Old 05-26-2020, 12:37 PM   #551
6t9camaro
6t9camaro's Avatar
Re: 67 C10 "Green Gobblin" straight from the field!
Originally Posted by KMC3420 View Post
Excellent job on the bedsides. That did look tedious for sure. All in the name of keeping the originality.
Originally Posted by Snake72 View Post
Your blending skills are bonkers. Very nice job!
Thanks !
Build
67 Green Gobblin
http://67-72chevytrucks.com/vboard/s...d.php?t=688755
6t9camaro is offline   Reply With Quote
Old 05-26-2020, 12:56 PM   #552
6t9camaro
6t9camaro's Avatar
Made some great progress on the truck the past few days! Started mocking up the bedsides and modifying the steel bed floor to fit. I quickly realized that i would rather have a wood floor for the look I want so like usual the plans changed again! Heres a few pics of the box sides finally mocked up and steel floor mock up. (Plus my helper for the day)
Build
67 Green Gobblin
Old 05-26-2020, 01:00 PM   #553
6t9camaro
6t9camaro's Avatar
So after scrapping the steel bed idea i realized i needed to remake the front and rear bed supports and plan out the raised bed floor.
Build
67 Green Gobblin
Old 05-26-2020, 01:05 PM   #554
6t9camaro
6t9camaro's Avatar
Building the rear support was tricky as I needed to taper the ends to fit into the odd shape of the box sides.
Build
67 Green Gobblin
Old 05-26-2020, 01:09 PM   #555
6t9camaro
6t9camaro's Avatar
Front wasn't as bad but I did build in a little adjustment so I can level and set the box height. The last pic you can see I lined up the body line with my good ol laser level.
Build
67 Green Gobblin
Old 05-29-2020, 08:39 AM   #556
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice work on those bed supports. I like the idea of using tubing.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-01-2020, 09:56 AM   #557
cornerstone
cornerstone's Avatar
You've got some excellent problem solving skills. Very nice work.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 06-01-2020, 12:08 PM   #558
6t9camaro
6t9camaro's Avatar
Thanks! Been a busy few days working on the truck! I’ve got some updates coming as soon as I can sit down at the computer.
Old 06-04-2020, 01:25 PM   #559
6t9camaro
6t9camaro's Avatar
More progress on the box! Trying to line up all gaps and getting everything to fit as it should before I tackle the raised bed floor.
Build
67 Green Gobblin
Old 06-04-2020, 01:32 PM   #560
6t9camaro
6t9camaro's Avatar
Nice and low! I also decided to start fitting the side trim. I had to cut down the long box pieces and after that they fit pretty good. lol
Build
67 Green Gobblin
Old 06-08-2020, 04:11 AM   #561
Average Joe
Average Joe's Avatar
Looks great! Getting a lot closer.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 06-08-2020, 06:53 PM   #562
6t9camaro
6t9camaro's Avatar
Thanks! Slowly but it's starting to come together!
Build
67 Green Gobblin
Old 06-08-2020, 07:12 PM   #563
6t9camaro
6t9camaro's Avatar
Ok I made some huge progress on the truck the past few days! I managed to get the raised floor framed and mocked up. Set and located all the rivets to the inner box sides so most of the hard measurements are done!
Build
67 Green Gobblin
Old 06-08-2020, 07:16 PM   #564
6t9camaro
6t9camaro's Avatar
Once the framing was done I started on the exhaust. I didn't see the need to get real crazy with the pipes I figured the less bends the better! I also put a bunch of v-band clamps in to make it easy to take in and out.
Build
67 Green Gobblin
Old 06-08-2020, 07:22 PM   #565
6t9camaro
6t9camaro's Avatar
Took half it apart to finish some of the welds and thats it for now! Oh and I also picked out the wood (Douglas fur) since I like the wood grain and how it responds to stains as well as the strength of it.
Build
67 Green Gobblin
Old 06-11-2020, 04:55 PM   #566
1stchevy
1stchevy's Avatar
Nice progress and great work
1stchevy is offline   Reply With Quote
Old 07-01-2020, 03:39 AM   #567
ilikethewoods
ilikethewoods's Avatar
The best build on this site!
ilikethewoods is offline   Reply With Quote
Old 07-01-2020, 07:48 PM   #568
bodydropped68
bodydropped68's Avatar
Yes
bodydropped68 is offline   Reply With Quote
Old 07-05-2020, 11:06 PM   #569
6t9camaro
6t9camaro's Avatar
Originally Posted by bodydropped68 View Post
Yes
Wow thanks guys! Had a busy weekend on the truck so more updates coming soon! Just gotta go through some pics!
Build
67 Green Gobblin
Old 07-09-2020, 10:18 AM   #570
6t9camaro
6t9camaro's Avatar
Progress! I've put quite a bit of time into the raised bed floor and getting everything to fit and work properly the last few weeks so heres some updates. I laid the wood in to get a idea of the space below and everything seemed to have a pretty decent air gap around it ( Exhaust, Compressors). I also decided to slide a pipe into the front bed support to straighten it and also add some strength incase theres ever anything in the box that slides to the cab!
Build
67 Green Gobblin
Old 07-09-2020, 10:24 AM   #571
6t9camaro
6t9camaro's Avatar
Tore everything down after that to finish up the bed floor and start to figure out and build the Center section that will be hinged and lift up on gas struts. You might also notice the front box support i decided to put a step notch into it incase of future driveshaft clearance?
Build
67 Green Gobblin
Old 07-09-2020, 10:26 AM   #572
6t9camaro
6t9camaro's Avatar
Back together again!
Build
67 Green Gobblin
Old 07-09-2020, 10:32 AM   #573
6t9camaro
6t9camaro's Avatar
I decided to start fitting the rear bumper and building the brackets to get it sitting where it needs to be. In the process I figured it was a good time to relocate the batteries to the rear. I've already been having a heck of a time dealing with them just behind the cab!
Build
67 Green Gobblin
Old 07-09-2020, 10:36 AM   #574
6t9camaro
6t9camaro's Avatar
I also decided it was a good time to put in a hidden hitch!
I don't think i will ever tow anything but hey you never know so i cut up some plates and reinforcement brackets and got that all finished up!
Build
67 Green Gobblin
Old 07-09-2020, 10:38 AM   #575
6t9camaro
6t9camaro's Avatar
More Hitch
Build
67 Green Gobblin
