Old 07-21-2020, 02:30 PM   #26
SBTork
Garage wrench
SBTork's Avatar
Re: 86 Suburban daily driver
Awesome build! Reminds me of mine for sure.
Would you happen to have a picture or could take one of the rear barn door lock actuator location/bracket/etc? I need to add one to my '85 as it never had one and I'd really like to add it.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 07-21-2020, 03:51 PM   #27
BlueJeep
BlueJeep's Avatar
Thanks all! LED headlight upgrade is coming next when I get a little time. Found some with great reviews with Amazon open-box pricing! If they work well, it didn't cost much more than the relay harness would have.
Adam, sent you a PM. I can get you any pics/measurements you need.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 07-22-2020, 11:38 AM   #28
ShortHaul
ShortHaul's Avatar
Mind sharing that Amazon link? I’ve been after a set of led headlights for a while, but I’ve found they are either too expensive for my taste, or they look too modern for my taste. I really like the OG looking patterned glass lens that Dapper Lighting offers, but their prices are craaaaazy high.. I also considered VintageCarLED but didn’t find many reviews on their product...
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 07-22-2020, 12:23 PM   #29
BlueJeep
BlueJeep's Avatar
Sure. These are pretty modern looking, but because of the phantom grille on my sub I don't think it will be noticeable.
Here is the review (which I found very informative):
https://www.youtube.com/watch?v=wDJrn0JD_wM&t=1s
And the Amazon link to what I bought (4x6 rectangle, I know yours are round). I took advantage of the "used" option on Amazon for mine, which are usually their returns that the original packaging is damaged but the product itself isn't, and they sell at discounted prices. I paid $65.xx for these.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 07-22-2020, 11:10 PM   #30
BlueJeep
BlueJeep's Avatar
Had some craigslist luck today and scored a 2wd 4L60e, which aren't super easy to find here! Also found some Trailblazer SS exhaust manifolds last weekend. Collecting parts.....
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 07-23-2020, 09:47 AM   #31
Pontiac1976
Pontiac1976's Avatar
I hope you checked the manifolds good because they prone to cracks. They look like they been running a little hot the on the right mostly. The cracks mostly happen at the v off the ports. Just in case you did not know good luck.
looking pretty good so far for the burb.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-23-2020, 10:20 AM   #32
BlueJeep
BlueJeep's Avatar
Thanks for the tip, I did not know that so I'll have to check them out good.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 07-23-2020, 12:36 PM   #33
SCOTI
SCOTI's Avatar
Originally Posted by SCOTI View Post
I highly recommend 'over-doing' the c-notch if planning to tow. A simple bolt-in raised floor allows for better frame rail height above the notch & ample pumpkin clearance (win/win). It doesn't have to steal too-much interior compartment space. Even raised just 2" allows for a superior ('safer' since you're a family guy) set-up & wouldn't be that noticeable.
Originally Posted by BlueJeep View Post
Thanks! The whole family is on board with it, as soon as I get a few things fixed (including A/C).
Thanks for the heads-up, and I'm already on it! I already measured the space between the top of the diff and the floor, and used that as my measurement as to how deep the notch reasonably should be. I want to cut as little as necessary because hooking up a trailer is still important to me.
Here's an image of a shop built notch. Not much clearance gained for the work but it is what it is. I bet if you extended the plating on both sides of the frame to where it's just below the floor (box the inside of the rail & plate the outside portion), you gain strength & could go ~3" into the rail. wouldn't have to cap the top off making it an easier install (as long as it doesn't trap moisture).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-23-2020, 12:56 PM   #34
BlueJeep
BlueJeep's Avatar
Thanks for the picture! Is that a blazer by chance? Mine doesn't have the crossmember right above he notch like that one. I will box the inside for sure, and I was also thinking of running it higher and filling in some of the gap between the frame and the floor.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 07-23-2020, 01:14 PM   #35
SCOTI
SCOTI's Avatar
Yes. It's a Blazer.
I would make the plates as tall as will fit. The strength is in their height. Capping them will add some rigidity but the main thing would be the height & doing it to both sides (like an I-beam).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-23-2020, 09:19 PM   #36
BlueJeep
BlueJeep's Avatar
I gave the manifolds a quick dusting in the blast cabinet so I could check for cracks, these are good to go! Were rusty, but other than that just fine.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 08-23-2020, 09:27 PM   #37
BlueJeep
BlueJeep's Avatar
While planning for my notch, I had a chance to stop at a Pick-N-Pull and grab some more parts off the list. Realizing how much I use the rack on top of my DD suburban, I wanted the utility of one for this one too. I grabbed the rack off a 2005 Suburban, the cross-bars will need to be narrowed just a bit and it'll fit great! The way they are put together, it will be easy to narrow them. I also want to not get rear-ended in traffic if I can help it. The LED taillights I already added plus this LED 3rd brake light off a 2004 Tahoe should help with that. Nothing is mounted yet, just sitting there for a preview.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 08-23-2020, 09:39 PM   #38
BlueJeep
BlueJeep's Avatar
I've been planning for my notch for a while now. I've now come up with a solid plan and I've started in on it. It may take me a while because lots of other stuff going on, but have a start on it.
First up was fixing where the wheels sit in the wheel wells. It drove me nuts that they weren't centered. I also couldn't live with the u-shaped flip brackets. I know there are thousands of them out there....but doesn't do the job for me. My number ended up being 1/2" back from the centering pin.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 08-23-2020, 09:56 PM   #39
BlueJeep
BlueJeep's Avatar
Got my template figured out and transferred it to 3/16" plate. The outside will be plated, the inside will be boxed, and the notch cut out and welded in. They raise up about 1" above the original frame rails, and will be capped. All of this will be below the floor. The inside of the C-Channel frame also needs to be trimmed, because it is in no way straight enough for boxing plates! I had to remove the body mount and will trim 3/16" out of it before it goes back on.
More to come!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 08-30-2020, 09:16 PM   #40
BlueJeep
BlueJeep's Avatar
Got a decent start on the notch this weekend. There was quite a bit more fine tuning I had to do with the plates I had previously cut out, but I'm pretty happy with how it's turning out. I started out with cutting out for the notch, then welding in a piece of 1/4" plate I bent in the shape I wanted.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 08-30-2020, 09:19 PM   #41
BlueJeep
BlueJeep's Avatar
After I had the basic notch in, I worked on boxing the inside of the frame rail. Not fun working out of position with obstacles in the way, but I did make it happen.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 08-30-2020, 09:23 PM   #42
BlueJeep
BlueJeep's Avatar
I then worked on the doubler plate for the outside. If I didn't have aspirations of pulling my trailer, I would have skipped this step. The back I did wrap into the shock mount "depression" in the frame.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 08-30-2020, 09:29 PM   #43
BlueJeep
BlueJeep's Avatar
Last on the list for this weekend was to section the appropriate amount out of the body mount so that everything still lined up. This was a pretty basic operation with mock up at the end. Now after I get the other side done, I'll jack the body up off the frame and cap both notches. Again, they extend up above the existing frame rails to just below the floor.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 08-30-2020, 11:15 PM   #44
SCOTI
SCOTI's Avatar
Looks good.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-02-2020, 08:48 AM   #45
focusedontheprize
focusedontheprize's Avatar
Nice work and that notch looks to be absolutely solid.
focusedontheprize is offline   Reply With Quote
Old 09-03-2020, 06:07 PM   #46
Corts60
Just here to tinker
Corts60's Avatar
Originally Posted by Keith Seymore View Post
It was a standalone option KC4, or included with the HD trailering package Z82.
K
https://www.gmheritagecenter.com/doc...t-Suburban.pdf
My '86 half ton burb has the trailering package and has the cooler.
How come you didn't just replace the hoses? Never gonna tow anything?
Old 09-03-2020, 06:20 PM   #47
Corts60
Just here to tinker
Corts60's Avatar
Great work on that notch!
Old 09-04-2020, 01:39 PM   #48
BlueJeep
BlueJeep's Avatar
Looks good.
Thanks guys!
As to the cooler, they aren't that effective vs. the leaking problems they have so the benefits don't outweigh the costs (risks). That, and this will only have a SBC for a little while, I'm gathering parts for a 5.3 swap. I will still pull a trailer.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 09-14-2020, 07:05 PM   #49
BlueJeep
BlueJeep's Avatar
More progress with the notch. The passenger side is now done!!! I had to jack up the body off the frame to weld the top of it, so yes at this point I really envy the pickup guys who can just take the bed off to do this! I opted to not cap the notch in the interest of getting it done, and I don't feel like I'm leaving that much strength on the table.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 09-14-2020, 09:18 PM   #50
SCOTI
SCOTI's Avatar
I wouldn't worry about not capping it. The strength is in the height & each side is still 'connected' within 1-2 inches below of the top.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
