08-29-2018, 11:58 AM | #1 |
Who makes a Fuel Injection tank for Blazers
I have searched but can't seem to find a tank I can put a Fuel Injection pump in for my 72 Blazer.
I am doing a 5.3 swap and I do not want to run a frame mounted pump. If there is a way to adapt my stock tank I am open for that suggestion also. I searched the TANKS web site but all they seem to have is for 73-91 Blazers! Thanks guys!
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
08-29-2018, 01:10 PM | #2 |
Re: Who makes a Fuel Injection tank for Blazers
https://fitechefi.com/products/40004/
Probably one of the coolest fuel injection parts made these days. Just put it in the engine bay and then you don't need to run wires and build new fuel lines for EFI. |
08-29-2018, 01:17 PM | #3 | |
08-29-2018, 01:31 PM | #4 |
My best recommendation to you would be to have a local fabrication shop just weld you up a tank then, they are dirt simple and can be built to any capacity you want. Nice thing about the Blazers is the tank is just a square in between the frame rails so a fab shop can whip one out quick because there's no complicated geometry.
Can even have them build it out of SS (although more expensive) and never have to worry about it again. Speaking of "it's just a box", you might want to look into fuel cells. Universal ones come in "box" shape of all kinds of different dimensions. Would just need to make some brackets for it, costs is about the same as a fuel tank. |
08-29-2018, 02:27 PM | #5 |
you'll have to do some fabrication...... but a 87-91 Blazer or Suburban EFI tank can be used for an in tank set-up...search the Blazer build section...there are a few threads on it...
the tank will be around $100 or so....
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
08-29-2018, 07:38 PM | #6 |
Boyd welding
08-29-2018, 07:58 PM | #7 |
Yes Boyd Welding. Call AZ Pro Performance and tell them you want the Boyd Blazer Tank. It has the fill neck the right size and moved to make it easier to use the stock fill hose. I just got mine last week but haven’t had a chance to mount it yet. If you are a member of C10 Addiction on Facebook you get a discount.....
08-29-2018, 08:32 PM | #8 |
Too Dumb To Know Better
Got mine from Fuel Cell Guy.
He is on the forum. |
08-29-2018, 08:37 PM | #9 |
08-29-2018, 09:17 PM | #10 |
I also converted to a 5.3, but made my own tank. Converting an original tank is fairly straight forward if you have some fabricating capabilities. My best advice is to use as much OEM stuff as possible because it will be much easier getting parts later on if a problem should arise. I used a factory 2003 pump and assembly and have no regrets. In fact, I've used these assemblies on a few builds. They are cheap and are self contained including fuel sender, roll over valve and return line. Another bonus is that the assembly will adjust to different depth tanks so it's an easy install. While you're at it, cut an access hole in your floor so that you won't need to drop the tank for any future pump servicing. One last thing I would recommend is plastic (nylon) fuel lines front to back. Once you use these, you will never go back to the old steel lines.
08-29-2018, 11:11 PM | #11 |
Thanks guys, exactly what I was looking for!!!!!!!!!!
08-29-2018, 11:12 PM | #12 | |
How did you mount the new pump assembly in the old tank?
08-30-2018, 12:12 AM | #13 |
I’ll 2nd Boyd from AZ Performance. I have one sitting in my shop for my build. It’s a top notch tank and fits in the stock position. You can also have them move the filler neck if you don’t like the position. Mine is behind the mount to the rear of the truck. Just need to snake a hose to it. I think it was about 4-500 with shipping if I remember right.
Kirk 72 Blazer CST 4wd highlander |
08-30-2018, 09:07 AM | #14 |
I didn't. I mentioned I built my own tank, but converting an old tank is the same process. I machined a ring and retainer then welded it to the new tank.
08-30-2018, 02:53 PM | #15 |
Goin through putting the 87-91 tank in mine right now. This is the best thread that I've found on it. http://67-72chevytrucks.com/vboard/s...d.php?t=670191 More pics and fuel line AN fitting part numbers here http://67-72chevytrucks.com/vboard/s...=663780&page=2 might be on page 2 or 3. With a 4.5" angle grinder and a drill you can do the swap. With the tank in this location the filler neck shouldn't need to be modified or turned, it'll be just in front of the second from the rear body mount.
1972 K5 Blazer 350/350/PS/PB From GA but live in Panama City, FL |
08-30-2018, 05:14 PM | #16 |
Vintage Evil
Another vote for boyd welding... i have pics and install info if you need it...
Current Rides: Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread EvilK5 - 71 K5 Blazer Evil Twin - 2006 Suzuki M109R EvilDmax- 2018 GMC 2500 Denali Duramax |
09-04-2018, 03:28 PM | #17 |
Page 60 of the current LMC catalog looks like Holley has one that fits in the stock tank. http://www.lmctruck.com/icatalog/cb/full.aspx?Page=60
My toys: 1971 GMC Jimmy 2008 Hummer H3 Adventure 2003 HD Road King |
09-04-2018, 09:06 PM | #18 |
My Jimmy came from the previous owner with a nice new Poly replacement gas tank. I had a tall version of the areomotive phantom 340 fuel system laying around. I didn't need that much pump, so swapped it for a Walbro 255. It's been working for me nicely so far. I've had it down to 2-3 gallons in the tank, and no stumbles.
Not necessarily what I would have done from scratch, but I had the phantom setup on the shelf from another project.. |
09-07-2018, 06:49 AM | #19 |
Collector of Projects
09-07-2018, 08:51 AM | #20 |
Not so much tank related but avoid fitech like the plague as mentioned above.
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
09-13-2018, 10:42 PM | #21 | |
What’s the problem with Fitech? I did a Google search and all the threads are from 2016-17 so old Anyone have recent experience with the newer command center pump? Been considering for the 454 in my 70 2WD Blazer
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC Last edited by scf100; 09-13-2018 at 10:47 PM. |
11-01-2019, 04:42 PM | #22 |
Did I read correctly that the Boyds tanks have the correct/complete filler neck for the Blazer/Jimmy?
72' JIMMY 454 |
11-06-2019, 11:31 AM | #23 |
97 2 door Blazer fuel tank fits nicely in replacement of the stock tank. and you can drop in a fuel pump and sending unit.
11-06-2019, 07:07 PM | #24 |
Thank you, but I already ordered a Boyds from AZ Performance.
72' JIMMY 454 |
01-02-2021, 11:58 AM | #25 |
Ricks Tanks makes an adapter for the original tank to use a 2010 Camaro style pump but it's expensive and on B/O for about four months right now. Nice part but JEEZ!
https://rickstanks.com/tech/bolt-in-kit-27000/
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
