Old 08-27-2023, 11:50 PM   #576
Jason 56
Re: My 56 build
Originally Posted by 57FleetsideC4 View Post
So on your bed wood did you use an oil based stain then automotive urethane clear?
No oil, I’m actually using dye and mixing my own stain. All from Amazon. To get the color change effect I’m first using blue mixed in water. That gets soaked into the wood. I apply it with a large oral syringe and spread it around with rubber gloves. After that dries I apply a quick coat of brown that’s mixed In lacquer thinner. It’s applied with a rag. The quick drying lacquer thinner keeps the stain on the surface. Dries, then sanded with 400 until I get the look I like. Then 2 coats of automotive urethane. Let dry overnight. Sand smooth and apply 2 more coats. I experimented last winter and perfected the process.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 08-28-2023, 09:02 AM   #577
57FleetsideC4
Re: My 56 build
Thank You, I used some minwax stain so will see what happens when I clear it. I am trying to keep this project on the simple side plus I am not experienced with this. Thank you for the rundown on what you did. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 09-15-2023, 10:59 PM   #578
Jason 56
Re: My 56 build
Last of the painting is done! Wheels look good
Old 09-15-2023, 11:09 PM   #579
Jason 56
Re: My 56 build
As of today I’m officially done with spraying paint. I put the last of my raptor bed liner on. So I’m ready for cold weather. Now the assembly begins. I’m looking forward to that process.
Old 09-16-2023, 07:51 AM   #580
57FleetsideC4
Re: My 56 build
Looking Great!! I am right behind you on my build. Doing the same thing with the raptor liner. Enjoy the rest of the build...The dirty work is over. Steve
Old 09-16-2023, 12:48 PM   #581
Jason 56
Re: My 56 build
I’ve been following. You’re making good progress. It’s tough painting in the garage this far north. I only have about 5 months a year
Old 12-02-2023, 09:35 AM   #582
Jason 56
Re: My 56 build
After taking a couple months off I’m back at it. Not much to show. Just color sanding as I assemble. I put the drivetrain back in. I’m not going to tear into the engine and change the lifters. At this point I just want to get it together! The box is together and I finished the inside of the cab yesterday. Here’s a few pictures.
Old 12-02-2023, 10:15 AM   #583
57FleetsideC4
Re: My 56 build
Looks Great. Making great progress. Steve
Old 12-31-2023, 10:52 AM   #584
Jason 56
Re: My 56 build
Some progress to report. Front fender are cut, buffed and installed. Interior is also cut, buffed and the steering column is in. Just finished some sound deadening yesterday. Today I’m looking forward to assembling. No sanding or polishing today. It’s looking good, but I’m sick of sanding!
Old 12-31-2023, 11:32 AM   #585
dsraven
Re: My 56 build
looks really good. curious, what is thatbig box above the drivers front wheel, does it have clearance for the tire to go through a full suspension travel with the wheels turned to the right? looks tight in the pics but then pics can do that.
I like the color combo, looks rich.
Old 12-31-2023, 02:55 PM   #586
57FleetsideC4
Re: My 56 build
looks very nice!! Making great progress. Steve
Old 12-31-2023, 08:08 PM   #587
Tempest67
Tempest67's Avatar
Re: My 56 build
that is a beauty, keep at it
Tempest67 is offline   Reply With Quote
Old 12-31-2023, 11:06 PM   #588
Jason 56
Re: My 56 build
It’s where all the engine electronics are housed. The fuse panel bolts to the inside of the cover. All you see is the wire loom entering the fender. There’s about 8” of clearance. So no problem with the static suspension.
Old 01-01-2024, 11:57 AM   #589
dsraven
Re: My 56 build
great idea on the electrical box, thanks for the pics.
HAPPY NEW YEAR!
Old 01-01-2024, 12:07 PM   #590
dsraven
Re: My 56 build
is your fuse/relay panel in there too? good access to work on it if required?
Old 01-01-2024, 04:20 PM   #591
8man
Re: My 56 build
I just went through your build, and it is awesome. Some real thought and skill went into it. Glad I found it.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 01-02-2024, 06:20 PM   #592
8man
Re: My 56 build
Did you use the Specialty Power Windows kit? If not, which one did you use and is it working well for you?
Also, I've seen a couple of one piece window kits that have the glass with them, what kit did you use for the one piece and did a local glass company cut the window?
Thanks.
8man-aka Robert
Old 01-03-2024, 09:36 PM   #593
Kevin_C
Re: My 56 build
its really coming together. Color looks great
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 01-04-2024, 09:08 AM   #594
6DoF
6DoF's Avatar
Re: My 56 build
good lord, those colors look even better as it's going together
6DoF is offline   Reply With Quote
Old 01-10-2024, 12:23 AM   #595
Jason 56
Re: My 56 build
Thanks.
Yes they are Specialty Power Windows. Kit is from classic parts. I got my side window glass and seals from Vintage Glass: Balls Rod and Kustom.
Old 01-10-2024, 12:49 AM   #596
Jason 56
Re: My 56 build
Yes, it’s in there too. There’s a cover to the box. The panel bolts to the inside of the cover. So the panel can be pulled out. You can see the 4 screw heads in the picture. It’s snug, but well ventilated.
Old 01-10-2024, 01:06 AM   #597
Jason 56
Re: My 56 build
Funny story… I was reading another post on the forum. It was mentioned to make sure your windshield fits if you are replacing the upper eyebrow area over the window. That was about a month ago. So I’ve been sweating a little. I’m nearly ready to install my new windshield in its new hole that hasn’t been fitted. After some thought I decided to install the old seal on the windshield and cut both the inner and outer lip seals off. Just left me with the windshield as it should sit without the rubber pulling on it. With much relief everything fit. soon to be installed permanently!
Old 01-10-2024, 01:13 AM   #598
Jason 56
Re: My 56 build
Otherwise I’ve been wiring for about 2 weeks now. Getting cliose to finishing that. Airbox is also installed.
Old 01-10-2024, 09:53 AM   #599
my56chevytruck
my56chevytruck's Avatar
Re: My 56 build
great job Jason, all your pics show great work, detail and perfection. Again, great job.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 01-28-2024, 05:05 PM   #600
Jason 56
Re: My 56 build
Radiator and fan are installed. Finished the a/c system. Dryer is installed and it’s ready for a charge.
