03-21-2024, 10:18 AM | #26 |
Re: Well, I did it again.....
That looks like a great start, good score!
03-21-2024, 10:47 AM | #27 |
Amen!
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
03-21-2024, 07:03 PM | #28 |
We're all looking forward to more pictures, especially when it's all on Leon's property.
Doesn't look like too much is missing.....but engine looks like it might have water in it... |
03-21-2024, 07:42 PM | #29 |
I know that truck.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
03-21-2024, 09:06 PM | #30 | |
The Older Generation
Thanks....
Yep, I looked at it back in 2019 but the guy that owned it then wanted too much for it. http://67-72chevytrucks.com/vboard/s...d.php?t=790724 He later sold it to the guy I just bought it from. . .
04-08-2024, 10:26 PM | #31 |
I now have the engine running and it sounds pretty good. The radiator had a leak in it so I had to fix that. Don't flame me for the back country core support brace... The under dash wire loom was a mess so I pulled it all out. Notice the two fuses with aluminum foil wrapped around them... .. I also removed the A/C components and wiring. The cluster had a couple of non-stock gauges in it so I disassembled it and removed them. I think I have another complete cluster I can use for it so I may just use this one for parts. .
04-09-2024, 12:19 AM | #32 |
In for this. You are reinstalling the A/C right? If not - let me know. Florida is hot!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
04-09-2024, 02:39 PM | #33 |
All about them K’s
Interesting that it’s an ac truck without a clutch fan. Never seen that before. Probably a Po’s shenanigans.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
04-09-2024, 03:55 PM | #34 |
Man you got it torn down quick ?
71 C-20 07 Magnum RT AWD |
04-09-2024, 06:06 PM | #35 | ||
I just hope I can get it put back together as quick...
04-09-2024, 08:28 PM | #36 |
I'm watching.
04-15-2024, 10:55 AM | #37 |
Replacement under dash wire loom and complete stock cluster are now in. Both items in good shape that I had on hand. I also dug out a pretty decent engine compartment main power/headlight loom that I am going to use. I think I can save the starter/ignition loom. I will pull it out this morning and check it out. If not I have one I can use. I also replaced the dash pad with a maroon one I had. It has a couple of small cracks on it but it is in a lot better shape than the black one that was on it. Next I am going to check out the brakes and start bolting the sheet metal pieces back on it. Keep in mind that this is not a rebuild or restore project but a get it running and driving safely project because I am probably going to have to sell it since I just purchased my Uncles all original '69 1/2 ton pickup.
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-15-2024 at 11:05 AM. |
