02-16-2016, 10:48 AM | #26 |
Re: 1966 C10 Project Truck
Some pictures from the weekend
Painting up the rally wheels This showed up while painting so I slapped it in, super easy! She runs! New glovebox emblem too I also ordered these up for the new wheels, should be here in a week and look killer! Last edited by scoot_mcgrute; 02-16-2016 at 10:55 AM. |
02-16-2016, 04:57 PM | #27 |
02-17-2016, 10:56 AM | #28 |
Tires and wheels are on! I found a bad lower ball joint on the driver's side so I'll be doing those, master cylinder, wheel cylinders, brake hoses and packing the bearings next. It looks so much better with a proper wheel on it
Also noticed this little guy on the driver's side. Didn't see it until last night, I think it's pretty cool! More to come in the coming weeks |
02-18-2016, 01:23 AM | #29 |
Small update but I'm waiting on parts to button up the brakes and front suspension, shold be here next week. I also ordered some new springs for it, I'll be giving it a 2-3 drop. It should look killer and still give a small rake so I can haul some stuff around. It's been a great little project so far!
02-18-2016, 01:10 PM | #30 |
Quick question, where is a good place to source a high hump tunnel for these trucks?
02-19-2016, 10:47 AM | #31 |
02-19-2016, 04:35 PM | #32 |
So, going to look at a new motor tomorrow. Mine has been a crap shoot since I bought it, it had no oil in it, and the amount it smokes has me thinking it needs rings. Found a low mile Targetmaster 292 I6 mated to what looks like a T5 transmission (ad just says 5 speed) so more than likely going to be bringing it home! It's going to be awesome!
02-19-2016, 09:16 PM | #33 |
Figured since I'll be doing ball joints, I may as well slap some new springs in it too! 2" front, 3" rear CPP springs. Those paired with my 235s should give it a great look!
02-20-2016, 09:35 PM | #34 |
Picked this up today, the block says 4.8L but the head doesn't look like a 292 head, is it a 250 head?
02-20-2016, 09:36 PM | #35 |
Block stamp
02-20-2016, 09:38 PM | #36 |
No more 3 on the tree, it was fun for a couple laps around the neighborhood but the T5 will make it more fun for me
02-21-2016, 01:43 AM | #37 |
Figured the motor question out...
02-21-2016, 05:34 PM | #38 |
02-21-2016, 10:01 PM | #39 |
It's a 292 block and head. Just had a brain fart and thought the head was taller than a 250 and the blocks were the same. Had it backwards.
02-24-2016, 01:49 PM | #40 |
02-24-2016, 05:05 PM | #41 |
That's cool! Truck looks Sweet! Yeah the 292 has a taller block than the rest. A 194-230-250 head will fit on a 292. Common to put a 194 head on a 292 as the combustion chamber is smaller which means more compression.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-25-2016, 09:55 AM | #42 |
Thanks! It's been a fun learning experience so far! I'm excited to drop the new motor and trans in it along with the brake parts and new springs. It's going to be an awesome little driver when I'm done with it
02-26-2016, 12:36 AM | #43 |
What a great looking truck. Good progress, too.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
02-29-2016, 04:06 PM | #44 |
Thanks! I didn't get anything done this weekend since I'm fixing my Jeep from breaking an axle shaft last weekend. I did get just about everything I need for the motor and tranny swap though
In my spare time (ha!) I am a board member of the local Wheelin With Warriors group and we had a meeting yesterday. One of the other members loves the pickup and was able to decode the bumper stickers for me. If I heard him right, it was a runway crew ordinance truck in Florida. I'm not sure how it found its way to the NW but it did |
02-29-2016, 09:43 PM | #45 |
Wow, all the way from Florida to these parts. Mighty long haul. Dependability.
03-08-2016, 01:15 AM | #46 |
After the Jeep was finished in the garage, I pulled the 66 back in. I'm getting ready to pull the front clip this weekend and start prepping for the 292 and T-5. While I was spraying down all the bolts with Kroil tonight, I found that the passenger fender was welded to the rocker panel with a piece of a barrel. Who needs bolts????
03-08-2016, 01:46 AM | #47 |
Looks like the PO was trying to make it a unibody
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
03-08-2016, 04:45 PM | #48 |
Right? I'm just glad to have rescued the truck from those hands
While I'm doing the motor swap, I need to swap the ball joints out. I had ordered everything for the drum brakes and was going to do a disc conversion this summer with a donor truck. The 6 lug wheels have kinda grown on me and not having a ton of space to part a truck out, I looked at my conversion options. I'll have the CPP stock spindle disc brake kit at my door before too long |
03-11-2016, 08:11 AM | #49 |
Started tearing it down last night, the front clip will be off this weekend!
[IMG] I entered it in a car show in June, here's the list of things that will be done before then: 292 T-5 Hydraulic clutch Wilwood brake master cylinder Clean and paint the frame Front disc brakes 2/3 lowering springs Scrub the body down with CLR Bed wood? I'm hoping to reach my goal far before June but now I have a deadline to work towards |
03-11-2016, 11:09 AM | #50 |
Rootin' for ya.
Have to ask. Whats the cardboard sign on the windshield in the older pics. |
