Old 05-21-2014, 05:08 PM   #626
Mattman2010
Mattman2010's Avatar
Re: 85 GMC Sierra Classic 1 Ton Crew Cab
Well this build is not dead. Just very slow. Finished up school and got a new job so things may end up picking back up on the truck. Mr. Ryanroo was kind enough to send me a new water inlet for my truck seeing as the stock industrial one would not work. Got it all hooked up and looks like everything will work out fine. Just need to get some more bolts to hold the fan hub in place and then measure for a new belt. Also have to weld a bung into the side of the new water inlet so I can hook the heater up as well.
A couple months ago I was trying to decide of I wanted to run a factory big block radiator or try to fit a 2nd gen radiator in the truck. The big block radiator I had needed to be replaced and so I just decided to go with a new 2nd gen radiator and not have any kind of problems hooking it up. So far it is half mounted. Going to have to get the body and hood on so I can tell how much I can come up with the radiator. It is setting to low so I have not finished mounting it yet. And I guess I never showed any pictures of putting a dodge fan hub on this industrial engine. Didn't want to have to run electric fans, and the industrial fan is way to big to run on this truck.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 05-21-2014, 08:26 PM   #627
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work. About time you get to work, let a lone knock some dust off the truck..............
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-21-2014, 09:10 PM   #628
ryanroo
ryanroo's Avatar
Excellent. i like the idea of matching the Rad to the engine. not that you would have ever had issues, but at least now its something to forget about. glad the inlet worked! if you feel like it you can weld that relief cut in and sand it down where that tab is bent. i dont think it would matter, but you will be at it again with the welder so...
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-21-2014, 11:29 PM   #629
Mattman2010
Yeah yeah I know lol
I thought about welding that relief together. But I figured it would be fine that way. I'm going to have to weld on it again anyway. Just have to buy a bung so I can hook up the heater.
Build Thread
Build Thread
Thread
Old 05-28-2014, 09:31 PM   #630
gmcrew
gmcrew's Avatar
Hey I am planning to convert my 1991 from 2 wheel to 4x4, did you have to change all the rear spring hangers or did they work for you.
gmcrew is offline   Reply With Quote
Old 05-31-2014, 01:21 PM   #631
Mattman2010
You have to change the rear spring hangers if you want to use factory springs. Otherwise you can get some lift springs. I mounted mine lower than what they where factory to get more lift and also did a shackle flip.
Build Thread
Build Thread
Thread
Old 06-06-2014, 03:55 AM   #632
gmcrew
gmcrew's Avatar
I have the option of using spring hangers from my suburban or my K20. Which would be preferable? Did you use 3/8 by 1" NC grade 8 bolts for your swap?
Old 06-06-2014, 07:01 AM   #633
Mattman2010
I'm guessing that you are talking about a crew cab truck. All crew cabs have different spring spacing on the rear axle than any k10, k20, k5 and burbs do. So if you use k20 spring hangers you can swap the rear axle out of the k20 into the crew cab or you can cut the spring perches off the crew cab axle and move them the appropriate amount and be able to bolt it up. I used 1.5" 3/8 grade 8 bolts.
Build Thread
Build Thread
Thread
Old 06-06-2014, 06:34 PM   #634
gmcrew
gmcrew's Avatar
Thanks for the info. Your build is looking great!
Old 06-06-2014, 06:59 PM   #635
Mattman2010
Thanks man, any other questions just let me know.
Build Thread
Build Thread
Thread
