12-09-2022, 02:23 AM | #626 | |
56 - autocross
Re: Yet another GMC build
12-09-2022, 04:26 AM | #627 |
I think it would look ok. I don’t know if you could absolutely eliminate orange peel. Maybe reduce the final coat so it lays down real wet? Small parts you don’t really notice it but on something like a big flat door I think orange peel might be inevitable. The best plan might include wet sanding to 2000 grit to get it real flat, then going over the panels with 3M Trizact pads to 3000 or 5000 grit to bring back the semi gloss sheen. Just don’t know of any other way to get a whole truck perfect. But that’s just me. I’ve had real good luck with my Eastwood paint gun set but I’m still pretty green with paint. This is the only car I’ve ever painted so I’m sure a body shop veteran might have a different opinion.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
12-09-2022, 10:27 AM | #628 |
Everything is looking really nice. I like the door panels. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
12-09-2022, 11:06 AM | #629 | |
01-20-2023, 06:40 PM | #630 |
2 coats Raptor bed liner with a fine foam roller, one coat Summit satin gloss urethane.
I tried to cover the dash in the Allsport viny. My vinyl dash experiment ended horribly. If I use this method i get the texture and a color matching my interior but no 5 hours of masking to respray the dash. I think I’m gonna go for it.
01-21-2023, 02:40 PM | #631 | |
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
01-22-2023, 01:00 PM | #632 |
Painting with the roller was definitely easier. I kind of like the texture. It reminds me of the paint on old refrigerators. I would rather have sprayed it when it was masked the first time around, hard to make the finish even with a roller. I can guarantee I’ll be spraying the bed when I get there. In the mean time I can start assembling the dash.
01-22-2023, 01:07 PM | #633 |
Since I’m covering the raptor with semi gloss 2k I won’t truly know. It looked black before the paint but more black after. The problem is the sheen. Raptor was flatter by far, and I think that could make it look more gray. I know you can roll latex house paint in 3 sheens side by side and it will look like completely different colors. I’ll post a pic of raptor only for reference. I coated it so all my colors matched.
02-07-2023, 04:28 PM | #634 |
Old Air unit wired, ac and defrost ducts ran, and control panel installed.
02-08-2023, 02:10 PM | #635 |
that finish came out great!
02-12-2023, 02:40 PM | #636 |
Built a channel to hide wiring, then mounted the Holley display screen on a swivel so it’s easier to read looking down from the driver seat.
02-20-2023, 05:28 AM | #637 |
Got the new carpet cut and fitted. I just need to bind the edges. And buy another yard. I didn’t have enough to cover the firewall or make floor mats.
02-20-2023, 10:52 AM | #638 |
Very nice!
02-20-2023, 07:53 PM | #639 |
Coming along nicely!! Steve
02-22-2023, 07:28 PM | #640 |
Thanks, guys! Edge binding the first half of the hump cover.
02-25-2023, 07:09 PM | #641 |
Still need to rebuild front kick panels, paint the column, and install seats. But interior coming together quick now.
02-25-2023, 07:16 PM | #642 |
looks awesome. do you use an underpad beneath the carpet?
02-25-2023, 08:19 PM | #643 |
Definitely. I sprayed lizard skin, glued down some thermal insulation, a layer of jute padding, then carpet. And I chose to make carpet that rolls over the step. I’ll take as much heat and sound barrier as I can get!
02-26-2023, 11:27 AM | #644 |
Looks really good!
02-27-2023, 09:49 AM | #645 |
just a thought, a few snaps in the corners would keep things stuck down, like in the step wells where the carpets rolls over the edge and on the carpet corners. velcro works too.
02-27-2023, 04:47 PM | #646 |
Was planning a dollop of adhesive on each corner and using a big magnet to hold til it dries. I used Weldwood landau glue on the footwells and steps but the heat barrier doesn’t extend to the very corners. I thought the binding would pucker there but now it just curls some instead.
Painted the column. One more thing off the list.
03-04-2023, 05:54 PM | #647 |
Getting closer every day.
03-06-2023, 03:20 PM | #648 |
Color matched Raptor liner.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 Last edited by OKGMC4; 03-11-2023 at 03:10 PM. |
03-06-2023, 05:26 PM | #649 |
Engine bay assembled
03-07-2023, 12:38 AM | #650 |
wow, thats awesome
