Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-28-2011, 11:33 AM   #601
Gene
Gene's Avatar
Re: Project - '69 4x4 named "Patches"
Im on the fence on wether or not to stick with factory air or go with aftermarket. I have most of my factory stuff, but then again theres alot that needs replacement. Thats a cool looking setup. I'd like to find one with the capability to work with the factory controls but havent seen any yet that do?
Gene is offline   Reply With Quote
Old 06-28-2011, 12:32 PM   #602
sdailey
The Few, The Proud
sdailey's Avatar
Check out Classic Air's website. I know their system will work with factory controls.
http://www.classicautoair.com/
Shannon
sdailey is offline   Reply With Quote
Old 06-28-2011, 08:59 PM   #603
jaros44sr
jaros44sr's Avatar
well done Shannon, always enjoy reading about your progress...nice controller
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-28-2011, 10:41 PM   #604
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Nice work Shannon, your doing an awesome job!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 06-29-2011, 08:40 AM   #605
sdailey
The Few, The Proud
sdailey's Avatar
Thanks fellas.
Shannon
Old 07-01-2011, 11:51 PM   #606
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Shannon, I just finished up making one of the patches. It turned out OK. It ripped in a couple places, nothing a welder can't fix. It's a roughed out patch that needs some trimming to fit. (what do you expect with a repop) I think we can work with it. Now you get to make the next one.
Here's the steps I took.
Alan's Classic is offline   Reply With Quote
Old 07-02-2011, 12:00 AM   #607
sdailey
The Few, The Proud
sdailey's Avatar
Originally Posted by Alan's Classic View Post
Shannon, I just finished up making one of the patches. It turned out OK. It ripped in a couple places, nothing a welder can't fix. I think we can work with it. Now you get to make the next one.
Very cool indeed. It looks great bud. Thanks for what you do.
Shannon
Old 07-02-2011, 12:02 AM   #608
sdailey
The Few, The Proud
sdailey's Avatar
Wait.............what????
Shannon
Old 07-02-2011, 12:04 AM   #609
Alan's Classic
Better get it right the first time. I only have enough metal for one more.
Old 07-03-2011, 10:18 PM   #610
msgross
msgross's Avatar
Make sure you leave a drain hole, that's how they rust out in the first place...
The new cowl didn't include that part?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-04-2011, 10:38 PM   #611
sdailey
The Few, The Proud
sdailey's Avatar
There will definitely be a drain hole fabbed into both sides.
The new cowl doesn't come with the lower inner supports. So they have to be fabbed up.
Here's what the original one looked like after it came back from the blaster.
Here's a picture of the cab before it was blasted. Notice the rot in the lower cowl area. Both sides were rotted out like this. You can imagine what the inner supports looked like.
Shannon
Old 07-05-2011, 03:53 PM   #612
freakshow108
freakshow108's Avatar
Thanks for the progress report/pics, you motivated me to get off my duff! Love seeing progress.
freakshow108 is offline   Reply With Quote
Old 09-11-2011, 09:29 PM   #613
sdailey
The Few, The Proud
sdailey's Avatar
I guess I need to knock the dust off of this thread.
Not much progress as of late to report. Between work and the summer heat I haven't had much of an urge to get off the couch the past few months.
Boredom finally set in this weekend, so I decided to get in the basement and rearrange truck parts, while doing that I decided to dig out the parts for my bed and try to assemble it. Alan happened to come over at the right time and he helped me put it together. The Goodmark bedsides have never been out of the box, so I was curious to see what they looked like. Both sides are really straight and looked really good for reproduction pieces, with the exception of a small dent on the driver's side tail light area (see pic below) and it looked like it was done in shipping maybe.
We mounted the new wheel wheel to the driver's bedside and installed the bedside with a couple of bolts and then mounted the Mar-K header panel (which is a real nice piece by the way). We moved to the passenger side and tried to install the bedside the same way we did with the driver's side, but as luck would have it it didn't go together as easy. Long story short I had to trim a small piece (cutting wheel thickness) of the bedfloor so the bedside would slide in the groove by the rear stake pocket. Other than that little issue everything went smooth. I dug out my tailgate and mounted it as well.
Just to recap, the entire bed was assembled with reproduction parts, with the Mar-K header panel being the only part being made in the US. With that being said though I was really surprised at how good everything lined up and how easy it all went together.
I took the rollers off the rear and mounted up the 33's just to see how they looked with the bed on. I'm still undecided about how they look. I'll have to wait to get the cab and front end mounted and let the springs settle before I fully form an opinion about the wheel and tire combo.
So without further delay here are a few pics. Enjoy!
Thanks again to Alan for the help and motivating me to get off my rear end.
Stay tuned for future updates.
Shannon
Old 09-11-2011, 09:43 PM   #614
VA72C10
VA72C10
VA72C10's Avatar
Looking good!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-11-2011, 10:40 PM   #615
msgross
msgross's Avatar
nice, much cleaner than mine!!!
The Garage:
Old 09-12-2011, 09:37 AM   #616
sdailey
The Few, The Proud
sdailey's Avatar
Originally Posted by VA72C10 View Post
Looking good!
Thanks Jonathon.
Thanks Mike. Any time in the schedule for yours in the near future?
Going back through my build I discovered that I've had the bedsides right at 3years now. Boy I'm slacking.
Shannon
Old 09-12-2011, 08:51 PM   #617
Alan's Classic
Heidi Ho slacker neighbor.............Looks good. :metal;
Old 09-13-2011, 07:58 AM   #618
my67chevytruck
Under Construction
my67chevytruck's Avatar
Nice Work Shannon and Alan... I need a neighbor like Alan.. any houses for sale around yours... lol...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 09-13-2011, 08:18 AM   #619
sdailey
The Few, The Proud
sdailey's Avatar
no movement right now, almost finished my man cave basement though... I flipped through some pictures and found this one... second pic is my son now!
Where does the time go? Our little girl was 9 months old when I bought my truck now she's turning 5 on Thursday.
As always, thanks for the help.
Hey Heath. Long time no see. Where have you been hiding?
There's a few for sale around the way. I'm sure we could fit you in somewhere.
Shannon
Old 09-13-2011, 09:19 AM   #620
my67chevytruck
Under Construction
works been hectic, which is a good thing i guess..... I have not done anything to the trucks, so i stay away so i wont get depressed... lol.... I peruse off and on, but have not posted in awhile. Hope all is well... Keep Alan in check...
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 09-14-2011, 12:13 PM   #621
65Custom
Really looking good
This is some good inspiration here to see it all starting to come together
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 09-21-2011, 12:36 AM   #622
Gene
Gene's Avatar
Really looking nice!
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 09-21-2011, 09:11 AM   #623
4dranch
Shloooooong bed member #2
4dranch's Avatar
Looks real slick Shannon. nice job
4dranch is offline   Reply With Quote
Old 09-21-2011, 02:42 PM   #624
sdailey
The Few, The Proud
sdailey's Avatar
Thanks guys.
Shannon
Old 09-21-2011, 03:05 PM   #625
Gene
Gene's Avatar
I've had mine on the road for a couple of days now. Nothing like drivin this old truck down the highway.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
