Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-28-2014, 08:30 PM   #26
Cobalt964ruf
Cobalt964ruf's Avatar
Re: 1971 K30 burb - LS3, 4l80e, np205, Dana 70f, 14bff, Detroit lckrs, 4"lift, 35" BF
It was a rural small town ambulance early in life and the roof has a small 3" rise. Not as bad as some ambulance roofs with like 12-14" roofs.
Cobalt964ruf is offline   Reply With Quote
Old 06-28-2014, 08:32 PM   #27
Cobalt964ruf
Originally Posted by Bigdav160 View Post
The seats appear to be '93 Suburban seats. i was going to ask about the roof also. I thought it just might be an illusion.
Yes Dave is correct, currently has 1992-1994 suburban seats. I have a set out of a 2004 tho that are going to go in it.
Old 06-28-2014, 11:00 PM   #28
Cobalt964ruf
After doing some research it appears it was likely a rural fire rescue ambulance kinda thing on the roof
Old 06-29-2014, 05:25 AM   #29
Cobalt964ruf
This is not my truck, but it is the truck inspiring my build. Name:  image.jpg
Old 06-29-2014, 04:52 PM   #30
Cobalt964ruf
Now in my possession
Old 06-29-2014, 09:45 PM   #31
mx289
mx289's Avatar
Originally Posted by Cobalt964ruf View Post
This is not my truck, but it is the truck inspiring my build. Attachment 1271964
Very cool build you have going here.
IIRC,there was an article about this yellow suburban.
One of the 4x4 mags maybe ?
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 06-29-2014, 10:14 PM   #32
Cobalt964ruf
i really like the yellow truck. I picked up my blue one today
Old 06-30-2014, 07:03 AM   #33
Cobalt964ruf
the old window tint needs to come off, and the lift kit and tires and wheels need to go on. a good interior vacuum and very minor rust repairs. very very little rust. im surprised.
Old 07-01-2014, 05:47 AM   #34
Cobalt964ruf
the initial list will be; remove the tint, then install dana 70 front axle, front lift springs, front wheels/tires. then 14bff disc brake rear axle, rear lift springs, rear wheels/tires.
Old 07-01-2014, 12:16 PM   #35
Bigdav160
Bigdav160's Avatar
It's so much easier to work on the front stuff, including LS cross member, when the front sheet metal is removed.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-01-2014, 03:18 PM   #36
Cobalt964ruf
I agree Dave. But at the moment she currently runs and drives so I'm not dropping in the ls just yet. I'm going to do axles, suspension, brakes, wheels and tires first. Then drive it a month or two before ls3 4l80 205 get dropped in it.
Old 07-01-2014, 09:55 PM   #37
Cobalt964ruf
14 bolt full float before rebuild. Name:  image.jpg
Old 07-01-2014, 09:58 PM   #38
Cobalt964ruf
Np 205 before rebuild. Name:  image.jpg
Old 07-02-2014, 11:41 PM   #39
Cobalt964ruf
more inspiration... again not mine. but way cool. Name:  129-1306-03+1972-gmc-2500-suburban-sir-burban+1972-gmc-suburban-side-view-rocks.jpg
Old 07-03-2014, 05:53 PM   #40
Cobalt964ruf
Thoughts plz... 4" lift front springs, so... I am not going high str or crossover steer, staying stock str with dropped pitman arm. Also going to use a ram for str assist. Thoughts?
Old 07-03-2014, 10:15 PM   #41
Does someone make a dropped pitman arm? You'll be happier with a raised steering arm and leave the drag link straight,if you meant drag link.
I have axles,lift springs,and 37" tires I'm dieing to put on and the only thing holding me up is I want to either do engine work or swap another in while the truck is easier to work on
Old 07-03-2014, 10:35 PM   #42
Cobalt964ruf
Size:  38.5 KB. Yes you are correct, the drag link.
Old 07-04-2014, 02:21 AM   #43
Cobalt964ruf
Size:  37.3 KB. oem 1 ton emblems
Old 07-04-2014, 02:23 AM   #44
Cobalt964ruf
Size:  37.1 KB Np205 complete rebuild kit. No Chinese crap parts either.
Old 07-04-2014, 02:25 AM   #45
Cobalt964ruf
Size:  36.8 KB. Dana 60f/70f front cover
Old 07-04-2014, 04:16 AM   #46
Cobalt964ruf
also converting the driveline ujoints to spicer forged 1410's thruout on front and rear driveshafts and the 205
Old 07-05-2014, 04:22 AM   #47
Cobalt964ruf
might be rethinking 35's on this truck and go to 37's, have not decided yet.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Old 07-05-2014, 06:23 PM   #48
Cobalt964ruf
In my front yard. Name:  image.jpg
Old 07-07-2014, 07:22 PM   #49
Cobalt964ruf
Resized pic in my front yard. Name:  image.jpg
Old 07-07-2014, 07:24 PM   #50
Cobalt964ruf
