Old 01-02-2021, 01:21 PM   #26
Rickjz
Re: Who makes a Fuel Injection tank for Blazers
I used Tanks Inc from Summit. Went into a stock Blazer tank.
Rickjz is offline   Reply With Quote
Old 01-02-2021, 02:29 PM   #27
Thealien
Thealien's Avatar
@Rickjz
That is what I did but am having clearance issues. The inlet and return are inline with the body mount and crossmember and the brass 90 degree fittings hit the crossmember by a lot 1/2-1"
Just want to give you a heads up as I am dealing with this now!
Old 01-03-2021, 03:41 AM   #28
Brad68c10Tx
Brad68c10Tx's Avatar
I used a Universal Tank from Tanks Inc. It had a in tank pump and return. Also a sending unit. Works great.
Brad68c10Tx is offline   Reply With Quote
Old 01-03-2021, 05:38 AM   #29
jjzepplin
jjzepplin's Avatar
Do you remember which one? Do you have any pics?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-03-2021, 06:44 AM   #30
jaros44sr
jaros44sr's Avatar
@Rickjz
20191002_093933 by [url=https://www.flickr.com/photos/97391199@N06
Had the same problem, took my stock tank to a fab shop and they welded a shelf in it
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-03-2021, 07:08 AM   #31
Thealien
Thealien's Avatar
[quote=jaros44sr;8858372]20191002_093933 by [url=https://www.flickr.com/photos/97391199@N06
Had the same problem, took my stock tank to a fab shop and they welded a shelf in it[/quote]
What pump and ring are you using?I Actually prefer a stock type pump assembly To the tanks incorporated 1 of using.
Old 01-03-2021, 09:54 AM   #32
jaros44sr
jaros44sr's Avatar
20190930_180411 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 01-03-2021, 10:01 AM   #33
jaros44sr
jaros44sr's Avatar
Originally Posted by thealien View Post
what pump and ring are you using?i actually prefer a stock type pump assembly to the tanks incorporated 1 of using.
vapor workz
SAFETY FIRST
AS usual, off topic
Jim
Old 01-03-2021, 10:31 AM   #34
Thealien
Thealien's Avatar
Originally Posted by jaros44sr View Post
vapor workz
Thank you
Old 01-03-2021, 12:45 PM   #35
Rickjz
@Rickjz
Yea, it’s pretty close! There is one fitting that is practically touching, the rest are clear. I do have new body mounts.
Old 01-03-2021, 12:55 PM   #36
Thealien
Thealien's Avatar
I also have new body mounts And tank is installed using the factory spacers. my fitting is halfway into that cross member.
Old 01-03-2021, 04:53 PM   #37
Rickjz
I guess I got lucky My Blazer is a 2wd. Not sure if it makes a difference. Your ID photo also looks like a 2wd.
Old 01-03-2021, 05:11 PM   #38
lux
I'm using https://www.summitracing.com/parts/sum-250151
It was an easy instal and it's working well so far.
lux is offline   Reply With Quote
Old 01-03-2021, 05:49 PM   #39
Thealien
Thealien's Avatar
2 wheel drive also?
I need to get the tires and brakes on and set ride height. Then I will decide if I can drop the tank an inch? Try and move the fittings around so they will miss the crossmember. Or weld in one of the recessed pump trays?
I would have bought a Boyds but his fill is 1 1/2 and the fuel fill is 1 3/8 and he doesn't want to make one 1 3/8?
Oh well its been going smoothly until this. About to get into wiring, starting where issues can come up?
Old 01-03-2021, 05:51 PM   #40
Thealien
Thealien's Avatar
Do you have any pictures of it installed and location of pump assembly?
Old 01-04-2021, 02:51 PM   #41
lux
Mine is in a 69 GMC truck with tank in rear.
Old 04-02-2022, 11:14 PM   #42
lt155ruck
lt155ruck's Avatar
Thanks for the inspiration, this is how mine turned out.
lt155ruck is offline   Reply With Quote
Old 04-03-2022, 03:55 AM   #43
Richard
Not sure if this is of any interest in this thread, but I thought it might be. I am using a later model Blazer tank in my truck I used a weld in ring and pwm controller from VaporWorx. Factory return less ZL1 pump I am using should be good to 650+ whp from what I understand. OEM pump is the only way I wanted to go. Aftermarket is to old school, and I am old school. Owner Carl is local to me. Real smart and nice guy, responds quickly to questions. Give them a call if interested.
Richard
