Old 12-16-2019, 04:40 PM   #651
Brad54
Brad54's Avatar
Re: The 1960 - 1966 Chevrolet & GMC Pickups Factory Correct Restoration Thread
Originally Posted by oem4me View Post
The factory primer/sealer on the cowl extensions and vent grill were red oxide, the bumper and front grill were black.
Thanks!
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 12-16-2019, 08:51 PM   #652
Blue666(2)
Looks great. I'm 20 miles away if anyone needs a drive by.
https://bham.craigslist.org/pts/d/bi...039762791.html
Blue666(2) is offline   Reply With Quote
Old 12-17-2019, 12:15 AM   #653
forestb
forestb's Avatar
This is a scam. It has been Thoroughly discussed in the the Craigslist finds thread. It keeps on getting flagged.
forestb is offline   Reply With Quote
Old 12-17-2019, 12:54 AM   #654
likaroc13
Rollin' Old Skool
Also not a factory correct restoration.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 01-17-2020, 11:36 PM   #655
63gm
Hay guys I’m in Canada and just wondering where the best place to order an engine overhaul kit for a 3.8L 230 might be looking for a suggestion please
63gm is offline   Reply With Quote
Old 01-18-2020, 03:58 AM   #656
66C10LB
Hey 63gm. One option would be rockauto.com
66C10LB is offline   Reply With Quote
Old 01-18-2020, 01:39 PM   #657
The Rocknrod
Moderator
The Rocknrod's Avatar
What year? - Egge Machine has a rebuild kit - https://egge.com/product/kits.php?ac...engine=230+CID
Old 01-22-2020, 10:17 AM   #658
LT1 Burb
LT1 Burb's Avatar
Just a few details, pretty close to factory correct.
LT1 Burb is offline   Reply With Quote
Old 01-22-2020, 06:00 PM   #659
66C10LB
LT1 Burb. For the body colour painted underside of your cab, did you use regular clear coat or some other protective clear?
Old 01-22-2020, 07:40 PM   #660
LT1 Burb
LT1 Burb's Avatar
Epoxy sealer, raptor liner, base, and then regular clear.
Old 01-29-2020, 12:24 PM   #661
Liz
Catchy title goes here..
Liz's Avatar
This thread has been added to the 60-66 FAQ post and unstuck. The FAQ index is there so that you can find these type of threads at anytime. Please use the report a post feature if you have a FAQ worthy thread you would like added.
Liz is offline   Reply With Quote
Old 01-05-2021, 05:59 PM   #662
jbgroby
jbgroby's Avatar
OK, for those of you that have an Oil Bath Air Cleaner, (of a fake one like I do) we found a source for the CORRECT oem decal. folks though it was something from AC Delco, but with some research, we found that the decal comes from the "United Air Cleaner Division".
You can get a re-pop from:
Studebaker International in Indiana at 317-462-3124.
Part number 3-014 total $6.00
United Oil Bath Air Cleaners was the company that provided the unit to GM Truck Division. They also provided them for many cars and trucks.
jbgroby is offline   Reply With Quote
Old 01-05-2021, 06:15 PM   #663
Submariner616
Active Member
Thanks for this!! You noted you have a "fake" one. What does that mean? I ask because I recently finished my '60 and had the Oil Bath Air Cleaner powder coated to make it look great, but I don't dare run the engine with it in place because of all the loose stuff inside of it. Ideas? Suggestions?
Submariner616
1965 Chevrolet K20 350 4 speed manual
Submariner616 is offline   Reply With Quote
Old 01-05-2021, 08:59 PM   #664
FetchMeAPepsi
FetchMeAPepsi's Avatar
Is this for a chevy or your GMC?
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
Old 01-05-2021, 09:41 PM   #665
Ronster66
Anyone know of a source for the three clips at the top of the firewall that hold windshield washer hose and A/C wire? Mine were lost at the body shop and boneyards in NE Indiana are no longer an option. At the very least can someone post a few close-up pictures of a clip with measurements? I may be able to bend my own.
'66 Custom Cab BBW SWB Fleetside 327/TH350 Factory A/C
‘96 Dodge Ram 2500 Laramie SLT Club Cab 4X4 8’ bed V10/47RE
Ronster66 is offline   Reply With Quote
Old 01-06-2021, 10:34 AM   #666
jbgroby
jbgroby's Avatar
Hi Sub, I should have been more clear. I decided NOT to actually use OIL inside of the old bath air cleaner, so I gutted it and am using a dry paper element inside and in place of the steel mesh.
Old 01-06-2021, 10:37 AM   #667
jbgroby
jbgroby's Avatar
I have a GMC, but from everything we can find, the decal is for both units. up to a certain period. a club member had an unused assembly and it has the decal in near perfect condition.
Old 01-06-2021, 10:45 AM   #668
The Rocknrod
Moderator
https://www.inlinetube.com/products/inl10368
https://www.corvettecentral.com/c2-6...le-hood-652012
Old 01-06-2021, 10:53 AM   #669
jbgroby
jbgroby's Avatar
https://www.grainger.com/product/4RJ...P7A1P:20501231
Old 01-07-2021, 08:10 AM   #670
Ronster66
HUGE thanks guys!
Old 01-07-2021, 12:34 PM   #671
60-66
60-66's Avatar
Its GMC .. ONLY ! Only GMCs used the United Oil Bath brand air cleaners. Chevrolets all used AC brand air cleaners. Still unable to confirm this is the exact decal for 1960 1961 GMC , but its definitely 1962-1966 GMC.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 07-19-2021, 11:55 PM   #672
Blk63vette
Ttt
Blk63vette is offline   Reply With Quote
Old 07-27-2021, 05:10 PM   #673
Lugnutz65
Lugnutz65's Avatar
This 1966 truck has just under 19K original miles. I spoke to the 70-something year old owner. EVERYTHING is original EXCEPT the exterior paint and hub caps, (and maybe not tires). It's a shame it was repainted with so few miles.
Of primary interest is the engine bay and original gray 283 paint color.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 07-27-2021, 05:11 PM   #674
Lugnutz65
Lugnutz65's Avatar
One more of the bed. I wonder if it was repainted.
