01-18-2021, 12:16 PM | #26 | |
Re: Front suspension and steering questions
1963 C20, small window, long bed 292, 4-speed |
01-18-2021, 04:34 PM | #27 |
The distance from the frame to the top of the axle is 1/4” less on the driver side. Not sure if this would make a difference of 1-1/2” when sitting on the ground.
I wonder if the pan hard bar could affect this?
01-18-2021, 05:47 PM | #28 | |
1/4" is not going to translate into 1.5" on the opposite end. That dimension is within 'standards' of a vehicle corner height.
01-18-2021, 06:00 PM | #29 | |
01-18-2021, 06:24 PM | #30 |
More info.
I think it is the way the spring sits in the retainer. Is this spring retainer intended to be positioned a specific way?
01-19-2021, 03:51 PM | #31 |
Do those springs look too collapsed with the truck just sitting on the ground?
And, will 1/2 ton springs work on a 3/4 ton truck? I am not planning on carrying heavy loads, just normal driving around town. The Truck and Car Shop in Orange only lists springs for 1/2 ton pickups.
01-19-2021, 04:03 PM | #32 | |
2) Yes, they do.
01-19-2021, 05:41 PM | #33 |
Those springs do look pretty collapsed. I'd be worried it would sit too high if you bought new stock springs. A lot of guys (including me) use 97-06 Jeep TJ rear coils as drop coils on 1/2 tons. (ACDelco 45H2104)
01-19-2021, 06:03 PM | #34 | |
2” maybe??
01-19-2021, 06:22 PM | #35 |
4" I believe. And I see in my notes the ACDelco 45H2104 is a 653lb variable spring.
01-19-2021, 06:54 PM | #36 |
I read a couple posts about those springs, people complaining of spongy ride. Not sure if that’s accurate. I wasn’t planning on a 4” drop - is that just the rear, or 4” drop for the front too?
01-19-2021, 07:20 PM | #37 |
Mine is 2 1/2" drop spindle front with stock springs, 4" drop in back with those Jeep springs. It's a short fleet and the back is very stiff. I still want to try to loosen it up with some different shocks but that will be after I get it from storage in the spring.
There is also a heavier Jeep spring. The ACDelco 45H2103 and the Moog 47939GB are 821lbs variable. One of my biggest complaints about my truck is the poor (clunky/stiff) ride. The other complaint I have is not enough leg room. Last edited by bigmoe; 01-19-2021 at 07:36 PM. |
01-19-2021, 08:21 PM | #38 |
I think I’m just going to go down to the Truck Shop and see if they have the 2” or 3” drop springs for the rear. At least those will fit and all I have to do is get the right drop. The Jeep springs are not a sure thing, and if they are 4” drop that’s probably too much for what I want.
01-20-2021, 09:57 AM | #39 | |
Since you ask the question, people have been lowering vehicles since long before most of us were born. That said, I have never liked the lowered or slammed looks. The lower something sits, the more it looks to me like it's broken. I guess I'm more of an "original" guy. Again I'm not saying lowering is "wrong", just that to my eyes the truck looks more normal at standard ride height. YMMV. |
01-20-2021, 11:38 AM | #40 | |
01-20-2021, 06:29 PM | #41 |
I looked in the manual and it shows a notch should be aligned with the end of the spring. Not sure if the end of the spring should be facing in or out? Anyone have an idea?
On the passenger side, the spring was not removed, so it seems the driver side spring was incorrectly installed. Has anyone installed these before? Can you confirm the notch is on the spring retainer?
01-20-2021, 06:49 PM | #42 | |
Just clock the springs the same on each side & install the retainers similarly @ each side.
01-22-2021, 10:42 PM | #43 |
I installed stock height, new coil springs in the back and got a new track arm (pan hard bar). I think it sits more level than before. Rides a lot better too. Next step is to replace the front springs and ball joints.
Also going to list some 2” drop springs; these did not work out for me. Couldn’t get the wheels mounted, tires a bit too wide.
01-23-2021, 12:23 AM | #44 |
How's your cab and core support mounts lookin? If they are blown out, that could also make it look like it's leaning
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
01-23-2021, 12:54 PM | #45 |
I have a similar problem (made even worse because the short box has a smaller wheel opening). Solved it by jacking the truck up by the frame so the suspension is in full droop. That gives room to remove/replace the tire.
07-28-2021, 10:54 PM | #46 |
Well, the truck is still leaning to the driver side. Measured at the rear bumper it is 1-1/2" lower on the driver side. I may need to jack it up at the frame and loosen the springs and see if I can rotate them to get it to sit evenly.
Maybe that will work.
07-29-2021, 07:27 AM | #47 |
Moderator
Looking at the a-arm space when seeing the front of the truck, that's what I'd look at also.
