Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 02-11-2012, 07:45 PM   #576
kev2809
low n' slo
kev2809's Avatar
Re: Project 67 DRGNWGN - 67 Burban!!
heres what i been working on last night and a few hours this morning...
still have to weld some rods to the bottom and top of the body, it has a weird twist in it. you can see it here...
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-11-2012, 07:46 PM   #577
kev2809
low n' slo
kev2809's Avatar
didnt really take any before pics but i had these saved..
probably get back on it tomorrow and finish it up, its actually turning out nice!
-_--_--_ _________
Old 02-11-2012, 08:10 PM   #578
VA72C10
VA72C10
VA72C10's Avatar
Nice progress! Getting the gaps right makes a big difference down the road when it's all painted!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-12-2012, 03:59 AM   #579
maxxxy
maxxxy's Avatar
How are you what are you using to fill those gaps?
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 02-12-2012, 11:42 AM   #580
kev2809
low n' slo
kev2809's Avatar
thanks, i had no choice with this one! lol
the other gaps are fine...maybe i will have to fix the door to rocker gaps, but thats a lot easier!
im welding tig rods to the side of the door...there is a thread on it in the paint and body section..
http://www.67-72chevytrucks.com/vboa...d.php?t=497761
-_--_--_ _________
Old 02-17-2012, 08:01 PM   #581
kev2809
low n' slo
kev2809's Avatar
almost finished up the gap...just need a little more grinding to even up the gap..
-_--_--_ _________
Old 02-17-2012, 08:05 PM   #582
kev2809
low n' slo
kev2809's Avatar
looks a lot better than that ugly twist that was in there...
i also got a little bored last night of fixing the gap, so i went to put my new ubolt in and also the panhard bar spacer from cpp...and i noticed something strange..
DRIVER SIDE
PASSENGER SIDE
i believe my notch was not welded in centered up...i took these pics of some mounting holes next to the notch and you can see the space between the holes and notch are different on both sides...
is this going to pose a problem? i really dont want to pay someone to cut this notch out and move it....it seems like it only touches when its completely aired out...
-_--_--_ _________
Old 02-17-2012, 11:31 PM   #583
bdydrppedc10
huh wow awesome build do you do your own welding??? If so cut the back half right off the truck and build a 2x4 box tubing chassis. Also weld in a nice sexy reliable 4 link for less then 300 bucks. Then in the new frame rails weld up a cross member combo to hold the gas tank, and all air ride components. Instal a sexy ass removable floor. Put 90degree angle steel and weld to the inside wall of truck as it was the the of the floor and put a couple supports and voila a raised bed floor skeleton in the drgnwgn and to make it even more slick install a tottally removable or lift up wood bed floor inside and then all components for air ride,and fuel are accessible......
not trying to take over just putting my 50 cents in the cd player lol
bdydrppedc10 is offline   Reply With Quote
Old 02-18-2012, 12:14 AM   #584
kev2809
low n' slo
kev2809's Avatar
lol
thanks for the input. no, i dont do my own welding on the framework. i really would like to try a 4 link, but its really not in the budget. maybe afteri get it on the road and enjoy the truck enough to know i would rather have a 4 link lol. i attempted to weld my brackets that are on the axle now and bridge and im not comfortable with how they turned out...so i will have that redone before i get it on the road.
-_--_--_ _________
Old 02-18-2012, 01:59 AM   #585
Slick67
Sofa King Crazy!!
Slick67's Avatar
Nice job on the gaps Kev. That sux when you find an issue like the c-notches, it always seems to pop up when progress is being made. Hope you can make it to the Lonestart Showdown, it's a long way for ya but would be well worth it!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 02-20-2012, 12:20 AM   #586
texastrendz
DRIVER SIDE
PASSENGER SIDE
Maybe you can do what I did, it will effect drive line length and what ever else is tied to it. Made them out of some aluminum i had laying around. It will also help center the rear wheels.
texastrendz is offline   Reply With Quote
Old 02-20-2012, 09:09 AM   #587
bdydrppedc10
what that is a good idea but where do the rear wheels sit in wheel well when layed out.(If it is pushed back then i would say that is my least favorite look on an air ride truck.)
Old 02-20-2012, 11:30 AM   #588
kev2809
low n' slo
kev2809's Avatar
mine are pulled more toward the front of the truck, so these would actually help both situations. thanks for the idea!
-_--_--_ _________
Old 02-20-2012, 11:53 AM   #589
lolife99
67-72 parts collector,…
lolife99's Avatar
Is the rearend centered in the frame?
Adjustable track bar?
Did you also take measurements when it's air'd up?
Cycle it from all the way up, to down,... and see how much the rearend moves left-to-right.
It looks like the step notch needs to move forward,... but as long as it airs out all the way,... I guess it doesn't matter.
Keith
Convert to disc brakes.
Old 02-20-2012, 04:24 PM   #590
1sik7t2
dave
1sik7t2's Avatar
ditto x3
Originally Posted by Newtz67 View Post
Digging it. Looks awesome!
check out my build "DIRTY BURB"
1sik7t2 is offline   Reply With Quote
Old 02-20-2012, 05:41 PM   #591
kev2809
low n' slo
kev2809's Avatar
you know, i havent realy checked any of those! the only reason i noticed one side was off was when i replaced that passenger side ubolt last i noticed that side was closer to touching. i had bought it from o reilly's, so the thickness wasnt the same as the driver side. so i figured if i bought the same one on both sides, it would straighten up. but it actually was more noticeable after i put the right size ubolt in.
i do have a double adjustable panhard bar. i ordered the short one...and actually cut it and welded a pipe in the middle to extend it to where i need it, but i do still some adjustability i can still play with.
ya, he definitely didnt weld the notch in the right spot...
-_--_--_ _________
Old 02-29-2012, 02:33 AM   #592
laid67
laid67's Avatar
Looks good man, ive been following for a while. makes me want to go find a burb... haha
laid67 is offline   Reply With Quote
Old 02-29-2012, 12:09 PM   #593
kev2809
low n' slo
kev2809's Avatar
lol..thanks for checking it out.
waiting on a friend of mine to let me use his stud gun and dent puller so i can start some body work...
-_--_--_ _________
Old 03-02-2012, 05:02 PM   #594
bcubed
bcubed's Avatar
Nice project, it keeps looking better and better!
2000 Bagged Silverado
1978 Chevy Malibu
1955 Apache Stepside (someday)
bcubed is offline   Reply With Quote
Old 03-04-2012, 10:48 PM   #595
kev2809
low n' slo
kev2809's Avatar
well, i cant stick to one thing.
tore my column apart for paint, then decided i might as well take off the pump for paint...then why not the center link...and while im at it replace the idler arm and paint the idler arm mount. man that always happens.....
and new grade 8 bolts for the pump..
-_--_--_ _________
Old 03-04-2012, 11:23 PM   #596
Slick67
Sofa King Crazy!!
Slick67's Avatar
Always a good update Kev! I see the snowball effect happening just like it did with me......and most of us for that matter. "Think I'll paint this, and maybe that, and that too, oh yeah, this would look better painted." Dangit, always happens.
Old 03-04-2012, 11:33 PM   #597
kev2809
low n' slo
kev2809's Avatar
lol..always. i wasnt even gonna tear down the column..i hope i dont forget how to put it back together lol
-_--_--_ _________
Old 03-09-2012, 02:59 PM   #598
Bud1300
Bud1300's Avatar
It really dont matter the order you attack the build I am the same my A.D.D dont help at all but in the end it is getting done. I will work on the body panels for a while and next I am on the wiring but at least I am working on it and at some time it will be done. Keep on and thanks for the info I use your site alot for inspiration.
Bud1300 is offline   Reply With Quote
Old 03-09-2012, 05:31 PM   #599
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
WoW!
Nice progress. Keep it up!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 03-09-2012, 06:10 PM   #600
lyrikz
PITbut
lyrikz's Avatar
HOw did i miss this build. That looks awesome.
On the black you put on the firewall, it looks like you have oil or water in the line somewhere. The red came out great.. One question i had was why you dont use paint reducer. Why the mineral spirits or thinner???
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
