Old 05-02-2019, 03:38 PM   #501
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Columbus..the 1957 IH 4x4..
thanks John!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-12-2019, 09:51 AM   #502
8man
Just went through this thread and wow, very nice. Looking forward to pictures of your parents when they get to drive it.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 05-12-2019, 03:41 PM   #503
mongocanfly
Post Whore
Thanks 8man!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-13-2019, 02:26 PM   #504
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I learned something about axle tubes. I never realized that they move with welding.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 05-13-2019, 11:05 PM   #505
mongocanfly
Post Whore
Yeah Dale...heat distortion from welding will really make the metal change shapes...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-18-2019, 04:39 PM   #506
mongocanfly
Post Whore
I'm still making baby steps...work keeps getting in my way though...
Finally decided to quit trying to make some fancy looking coil mount brackets and just make something that would work....where they are and with everything assembled they'll be hard to see anyway...if they are a eyesore I'll make some covers for them...
Heres the brackets I made...they bolt to the back of the heads
And a pic of them mounted..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-18-2019, 04:46 PM   #507
mongocanfly
Post Whore
Side job on my hydroboost install was I needed a extra return port into the tank for it...I've seen where some just tee the lines together but have also heard some say it cavitates sometimes...
So I machined a nipple for the return...
Cleaned up a spot on the tank and welded it on..
Then i stuck some magnets in the tank around where the hole would be and drilled on into the tank...I think it'll work
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-18-2019, 04:50 PM   #508
mongocanfly
Post Whore
Also getting close to finalizing the brackets for the hydraulic clutch master...its still in r&d mode...turns out a 1:1 ratio was gonna work ok on the bellcrank..
I'll clean up and shape the brackets some..I had to order a banjo fitting to go on the reservoir end ..a 90deg -3an hose stuck up a little to high and was to close to the floorboard..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-18-2019, 10:29 PM   #509
72 tigger
72 tigger's Avatar
Making progress- keep it up
72 tigger is offline   Reply With Quote
Old 05-18-2019, 11:14 PM   #510
Ol Blue K20
Nice work and progress
Dale
Old 05-18-2019, 11:35 PM   #511
mongocanfly
Post Whore
thanks tigger and Dale
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-20-2019, 11:22 PM   #512
mongocanfly
Post Whore
Spent what little time I had today working on the plug wires...
I must say this just reaffirms the fact that I HATE wiring...It took most of the afternoon just to do one side.
I'm using Taylors build your own wiring kit...the kit I have has the 10mm wires..
As I expected nothing goes as planned..their crimp tool sucks...it won't crimp the terminal properly...channel locks works better than the tool...the coil boots will test your patience...they dont slide easily on the wire jacket....even with the dielectric grease, wd40,hot water and youtube.....its a good thing I had extra boots..I had to cut 2 boots off the wire and redo just on the drivers side...they would stick to the wire just like they were glued on..and always in the wrong spot...but I got this side done..
I started on the pass side but needed to dimple the header tube on the front 2 cyl..the plug boots were just to close for comfort....and of course half way thru that I ran out of O2 for the torch...
Oh well..I needed to cool down after doing the drivers side anyway...
Drivers side done ...and the sucky little crimper...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-21-2019, 12:18 AM   #513
Ol Blue K20
May have been a pain but they is purdy....
Dale
Old 05-21-2019, 12:44 AM   #514
mongocanfly
Post Whore
Thanks Dale!....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-21-2019, 08:21 AM   #515
8man
That does look nice.
8man-aka Robert
Old 05-21-2019, 08:54 AM   #516
7dee2
7dee2's Avatar
Hey Greg, did you try any Windex to move those boots around?
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 05-21-2019, 11:41 AM   #517
mongocanfly
Post Whore
thanks 8man!!..
no 72...I didn't try windex...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-21-2019, 03:58 PM   #518
Advanced Design
Advanced Design's Avatar
Nice looking mounts and wire routing!
Advanced Design is offline   Reply With Quote
Old 05-21-2019, 08:38 PM   #519
mongocanfly
Post Whore
Thanks Doug!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-21-2019, 10:56 PM   #520
mongocanfly
Post Whore
Well I got the pass side done...for some reason it went a little easier than the 1st 4 did....
I'm gonna straighten the wiring up but 1st I've got to get some more wire separator clamps...thatll make it look some better...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-21-2019, 11:02 PM   #521
mongocanfly
Post Whore
I did some measuring and found what I think could have been some of the issues I was having...there is about .050 difference in the od of the wires...that makes it harder in the stripper/clamp and getting it in the plug boot...not to mention with a od range of .420-.470 and trying to get it in a .200 hole in the boot..
Like trying to cram 10lbs of crap in a 2lb sack...
They sell the same boot for 10mm and 8mm wires...if I'd gone with 8mm it probably would have went much smoother...I did try the windex..it helped in the stripper part but not on the boot install...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-22-2019, 11:12 AM   #522
Dads79GMC
Dads79GMC's Avatar
All sounds too familiar. Great work!
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 05-23-2019, 05:10 PM   #523
mongocanfly
Post Whore
Mike,i take it you had fun with this before?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-26-2019, 10:10 AM   #524
Dads79GMC
Dads79GMC's Avatar
Yep!
Old 05-28-2019, 04:52 PM   #525
mongocanfly
Post Whore
Got the clutch master mount and bell crank done...small progression but at least moving forward...
Mongo...aka Greg
RIP Dad
RIP Jesse
