05-26-2020, 10:52 AM | #1 |
Re: LS swappers, post up your pics!!
The LS1 in my 53 Suburban..
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
03-28-2020, 09:48 PM | #2 |
Post Whore
bigru...might want to put this in the LS section..this section is mostly for pics
03-28-2020, 09:52 PM | #3 |
Got ya.
1965 Short Fleet http://67-72chevytrucks.com/vboard/s...d.php?t=637478 1983 Short Fleet (Under construction for my 13 year old son) 2008 GMC Denali 2012 Harley Roadglide Follow me on Instagram: Ru_django |
04-19-2020, 01:06 AM | #4 |
1972 Chevy original short fleet. Started life as 6 and 3spd.
Built up in 1995 with swapped in V8 and automatic but needed some new blood injected into it. So I stuffed a 2015 LS3 and TR6060 into it which snowballed into a pile of other stuff. Z06 14" brakes, 4" and 6" drop on Hotchkis suspension blah blah Need to get a tune on it, finish up AC and some other details but pretty much ready to hit the street. |
04-19-2020, 03:11 PM | #5 | |
04-19-2020, 11:51 PM | #6 | |
Im really not a kit guy. Just used Wilwood clutch master. 3/4" bore if I recall. Works perfect. Lining up rod to master was hardest part and that was pretty easy. Drivetrain only has 20k on it but still swapped in new clutch. Just LuK replacement. Trans crossmember is a IFS. https://www.amazon.com/Ingenuity-Fab.../dp/B074L8YYY6 Good in fact that you can center the trans plus I couldn't make it for price they charge. Little rough out of the box but very slick piece. Has dual exhaust humps too. The actual trans mount I made and it takes a TH350/400 rubber or poly mount. Factory '15 Camaro piece was too high for the floor pan. Driveshaft is modded rear a 2002-03 Excursion 4x4 with slip joint. Couldn't see spending $1k for a driveshaft. |
04-26-2020, 04:36 PM | #7 |
Irish1941
would you be so kind as to tell how the front brake system on your beautiful truck came to be? Thanks, Chip |
04-27-2020, 11:51 AM | #8 |
87 spindles with hubs and caliper mounts from Kore3.
Tobin from kore3 is a great guy and super helpful. If you want big brakes that work, you can't go wrong. http://www.kore3.com |
04-19-2020, 04:10 PM | #9 |
On my 68 C10 I used the Captian Fab clutch kit. Worked like champ.
04-27-2020, 10:52 PM | #10 |
Just added boost to my 65 and my wife’s 61 stocker
07-23-2021, 04:26 PM | #11 |
L33 engine with a non usable 4l60e in it.
It is running (great), just need transmission rebuilt and it can move under its own power. Then just a few other small things and I can be driving it on the road, been a long 18 momths from where I started.
1964 C10 Resto-mod 5.3L - L59 |
12-10-2021, 08:50 PM | #12 |
My 50 roadster pickup, 5.3 LM7 4L60E trans...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
07-27-2022, 11:31 AM | #13 |
1971 k20....
08-04-2020, 12:27 AM | #14 |
Here are few of my setup and a before and after photo.
02-22-2021, 01:40 PM | #15 |
Here's mine. Its a 5.3 bored to a 5.7, 243 Heads, and a TSP 228 Cam.
03-01-2021, 01:02 PM | #16 |
@BAM55 I love how clean that is.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
03-01-2021, 05:20 PM | #17 |
03-01-2021, 06:34 PM | #18 |
My 65 with LS1/t-56 from 04 GTO....
11-20-2022, 10:52 PM | #19 |
Ls3 - 4L80e with np205.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
01-26-2024, 12:51 PM | #20 |
2006 LH6 out of an Envoy Denali. I bought the motor before I knew much about these, turns out they're a b*st*rd child lol. I just knew it was aluminum and that's what I wanted for my handling goals later on
- Gen4 aluminum block with knock sensors on the sides - Gen4 rods - 24X Gen3 timing system - Uses an E40 computer (only these, 04/05 GTOs and SSRs used that comp) - 799 heads (same as 243s) - TBSS style intake - 30lb injectors Originally (3yrs ago) it was thrown in with the 4L65E that came with it and a BTR Stage 4 V2 truck cam (.553/.553 224/230 109lsa) and LS6 springs. Then last fall I pulled it out for a reseal (rear main) and to swap to a T56. So since I didn't have to worry about converter walk anymore, I stepped up to the TSP Bald Eagle N/A cam (.600/.600 227/234 111lsa), double valve springs, a CHE trunnion kit and 50lb/hr injectors.
1985 GMC Sierra Classic Chopped down wrongbed Cammed LH6 5.3/T56/3.90 Walker Tuned 5/8 drop US Mags |
01-27-2024, 11:20 AM | #21 |
'67 C10 SWB step side resto-mod
2002 TransAm LS1 with built 4L60E Close to being completed!
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
01-28-2024, 10:28 PM | #22 |
It's cool to see this thread resurface. I have one to contribute. I LS swapped this 72 GMC within the last year and have been driving it for a few months now. It's a 2004 LM7 with a 2002 NV3500 transmission. I did not rebuild the bottom end or heads but I did update, replace, and clean pretty much all the auxiliary items. I used many "LS swap" parts as well as some custom made bits and pieces to make everything work. I have extensive details on everything in my build thread.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
01-29-2024, 11:03 AM | #23 |
Man that looks good! Makes me wish I'd painted the whole motor orange instead of just the block. Pretty sure I saw you roll into Fall Revival, that thing looks great!
02-02-2024, 06:01 PM | #24 |
Hewittca, that is a very nice driver there and I love those hubcaps!
My 1971 GMC build |
07-16-2010, 07:54 PM | #25 |
Nice work guys they really look sweet
Heres a few of mine |
