Old 10-05-2016, 03:13 PM   #26
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: 54 GMC 100: The Iron Ox
Originally Posted by joedoh View Post
looks like a pot of spaghetti blew up!
And wiring one of these old trucks should be as easy as it gets. To top it off, this is one of those generic wiring harnesses that has each wire labeled, but there is no schematic for it. On top of that, I've had to buy the ignition switch, light switch, dimmer switch all separately and they have generic wiring as well and there is no matching up wire colors. Even had to splice in the right light harness to the left side.
Anyway, I'll get'er done - the worst that could happen is I burn it to the ground, right?
I should have this part done sometime this week I hope - I'm about ready to hook up power to it to make sure everything works before I tie everything away.
I'm using all new parking light and headlights too, and replacing all the connectors - getting rid of all the old crap. Same with fuel sending unit annd dash instruments.
Zoomin is offline   Reply With Quote
Old 10-05-2016, 07:54 PM   #27
joedoh
joedoh's Avatar
stay away from dorman headlight sockets, I just bought some and they are crapola, the terminals push out of the plastic.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 10-05-2016, 08:55 PM   #28
DeanTX
DeanTX's Avatar
I went with H4 headlights so I used ceramic plugs. I didn't want to risk plastic ones melting
DeanTX is offline   Reply With Quote
Old 10-05-2016, 11:22 PM   #29
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Thanks for the advice guys.
I got some of the spaghetti cleaned up today. Hooked up the battery, no sparks or plastic melting which is always positive. Turn signals and parking lights are working. Put on the hood to cowl seal today. The old screws did not want to depart!
Old 10-06-2016, 08:16 PM   #30
SCHRUMGMC
SCHRUMGMC's Avatar
Loving this project so far
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 10-09-2016, 08:16 PM   #31
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Just because a truck has a ton of rust, I dont think it's a good dea to let it go without doing something to slow or stop it. Eastwood sells a spray on product that's a rust "converter" instead of an "encapsulator". Just go after the area with a wire brush then hit it with a couple thin coats.
Before
After
Got the headlights, parking lights and tailghts installed. The headlights are HID with the turn signals built into them. The turn signals I changed to be parking lights. One piece of amusement is that the new dimmer switch I bought worked for low beams only, so I cleaned up the American made 62 year old old one a bit and shot some lithium grease into it, and it works like a champ.
Spaghetti is getting under control
I should get the gauges installed this week
Old 10-13-2016, 11:13 PM   #32
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Decided to work on the dash and gauges so I could get them wired up. Here's how they looked before - all original and I don't know if they worked or not. If anyone wants them, drop a PM.
After
Old 10-14-2016, 12:55 AM   #33
joedoh
joedoh's Avatar
nice work! the fourth dimension has always been time.
are your headlights upside down?
Old 10-14-2016, 08:54 AM   #34
Zoomin
Man of Mini-Talents
Zoomin's Avatar
All the ones I've seen have the turn signal at the bottom. Now you've got me wonerdering...
Old 10-14-2016, 09:57 AM   #35
aggie91
I'm just glad to be here!
aggie91's Avatar
Love you builds. This one looks like a 180 direction change from your last few...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-14-2016, 12:13 PM   #36
joedoh
joedoh's Avatar
no I think you are right, the turn/park chamber on mine is on top!
Old 10-14-2016, 08:45 PM   #37
Zoomin
Man of Mini-Talents
Zoomin's Avatar
You're definitely nicely right about that. I've figured out my favorite part of the hobby is the build process, figuring out how stuff works, and it's as close as I'll ever get to artistic expression, if that makes any sense. And you don't have to drop big chunks of change to do it.
Hey, if it works that's a win IMO.
Old 10-17-2016, 01:03 AM   #38
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Got the gauges installed in the bezels and made up the wiring harnesses
Yes, that's a dent in the hood.
Old 10-18-2016, 04:25 PM   #39
mcbassin
Still Learning
mcbassin's Avatar
Cool Project Steve! I would have never known if you hadn't changed your picture....
Looking forward to following along.
mcbassin is offline   Reply With Quote
Old 10-18-2016, 09:27 PM   #40
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Well Mike, this is a project that I'm doing myself, a low budget-have some fun-twenty footer. I bought this on a whim and we'll see how it goes. It's been fun so far.
Old 10-29-2016, 04:22 PM   #41
solidaxel
solidaxel's Avatar
Great project and it is another solid windshield GMC!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-14-2016, 12:41 AM   #42
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Some progress to report. The gauges are in and the wiring is mostly complete. I cleaned up the firewall a bit in the process. I bought a leaf spring kit from Total Cost Involved (haven't received it yet) so I started the process of removing the current rear suspension, which looks like it's going to be a ton of fun in the form of rivet removal. Can hardly wait for that.
Old 11-14-2016, 09:47 AM   #43
mcbassin
Still Learning
mcbassin's Avatar
Nice work Steve! Sounds like you'll have fun on the rivet removal.
Old 11-14-2016, 01:59 PM   #44
iowaboynca
iowaboynca's Avatar
Man I do like how a 54's dash looks. Popping out the rivets aren't that bad as long as the cut the "X" in the head and pop it off.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 11-15-2016, 09:39 PM   #45
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Cut the X then drill out or chisel it?
Old 11-15-2016, 09:54 PM   #46
iowaboynca
iowaboynca's Avatar
yup. Cut an "x" into the head w/cutoff wheel down to the frame then use an air chisel to remove the head. then you can punch the remaining piece out with the air chisel. Definitely wear hearing protection. It can be LOUD!
Old 11-22-2016, 01:28 AM   #47
Zoomin
Man of Mini-Talents
Zoomin's Avatar
What a PITA! Each front spring mount has no less than 5 rivets holding it in place - 3 on the side and 2 underneath. I went to HF and pissed away some money on an air chisel. It did make a hell of a racket but not much of a dent in the rivet head. I found the best way was to grind the head down flush to the frame and then drill it out.
The two front mounts are out and now on to the rear mounts with only 3 rivets each, but the are all on the bottom of the frame.
After this everything else will seem like a blast...
Old 11-22-2016, 03:41 PM   #48
joedoh
joedoh's Avatar
man I hate grinding rivets.
for next time,
instead of a grinding disc use a thin cut off wheel in the grinder and be VERY CAREFUL (goggles, face shield, heavy long sleeve shirt, leather gloves, no shorts or flip flops!) to hold the grinder firmly, dont bind the disc or it will explode and the shrapnel is lethal. (maybe not lethal, but it will make you remember the date on the calendar as a BC/AD kind of thing)
slice the heads off the rivets, easy peasy, then drill a hole about half the size of the rivet in the center. the hole in the center takes the compressive force out of the rivet and you should be able to just bang them through.
if you have a plasma cutter, just blow right through the centers of the rivets and blow the heads off sideways, easy peasy.
Old 11-22-2016, 09:22 PM   #49
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Joe, I took your advice and ground the heads off. Wasn't easy peasy because there was always something in the way and being on the bottom of the frame I was treated to spark showers. I also learned why you recommended a long sleeve shirt too.
I had better luck drilling a small hole in the center of the rivet then going after it with a step bit after that. Then I just knocked the bracket off with a BFH.
Anyway, all those rat bastard rivets are off there now.
Next up is to grind the crust off the axle and get it painted and hang the brackets.
Old 11-22-2016, 11:14 PM   #50
joedoh
joedoh's Avatar
good workaround! I dont have a drill that will drill past the 4th step on a step bit haha.
