#6076 | |
Re: What did you do to your truck today!
![]() ![]() ![]() And for sh!ts and giggles Before: ![]() After: ![]() Posted via Mobile Device |
#6077 |
I started putting the motor back in
69 Chevy 4x4 383 Power ![]() |
#6078 |
Installed remflex header gaskets. These things are sweet! First set of header gaskets that haves actually worked! Love them, truck sounds awesome without that annoying exhaust tick.
Here is a link if ya want more info: http://catalog.remflex.com/ Posted via Mobile Device
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130 Club longbed ...cause girls like'em long!!!!! |
#6079 |
put my new door panels on. I have to say I had to trim the holes out bigger where the armrest goes on. I ordered lmc door panels don't know if any others line up better but you cant see where I had to make the hole bigger the armrest covers it so I guess its ok.
1972 Chevy C20 Pickup 1974 Plymouth Roadrunner 2009 GMC Sierra 2011 Chevy Equinox |
#6080 | |
![]() Join Date: Mar 2012
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
#6081 |
Been collecting parts... STILL waiting for my air bags and CPP brakes to arrive. Brutal. Got my GMC emblems installed, and got all the side trim cleaned up and repainted. I might install it this week. I bought all my 4 guage battery cable for the compressors, 80amp fuse block, continuous duty soliniod to control the compressor power. I made up some cables tonight with the 4 guage and copper ring terminals from the battery to the fuse and made a new 4 guage ground strap to go from the battery to ground. Just been slowly plugging away at it.
#6082 | |
Thx Posted via Mobile Device
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
#6083 |
Mister-B
What type of paint did you use?
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel |
#6084 |
Pulled the upper steering column apart to determine why shifter is sloppy. Didn't find anything obviously wrong with it other than needed a good cleaning and lubrication. Now I can pull the shifter inward, but it still moves from park to drive without any stops. Now to dismantle, inspect and lubricate the lower section and linkage.
![]() ![]() Posted via Mobile Device
1970 C10 Short Stepper with 71/72 front clip. |
#6085 |
#6086 |
Thanks...just looking to do mine and wanted some ideas..yours looks great
#6087 |
#6088 |
M17 : thank you ~ I'm not always sure if My Tech Help is appreciated or not .
It sounds to me like you have your fans set up and working O.K. , I wasn't sure before . Always remember : your coolant should run as close to boiling temperture as possible for maximum engine life , power and fuel economy . Dennis : SWEET ! I wish you were closer , I really want to find an honest & reliable Body Shop to rebuild my '69 Stepper . RE Driveshafts : I'd pass on that hybrid U-Joint , take anu old drive shaft(s) with the correct ends and measure *exatly* how long you need it then hie yourself to the nearest Big Rig Repair Shop and ask who does thier drive shaft works ~ take it there as they'll know and for $150 (assuming they're honest) you'll get your drive shaft back cut & measured , balanced with two new greasable U-Joints , ready to pop in and go.... no hassle .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#6089 | |
Posted via Mobile Device Posted via Mobile Device |
#6090 | |
Nice truck and was going to ask year/ model but didnt even bother to look at your handle..dohh! Working on mine to try and get a similar clean look but it aint easy..... kkaa Last edited by kkaa607; 02-19-2013 at 01:22 PM. |
#6091 |
Put on my new old 1971 Maryland State tags. Thanks Maryland.
#6092 |
Tires came in today !
1970 Chevy swb, project UGHH! ![]() 1987 Grand National http://s168.photobucket.com/albums/u.../1970%20Chevy/ |
#6093 |
Put the new bearings and brushes in my alternator, funny enough it went back together,
68 ![]() My other ride ,,, 07 Streetglide.. |
#6094 |
#6095 |
RAT1968 '68 Cab/'71 Parts
Didn't get much done today.
Or tonight.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#6096 |
Did nothing on my truck today, but ordered a Comp cam 270H for my 454 to go with the Rpm intake and roller rockers I just got. Might as well go all out when it is apart and port the 781 cyl heads too while I am in there, work and more work. Ported 1 of a set of Dart Iron Eagle New cyl. heads today and reassembled, one more to go.
#6097 |
i finally got my engine back from the machine shop . i put it together and painted it. it is a 1993 chevy 5.7. my original engine had a cracked block in two spots.
#6098 |
I put a tarp on mine, lol. We got alot of rain today right after I got off work. It's still going.
Dan 1968 Longbed Stepside C10 |
#6099 | |
#6100 | |
