Old 04-13-2015, 12:01 PM   #501
SaltyC20
SaltyC20's Avatar
Re: Project 69SWB
Looks great. I like the green needles on the gauges.
1968 Chevy C20
SaltyC20 is offline   Reply With Quote
Old 05-11-2015, 11:02 PM   #502
sduckworth13
sduckworth13's Avatar
Re: Project 69SWB
Any progress lately Jimmy?
Scott
sduckworth13 is offline   Reply With Quote
Old 05-14-2015, 09:56 AM   #503
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by RRR18 View Post
Thought I was subscribed. Am now. Nice work.
Thanks RRR18!
Originally Posted by Low Elco View Post
I used the vacuum trick, and grease on the drill bit. Seems ok.
I ended up taking the bearing out
Thank you.. I've always like Black and bright green together.
Yes I've made a bunch of progress.. will sort pics and post up tonight... Even got a video and starting it up. ;-)
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 05-14-2015, 10:39 AM   #504
sduckworth13
Re: Project 69SWB
Awesome
Scott
Old 05-14-2015, 01:03 PM   #505
jmking9
jmking9's Avatar
Re: Project 69SWB
Cant wait!!
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 05-15-2015, 10:34 AM   #506
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
OK here are some updates.
After I finished laying out, vinyl wrapping, and splicing on connectors for the Painless Wiring first thing I needed to do was fix my Neutral Safety Switch issue.
I have a Van tilt and the hole for the NSS is too high up on the column and was hitting the brake assembly. I needed to cut a hole for it to sit in lower on the column closer to the firewall.
I marked where it needed to be while the column was still in the truck, then commenced to cutting.
The NSS for the trucks is different than the Van, the Van NSS has a longer nub that fits down into the groove, because I already had the one for the truck I just welded some tabs on so the shorter truck would catch and work correctly. I also, drilled holes and tapped.
Jimmy
.69SWB Build.
Old 05-15-2015, 10:41 AM   #507
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Next up was the master cylinder and brake booster
I dissembled everything so I could get it down to bare metal.
I dropped all the brackets into my electrolysis tub. I have gotten so much use out of this and it is my GO-TO rust removal choice... especially for odd shaped parts that are a pain to strip with a drill and pad.
This stuff comes off with a brillo pad
Smaller parts I just knock out with my gator wheel
Jimmy
.69SWB Build.
Old 05-15-2015, 10:44 AM   #508
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Here's the finished work.
I bought a new MC from Jegs and I have an original prop valve. Working on the brakes coming soon. I just wanted to get the harness in and as much of the engine bay done as I could and start the ol truck... so I'll come back to brakes soon.
Jimmy
.69SWB Build.
Old 05-15-2015, 10:49 AM   #509
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I got all the carpet, kick panels and the seat in, pay no attention the steering wheel it's a work in progress from a few pages back, that I'm not done with and not sure I'm going to use. Before I laid the carpet and put the seat in I put down a layer of mass loaded vinyl.. no pics, but under it all is hushmat, mass vinyl, jute, then the carpet... should be nice and quite.
seat cover, carpet, headliner.. everything is from Truckseats. Tim is a great guy to work with and has great products. There's new foam on that seat too. I did that a while back... pictures further back in thread. door seals are GMCpauls, they are awesome.
Jimmy
.69SWB Build.
Old 05-15-2015, 10:53 AM   #510
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
ok ther rest of these pics are just random engine bay pics showing different things I've done, restored, put back together.. to get to a point to where I could start the truck. I know in the pics are things that need buttoned up and will be doing, I just wanted to start it!
Jimmy
.69SWB Build.
Old 05-15-2015, 10:54 AM   #511
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Jimmy
.69SWB Build.
Old 05-15-2015, 10:56 AM   #512
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
truck wouldn't shut off, had to install this diode on the white wire.
Jimmy
.69SWB Build.
Old 05-15-2015, 11:18 AM   #513
Xeen
Xeen's Avatar
Re: Project 69SWB
Congratulations on first start up, you must be stoked.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 05-15-2015, 11:26 AM   #514
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Oooooh yeah, thanks Brian... still lots of work to do, but it's a big step forward
Jimmy
.69SWB Build.
Old 05-15-2015, 11:26 AM   #515
RRR18
RRR18's Avatar
Re: Project 69SWB
Yes!
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 05-15-2015, 01:17 PM   #516
sduckworth13
Re: Project 69SWB
Nice work Jimmy. The engine looks and sounds great.
Scott
Old 05-15-2015, 01:20 PM   #517
sduckworth13
Re: Project 69SWB
Jimmy did you go to a one wire alternator? Is that why you had to install the diode?
Scott
Old 05-15-2015, 01:30 PM   #518
Low Elco
Re: Project 69SWB
Congrats! Good lookin' stuff!
Low Elco is offline   Reply With Quote
Old 05-15-2015, 01:55 PM   #519
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Yes!
Thanks!
Thanks, still need to get it all tidied up and correctly timed... Not to mention some mufflage!
It's the same alternator that was on it when I tore it all down.. Internal regulator, it's wired just like this pic, Originally these trucks had were externally regulated. I'm not sure what's different between the stock harness and the Painless Harness, but they mention in the paperwork that in some instances the truck will not shut off and that diode is needed on the 914 White wire. Truck wouldn't shut off so I just followed the directions. :-)
Here's what it said in the instructions:
NOTE: Under some circumstances, the connection to the Alternator will not allow the Engine to shut off If this occurs, a diode will have to be installed inline on wire # 914. This will prevent alternator feedback into the ignition system & allow the Engine to shut down, The RADIO SHACK part number for this Diode is 276-1661 It is to be installed with the striped end towards the alternator.
Thanks!
Jimmy
.69SWB Build.
Old 05-15-2015, 02:24 PM   #520
mcbassin
Still Learning
mcbassin's Avatar
Re: Project 69SWB
Way to go Jimmy! Congrats on getting her running!
mcbassin is offline   Reply With Quote
Old 05-15-2015, 03:21 PM   #521
sduckworth13
Re: Project 69SWB
Thanks Jimmy
Scott
Old 07-12-2015, 06:24 PM   #522
jmking9
jmking9's Avatar
Re: Project 69SWB
How's it coming along?
1970 SWB Build
Old 07-20-2015, 11:09 AM   #523
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Trucks on hold, been saving for vacation so the TruckBucks have been depleted.
However, I have the brake lines all ran, bled, and working good now. Next up after we get back from vacation and I save a few truck bucks, is a battery, sway bars, bed wood and trim, run the gas line to the rear tank, block it all out and paint. That's all gonna take me all winter and part of spring to save money for and actually do the work. :-) Taking longer than i want, but I don't want to build my truck on credit.
Jimmy
.69SWB Build.
Old 07-20-2015, 01:41 PM   #524
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
Re: Project 69SWB
Not sure if I missed it or not, but what did you use for the ac components?
FRANKENSTEINC10 is offline   Reply With Quote
Old 07-21-2015, 10:15 AM   #525
jmking9
jmking9's Avatar
Re: Project 69SWB
Come on man, spending money you don't have is the American way!
But seriously, I'm glad you're still at it. It doesn't sound like you're that far away(other than that part about blocking it out) It's going to be a KILLER ride when you get it finished. Can't wait to see it! Keep us posted
1970 SWB Build
1969, black, custom 10, fleetside, shortbed
