#26 |
Re: Drum to disk brake conversion on 1967 C20
I'm curious on the front wheels how much I would have to swap out of a later model pickup to use the stock disc brakes off of them? Could I get away with the spindles or would I have to do the A-frames as well?
I was kind of thinking of using the ones off of a '72, but looking at LMC, it looks like they don't offer the spindles as new parts, and I was also wondering about new bushings. Where should I look for parts like that? Would the local Chevy dealer be able to get something like that for me? Or would I have to go looking in a junkyard for spindles? And what would I do for bushings? |
#27 |
![]() Join Date: Aug 2019
Best to score a complete subframe ( front suspension ) from a 73 to 86. It should bolt right in. Get the master cyl and the prop valve with it.
#28 |
![]() Join Date: Nov 2018
Or up to a 91 since he has an 8 lug. Suburban and one rona kept going for four more years past the 87 R10
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
#29 |
What year did GM go to metric lug nuts?
#30 |
Not till the OBS body style
#31 | |
#32 |
The only reason is parts replacement. 71/72 parts are getting harder to find. I still have my original 72 disc brake set up and plan on keeping it.
#33 |
That right there is just wrong. They use the same brake pads, calipers interchange for almost 20 years, brake hoses can always be used from a different year if 71/72 can’t be found. Control arms interchange with the difference being bushing type. Lastly what’s the point in hoarding parts if you won’t use them?
#34 |
Would it be hard to find bushings for a '72? I suppose one of these days before work I'll just have to call the local Chevy place and see what I can get.
#35 |
That part is a good question. But if you’re referring to the solid non rubber style. I’ve never seen a set that had enough wear to be considered worn
#36 |
#37 |
I guess I figured that since I'm stripping everything down to repaint it I might as well put new bushings back in instead of the old ones.
#38 | |
#39 |
Its not hording when they are still under the front end of my 72!
#40 | |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
#41 | |
FYI though I was referring to the difficulty of being able to getting parts when I said that’s wrong
#42 |
For my 64 C20 I ordered from POL in 2016-2017 timeframe for their front disc brake conversion with 2.5" drop spindle... It is currently on the truck, but I am still in the process of getting the truck back together.
That being said, I have also gone to a 2002 2500HD 14bolt with disc brakes, finally got brackets on it and had to have custom u-bolts made to mount it to my CPP trailing arms... Will hopefully have the truck completed for the 2022 car show season.
1964 Chevy C20 Restorod 2000 Subaru Impreza 2.5RS Coupe race car 2003 Chevrolet Corvette Z06 2019 Ram Rebel (5.7eTorque) - 2020 ATC 22' Race Trailer 2020 Dodge Durango SRT |
