Old 02-03-2017, 03:13 PM   #26
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: inside door handles falling off
Originally Posted by vince1 View Post
Why would you want to tap them to 1/4" when !2-20 screws are surely available?
Modify them if you have to according to the description above in post #19.
Post #19... 10-24?, 10-32?, 1/4-20 etc. What is written in #19 can you please explain it to us? I'm curious as to what it means.
Old 02-03-2017, 04:08 PM   #27
vince1
OK I guess 12-20 is not a common size. From what I have just looked up #12 thread pitch would normally be 24 or 28 threads per inch. I think I would try running a 12-24 tap through before going to 1/4"
So that tells me that if I measured the screw correctly at 12 -20 it must have been a special screw made by GM.
Does nobody supply these original type door handle screws? It seems wasteful to drill and tap good original handles for lack of the correct screw.
vince1 is offline   Reply With Quote
Old 02-03-2017, 04:44 PM   #28
vince1
Attempting set screw picture
Old 02-03-2017, 05:22 PM   #29
forestb
forestb's Avatar
I am using after market handles.
forestb is offline   Reply With Quote
Old 02-03-2017, 05:49 PM   #30
The Rocknrod
Moderator
Their 1/4"-20 threads. Slotted Dog Point Set Screw. I think we'd be looking a long time to find exact new ones though. You can find allen head dog points though.
Old 02-03-2017, 07:56 PM   #31
vince1
My mistake then if they really are 1/4 - 20. I should have thought to put a caliper on the threads. Then it would be easy to modify something 1/4 - 20 to work. Not a total waste of time, we have pictures.
Old 02-03-2017, 08:46 PM   #32
vin63
It's Better With Nitro
vin63's Avatar
More surface area, the better for clamping (threads and set screw end).
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-03-2017, 09:05 PM   #33
TopFuel1966
TopFuel1966's Avatar
Originally Posted by forestb View Post
Was the hole size 1/4-20 or did you reatap it or just force it?
My original screws were #12 or possibly a metric thread with a slotted head and they kept coming loose from the shank. I drilled and tapped them for 1/4-20 set screws with an allen head.
TopFuel1966 is offline   Reply With Quote
Old 02-04-2017, 02:00 PM   #34
vince1
1/4 - 20 they are. I measured the major thread diameter at .243" so close enough. The head diameter was .252" and the the little nub at the end was .150" diameter. Time to eat crow. I must have been having a seniors moment.
Old 02-17-2017, 08:17 AM   #35
The Rocknrod
Moderator
Looks like Jim Carter has them:
http://www.oldchevytrucks.com/cart/p...21&i=9741|||||
Item Number: WI121
Old 06-01-2021, 07:44 AM   #36
The Rocknrod
Moderator
Wow. I pulled the set screws for the window cranks (counter part) and door handles in hopes to place in there dog point allen set screws instead. With a thread gauge I went through everything I had and couldn't find a match, some kind of strange made up BS.
The originals I have are 1/4-20 but very old and worn. Maybe I can tap them, what do you think?
Old 06-01-2021, 08:35 AM   #37
nsb29
nsb29's Avatar
My originals were rough so I went with the aftermarket after picking them up off the floor several times I used a little Loctite
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 06-01-2021, 02:54 PM   #38
The Rocknrod
Moderator
Yes, I just installed them with blue loctite, so we shall see.
Old 06-01-2021, 09:51 PM   #39
karlbenz
Originally Posted by 64shortbox View Post
I had the same problem on my reproduction door handles. Where the set screw made a mark or slight dimple in the serrated shaft on the door actuator I simply drilled a dimple where the set screw left its mark, drilling the dimple slightly larger than the set screw. I haven't had a problem with the handles falling off since.
I did the same
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 06-03-2021, 11:47 PM   #40
Nappers
If anyone has any lead shot (smaller), I put some in the handles and put the set screw in and tighten. I use it on my reloading dies and pretty much anything with a set screw.....
Nappers is offline   Reply With Quote
Old 06-04-2021, 10:04 PM   #41
karlbenz
How long does that last? never thought about lead
1965 Chevy C60
Old 06-05-2021, 03:07 PM   #42
Nappers
I haven't had them fall off yet! The lead squishes pretty good unless you use too much. I have really tiny re-used lead shot from indoor ranges that I'm using.
