Old 08-12-2016, 10:46 AM   #26
CES2749
Re: 64 Garage Build
Where did you get your 5 lug conversion for the rear end and was it simple to install? I'm debating on how to covert my rear end which is also a 64.
CES2749 is offline   Reply With Quote
Old 08-12-2016, 02:02 PM   #27
notsolo
notsolo's Avatar
Re: 64 Garage Build
Pick a couple colors you like and ask for a Photoshop with your wheels. Truck is looking great BTW.
notsolo is offline   Reply With Quote
Old 08-12-2016, 02:55 PM   #28
Hop
Re: 64 Garage Build
The axle are from Yukon Gear and Axle. Length (30 -3/4). Simple to put in. Make sure you measure from tip of shaft to the flange to get a correct measurement. You can get them form CPP, Summit etc. any vendor.
Hop is offline   Reply With Quote
Old 08-12-2016, 02:57 PM   #29
Hop
Re: 64 Garage Build
Thanks for the compliment. I will do that. Should be finished with it to get inspected on Saturday. Then I will get good pics and post.
Old 08-12-2016, 08:33 PM   #30
CES2749
Re: 64 Garage Build
Thanks. Was yours 17 spline or 30 spline axles? I'm trying to see if I can change axles without changing spider gears to 30 spline.
Old 08-13-2016, 08:55 AM   #31
Re: 64 Garage Build
Truck is coming together real nice.
Old 08-14-2016, 11:27 AM   #32
Hop
Re: 64 Garage Build
My axle is 30 spline. Think you will have to change the spider gears to match up. Someone chime in if I am wrong.
Old 08-14-2016, 11:29 AM   #33
Hop
Re: 64 Garage Build
Thanks Palf70Step. You guys on this board keep me inspired.
Old 08-14-2016, 02:23 PM   #34
CES2749
Re: 64 Garage Build
Thanks HOP. I got the 17 spline. So I'll have to get the whole conversion kit with spider gears. I was trying to do it another way cause I can't find nobody to fill and drill the axles(even Moser wouldn't do it when I called). Truck is looking good and love the wheel choice.
Old 08-14-2016, 09:45 PM   #35
Hop
Re: 64 Garage Build
Good Luck on the build and looking forward to the progress.
Old 08-14-2016, 10:42 PM   #36
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Re: 64 Garage Build
Hi Hop. Cool stepper! Those wheels look great.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 08-16-2016, 01:49 PM   #37
Hop
Re: 64 Garage Build
Thanks JL. As promised a little update. Took the Ol'Gal out for her first test drive with the neighbors and their girls. 84 IROC , 72 Vette. She ran well had but lost power in 6th gear. Got home checked timing, 8 degrees retard go figure. Advance the timing 8 degrees before TDC and she was extremely happy . I 'll try and get a closer side shot to see if I can get a photo shop of different paint colors. I appreciate the assistance with this build form my neighbors. Solid guys. Not done, but this far in 10 mos. Need a break now.
The marks on the street don't belong to us........
Old 11-01-2016, 11:23 PM   #38
mailman
mailman's Avatar
Re: 64 Garage Build
The truck is coming along nice cousin.I can't wait until we cruise together brother.
mailman is offline   Reply With Quote
