Old 09-20-2021, 02:28 AM   #1
Captain X
Captain X's Avatar
Drum to disk brake conversion on 1967 C20
So I have a 1967 Chevy 3/4 ton that I would like to convert to disk brakes all around if I can. I was wondering if any companies offered a kit conversion for this style of rear axle, and if anyone had any recommendations for front wheel conversion kits.
Failing any handy kits, does anyone know if Chevrolet ever made a HD 3/4 ton with a rear axle of this style that came with disk brakes and would work on a '67 C20?
Captain X is offline   Reply With Quote
Old 09-20-2021, 11:18 AM   #2
Big Kev-O
Big Kev-O's Avatar
Re: Drum to disk brake conversion on 1967 C20
If you have an Eaton or Dana 60 rear axle Lugnut4x4.com sells disc kits. It's is hard to tell which axle you have without seeing a picture of the differential cover.
https://lugnut4x4.com/product/eaton-...se-your-rotors
https://lugnut4x4.com/product/dana-6...oose-your-axle
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 09-21-2021, 05:33 AM   #3
Captain X
Captain X's Avatar
Well, it's like a 3 hour drive away from me, so I can't just stick my head under there and take a picture just now, but I know it's a posi-track rear end with a big round pumpkin.
Next time I'm there, what should I look for to tell me if it's an Eaton or Dana?
Old 09-21-2021, 12:03 PM   #4
Caddylackn
Caddylackn's Avatar
The problem with rear disc brake kits is the parking brake. The rear disc swap kits usually use the cadillac eldorado type rear calipers with the cable operated rear parking brake. The cable disc parking brake arrangement is usually too weak to hold a truck with a load on any hill. Unless you have a manual with a granny gear this will be problematic if you have a camper or a load.
To overcome the weak rear parking brake, you can add a line lock on the hydraulic brake line or use the motorhome type turbo 400 which has the drum parking brake on the output shaft.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 09-22-2021, 04:17 PM   #5
Captain X
Captain X's Avatar
I don't suppose there's a way to strengthen the parking brake on the kit, is there?
This is also part of why I was wondering about rear axles on later models that just came stock with disk brakes.
Old 09-27-2021, 02:44 AM   #6
Captain X
Captain X's Avatar
So I managed to get out there this weekend, and here's the differential.
Old 09-27-2021, 11:38 AM   #7
Big Kev-O
Big Kev-O's Avatar
That is an Eaton rear axle.
According to Lugnut4x4:
"Our e-brake calipers are unique. While they're based on GM designed JB6 calipers made for the '76-78 Cadillac Eldorado, Lugnut4x4 e-brake calipers feature a much stronger parking brake lever arm that is better suited to heavy-duty applications."
Old 09-27-2021, 01:20 PM   #8
Madkidd007
Madkidd007's Avatar
The aftermarket disc brakes using the eldarodo calipers are not ideal and I wouldn’t trust to hold a truck still on a hill. Being you have a trailing arm truck you can’t use an entire late model axle. Personally my c20 converted to disc on just the front with hydroboost will put you through the windshield. In a truck rear discs from a useful aspect aren’t worth it unless you have a lot of weight in the bed. But as far as the front goes, entire front end from a square body works
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 09-27-2021, 01:27 PM   #9
dagnabbitt
dagnabbitt's Avatar
As others have noted, rear disc brakes can be more trouble than they are worth in trucks, especially 3/4 tons. But I know better than to try to talk someone out of what they want to do.
I don't think you have mentioned what transmission you have. It is a manual? You will be using that parking brake all the time.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 09-28-2021, 02:37 PM   #10
Captain X
Captain X's Avatar
Yes, it's a four-speed manual.
I just like the idea of converting to disc brakes because I hate working on drum brakes, and they're more efficient anyway. The only real concern I have is the same one I've always had, which is the parking brake issue since I know how they work in drum brakes, but really nothing about how they work in disc brakes. And then there's the other concern of if they'll work for a 3/4 ton.
Old 09-28-2021, 04:03 PM   #11
dagnabbitt
dagnabbitt's Avatar
Well, one thing you could consider is a driveshaft brake, there is some precedent for these on our trucks. If you check out my 68 C20 build you will see that it was an actual option on mine: and if your trans is an SM 420 - it should be, if it is a 67- it might be easier than you might think if you collect the right parts. I complain a lot about mine of course because there is so little information on them, but I also think it is kind of cool and if it works, it works. I have yet to get mine assembled but it is pretty straightforward for me since it originally had one.
http://67-72chevytrucks.com/vboard/s...d.php?t=795405
There is always a way to get what you want, and if you really want discs in the rear you can have them and have a parking brake, too.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 09-29-2021, 07:17 AM   #12
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
I actually have one of these driveline brakes on the back of an SM420 but it came out of a larger truck like C50 or C60. I think it would be neat to use it in something, just don't have a plan for it yet
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 09-29-2021, 08:40 AM   #13
Madkidd007
Madkidd007's Avatar
I forgot my 62 1 ton was setup that way, it worked great. More than once I forgot to take it off and stalled the truck
Old 09-29-2021, 10:14 AM   #14
dagnabbitt
dagnabbitt's Avatar
I'm hoping to get mine together this winter. I have yet to actually see one on a 67-72 so its going to be trial and error, but I also think it will be cool. I have always preferred a handbrake to that little pedal.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 09-29-2021, 11:21 AM   #15
RichardJ
You're going to adapt your SM420, that dates from 1947, so that you can put more modern disc brakes on a '67 Eaton axle? Even at that, the calipers are going to be skimpy car calipers on a 3/4 truck.
I don't see it?
My '67 3/4 has disc/drum and a SM365 (original 3spd). If i considered any change, it would be one that proved real improvement to the truck such as a NV4500 5 spd.
The NV4500 was available with a tail housing mounted driveshaft brake. Might be easier to find than a SM 420 brake
I'd be so excited about having the 5spd, I wouldn't want to ruin that thought by thinking about car calipers on the rear. I'd keep the drums and use a regular NV4500.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 09-29-2021, 11:50 AM   #16
jarrodblake
jarrodblake's Avatar
Have you priced out a Lugnut4x4 disk brake conversion with the E brake option? It may be cheaper to swap the axle for a newer disk brake axle. I was going to use the Lugnut4x4 conversion but for the price it was cheaper to swap axles.
jarrodblake is offline   Reply With Quote
Old 09-29-2021, 02:39 PM   #17
Captain X
Captain X's Avatar
What would be a good axle to use for it?
Old 09-29-2021, 02:55 PM   #18
Madkidd007
Madkidd007's Avatar
There isn’t one, all of the late model axles with disc brakes are too big. It’s the axle tube diameter that’s too big, leaf spring trucks can do it but not a trailing arm truck
Old 09-30-2021, 03:55 AM   #19
Captain X
Captain X's Avatar
Would this keep the front tires in line with the rears (I noticed the conversion kit says it will move the tires out 1/4 inch)? And would I be able to just swap spindles, or would I have to swap the A-arms and steering and everything?
As far as the rears, would I maybe be able to pick out a vehicle with beefier rotors and calipers and custom make any parts I might need? Would a such a set also have a stronger parking brake set-up? I'd kind of like to keep the hand brake. Or is that no good for any disc brakes?
Old 09-30-2021, 04:38 AM   #20
mcmlxix
Collector of Projects
mcmlxix's Avatar
I swapped a late model AAM 14BFF with factory disc brakes under my 1972 K5 Blazer. It came out of a 2005 GMC 2500HD truck. There are two versions, one with a 10.5" Ring Gear and an 11.5" Ring Gear identified by if it has a weighted ring on the input yoke. The new axel is wider than original and will use metric brake line fittings and wheel studs. I had to remove and replace spring perches and shock mounts on the axle tube. I used aftermarket E-brake cables.
www.car-part.com
Rich
1972 K5 Blazer CST Click HERE
Old 09-30-2021, 05:25 AM   #21
BigBird05
Why do you want to go to rear disc brakes? A good brake job and a properly adjusted parking brake will work just fine on your truck. The rear brakes only provide between 20 to 30 percent in stopping power. The factory went to rear disc for weight savings. Every once counts.
BigBird05 is offline   Reply With Quote
Old 09-30-2021, 02:35 PM   #22
Captain X
Captain X's Avatar
www.car-part.com
I'm hoping not to have to do anything that drastic, but thanks for the info.
Because disc brakes are easier to work with. They are also more efficient.
Old 09-30-2021, 05:54 PM   #23
Mts67C10K20
Mts67C10K20's Avatar
Here is an article from 4 wheel magazine it will answer several of your 4
Good wrenching
http://www.fourwheeler.com/how-to/su...o-disc-brakes/
I seem to remember hearing that the 14 bolt kit will work with an Eaton 052
You'll have to confirm for yourself
Mts67C10K20 is offline   Reply With Quote
Old 10-01-2021, 03:59 AM   #24
Captain X
Captain X's Avatar
Good wrenching
Thanks, that kind of gives me some ideas. I'm kind of thinking all I might have to do is get the rotors and calipers off a newer model of Chevy 3/4 ton and get the brackets this guy got, or maybe even have a machine shop make me some based on measurements I'd make. The driveline brake this guy uses is more appealing than the stock one other people were mentioning, but I'd still love to use one that just engages the rear calipers mechanically just so I don't have yet another brake to worry about. Though, I found a video about the kit that Big Kev-O brought up, and it looks plenty heavy for what I'd need, and the only downside to it is that since the rotor fits along the outside of the old hub, it moves the tire out 1/4" from where it is stock. I guess that wouldn't matter as long as I got the kit for all four wheels, and you probably wouldn't be able to tell looking at it that way, but part of me likes the idea of what this guy did better.
I'm wondering what exactly is the problem with the kit's e-brake as far as it not being strong enough. Is it just a problem with that particular design, or is it fundamental to disc brakes in general?
Old 10-01-2021, 04:08 AM   #25
mcmlxix
mcmlxix's Avatar
Electronic Parking Brake Rear Retrofit Brake Kit Description
Wilwood’s Electronic Parking Brake kits provides a complete parking brake solution for 0.81" and 1.10" rotor width rear brake kits. The Black or Red powder coat external electronic parking brake provides superior static holding power and a simplified installation with the included controller, harness and switch assembly. Installation would require custom bracket assemblies to fit to most application
WILWOOD WEBSITE HERE
Rich
