Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-27-2014, 07:06 AM   #1
Cobalt964ruf
Cobalt964ruf's Avatar
1971 K30 burb - LS3, 4l80e, np205, Dana 70f, 14bff, Detroit lckrs, 4"lift, 35" BFG's
1971 Chevrolet K20 burb into a K30 rock burb family hauler. Name:  image.jpg
Cobalt964ruf is offline   Reply With Quote
Old 06-27-2014, 07:07 AM   #2
Cobalt964ruf
Re: 1971 K30 burb - LS3, 4l80e, np205, Dana 70f, 14bff, Detroit lckrs, 4"lift, 35" BF
Made a deal on the burb yesterday, pick it up Sunday morning.
Old 06-27-2014, 07:10 AM   #3
Cobalt964ruf
Yes I know it has a gmc grill po installed that from a collision repair. I kinda like it, gonna leave it. Currently the truck runs and drives so the mods will be over time, one at a time so the truck isn't down huge amounts of time.
Old 06-27-2014, 07:15 AM   #4
Cobalt964ruf
I was born in 1971 and have been looking for a 71 burb for a while. Found a 71 pu initially but now found this burb I'm really excited about the build. I am an ase master certified GM tech. I am retired now and just play with my toys in my private machine shop.
Old 06-27-2014, 07:25 AM   #5
Cobalt964ruf
The build; I have a new crate engine LS3 hotcam Mtr 520hp, stage 4 4l80e trans, rebuilding a np205 with new timken bearings seals and gaskets. Rebuilding a dana 70 front axle with new spicer bearings seals gaskets king pins and u joints 4.10 Yukon gears and Detroit locker, rebuilding a 14 bolt full float rear with new timken bearings seals and gaskets 4.10 Yukon gears and Detroit locker rear disc brake conversion, New skyjacker 4" all spring lift kit, and new BFG 35" all terrains. I have a 73-87 burb safari full length roof rack that I will retrofit. Will build from scratch front and rear rock crusher bumpers with winches. Build full side rock crusher step bars too. I have a safari snorkel kit for a 73-87 burb I will retrofit as well.
Old 06-27-2014, 07:33 AM   #6
Cobalt964ruf
Plan on putting late model burb seats in it that I already have too. Paint will be themed like a 71 cheyenne super pu, white roof, med blue, white stripe down side then med blue at bottom again.
Old 06-27-2014, 07:40 AM   #7
Cobalt964ruf
Size:  105.4 KB. Donor truck for a lot of the parts. Those are the tires and wheels.
Old 06-27-2014, 07:41 AM   #8
Cobalt964ruf
Size:  40.3 KB. Disc brake kit I built
Old 06-27-2014, 07:44 AM   #9
Cobalt964ruf
Size:  63.7 KB. Some of the spicer parts have come in
Old 06-27-2014, 07:45 AM   #10
Cobalt964ruf
Size:  100.8 KB. Warns came in
Old 06-27-2014, 07:47 AM   #11
Cobalt964ruf
Size:  90.6 KB. Griffin 3core aluminum came in
Old 06-27-2014, 07:49 AM   #12
Cobalt964ruf
Size:  44.0 KB. 2004 burb all 3 rows of seats will go in the 71.
Old 06-27-2014, 08:46 AM   #13
Bigdav160
Bigdav160's Avatar
It's going to be an interesting build. That's a nice parts truck. Do you plan to use it's longer springs? You might need a lift as the "K" - LS conversions I've seen leave little front axle-to- oil pan clearance. You might consider cross over steering as these 4x4's can have some bump steer.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-27-2014, 08:51 AM   #14
Cobalt964ruf
Not using the lift from the truck. Using hydraulic assist steering. The ls3 crate motor has a corvette low profile oil pan so clearance won't be an issue like on a ls truck pan.
Old 06-27-2014, 08:52 AM   #15
Cobalt964ruf
Forgot to mention using hydro boost setup from 1 ton, and 4 wheel disc brakes
Old 06-27-2014, 08:54 AM   #16
Cobalt964ruf
Thanks for the info on the bump steer dave
Old 06-28-2014, 12:54 AM   #17
Cobalt964ruf
Size:  36.4 KB. Interior pic currently
Old 06-28-2014, 12:56 AM   #18
Cobalt964ruf
Size:  83.0 KB. Current 350 v8
Old 06-28-2014, 12:57 AM   #19
Cobalt964ruf
Size:  57.5 KB. Gmc grill on Chevy looks good I think
Old 06-28-2014, 05:58 AM   #20
Cobalt964ruf
Size:  78.4 KB. Was a rural ambulance with small raised roof
Old 06-28-2014, 08:22 AM   #21
Cobalt964ruf
Gmc grill on Chevy looks good I think. Name:  image.jpg
Old 06-28-2014, 08:24 AM   #22
Cobalt964ruf
Overall I like it
Old 06-28-2014, 08:49 AM   #23
lowrodderchev
lowrodderchev's Avatar
Can't wait to see the finish product those old suburbans are pretty sweet
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 06-28-2014, 11:29 AM   #24
pwdcougar
pwdcougar's Avatar
Looks like a great project/starting point. Any idea what the seats that are in in now are out of? I'm interested in how the late model burb seats will fit too.
Is it me or is the roof raised up?
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 06-28-2014, 11:59 AM   #25
Bigdav160
Bigdav160's Avatar
The seats appear to be '93 Suburban seats. i was going to ask about the roof also. I thought it just might be an illusion.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
