from the fab work... Machined some 4130 rod ends and 1 3/8" X .093" wall 4130 links. Rod ends are a press fit... will weld them up today and get that rear end ready for the frame this week and post updates Sunday evening.
Fixture to set the link lengths equal to the 18" C/L dimension
Best regards,
Gary
DOMERINGER BUILD
Old 08-13-2014, 01:27 PM   #45
chad64chevy
chad64chevy's Avatar
loving the updates, cant want to see the rearend in with some wide tires
chad64chevy is offline   Reply With Quote
Old 08-16-2014, 05:48 PM   #46
Gary V
Active Member
Gary V's Avatar
Hi Chad, Thanks and here's some updates!
Good day today! Had to fire up the plazma cutter and make up some new back braces. The ones I received were not correct... they were for a standard rear end housing and 3" axle tubes. The rear end housing will be shortened to the inside of the orange tape so thats where I ended the back brace. Here's some pics explaining how the jig was used to preload the axle tubes prior to welding the back brace on. The brace was fit after the tubes were loaded. Should have the rear end back under the frame and 4 links installed tomorrow... will post progress Sunday evening!
Best regards,
Gary
DOMERINGER BUILD
Old 08-16-2014, 11:14 PM   #47
Modges'66
Modges'66's Avatar
Yeah?
Still waiting for all of the shots of the picture-perfect welds...LOL!
Very skilled work!
Old 08-17-2014, 06:17 PM   #48
Gary V
Active Member
Gary V's Avatar
Yeah?
Very skilled work!
Hi Modge, Looking for a little weld porn eh LOL. We''ll get some close ups for you next week. I weld mild steel structural on the hot side... penetration with no undercut... so the welds are more girl next door looking.
Progress pics! Rear back under the frame, links installed and jig work stripped away. Next... mount the shocks, wishbone locator and ARB (anti roll bar)
Best regards,
Gary
DOMERINGER BUILD
Old 08-17-2014, 11:02 PM   #49
Bomp
Bomp's Avatar
With a chassis/suspension set up like that I'll take the girl next door any day.
Somethin's getting hacked apart on my build now.
Note to self: cut off and start over.
Old 09-01-2014, 05:45 PM   #50
Gary V
Active Member
Gary V's Avatar
Hey Bomp... any fabricator that says he never has to cut stuff off and start over is not telling the truth Keep up the great work!
Been working on machining the wishbone and anti roll bar details and ordering parts... so not a whole lot got attached to the chassis other than the coil overs. Should have everything else ready to get on there this coming weekend. For now here's a couple of pix with the coil overs mounted.
Best regards,
Gary
DOMERINGER BUILD
66 c10, drag truck, pro street, twin turbo ls1
