Old 01-21-2016, 10:17 PM   #676
61K10
61K10's Avatar
Re: 61K10 build
I agree Joe--will post up some pics when i ever get this new brake system up and running.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-04-2016, 09:10 PM   #677
aotte1
Re: 61K10 build
Kimble,
Still working on my front springs, got the two front bushing ordered, and four for the rear. Looks like the rear did not get greased enough. The threads are gone on part of one bushing. On the other one still have not got the pin out of the bushing. However, did get the bushing out of the spring eye.
Last photo shows it being soaked to try and get it loose. The rear shackle holding it is being replaced. Really like the Kroil for getting parts free. This part has been soaked for weeks now off and on, now that it is out and verticle can keep it saturated. Tomorrow plan to put air pressure on the grease fitting hole to see if can force Kroil in more.
Les
aotte1 is offline   Reply With Quote
Old 02-05-2016, 02:52 PM   #678
61K10
61K10's Avatar
Re: 61K10 build
Les--are they the same as the front spring rear bushings pins? I have some pins from my front that aren't bad. yours if you want them.
1961 chevy K10
Old 02-05-2016, 03:11 PM   #679
aotte1
Re: 61K10 build
Kimble,
Yes, this is picture of front spring rear bushing with pin frozen in it . Would likely be interested in your front spring rear pin, if it is the same. The place Ron suggested in an earlier post here, showed a break for 60 to 63, And 64 to 66 for the front rear shackles. Them not showing pictures, do not know what the differences are. Did post photos of '64 rear shackles minus the bushing to my build yesterday.
Ordered front bushing, they are one piece for each eye of front spring. Out of stock on these, back ordered, however, should have in about two weeks. Tried to order the rear shackle kit for '64 front springs and they are out. Not sure when or if they will have them back in stock. They are trying to get four rear bushings with the treads inside.
Will likely have some rear spring shackle parts extra you are welcome too also, will keep you informed.
Les
Old 02-05-2016, 04:12 PM   #680
61K10
61K10's Avatar
Re: 61K10 build
A little up-date. my wheels go around again. ft hubs lock in and out ok. having a little problem getting my clutch adjusted with Capt's clutch set-up. bought some 1 1/2" wheel spacers for the rear to move the wheels out to match the front track. Don't know if i will run them, but it looks much better with the wheel/tires in alignment. will post up some pics when i get it out of the garage when i get my clutch working.
1961 chevy K10
Old 02-06-2016, 08:35 PM   #681
aotte1
Re: 61K10 build
Kimble,
Sounds all good. Just a heads up, you probably know, for wheel spacers, it is good to only use billet alu. ones, as they are much more stable and more likely not to cause the wheels to come loose. Also if using spacers I check the lug nut torque a lot, when first installing them.
Les
Old 02-06-2016, 09:04 PM   #682
61K10
61K10's Avatar
Re: 61K10 build
not going to use them--tires out farther look good but with 6" rims the backing plate shows to much. they are billet.
1961 chevy K10
Old 02-08-2016, 11:03 PM   #683
sokoloka
Re: 61K10 build
My apologies if this has already been covered - what color was the truck before you repainted it? Was it also neptune green, just faded?
Truck looks FANTASTIC. Love it.
sokoloka is offline   Reply With Quote
Old 02-09-2016, 02:12 PM   #684
61K10
61K10's Avatar
Re: 61K10 build
sokoloka--thanks for the thumbs-up. the org color is Neptune green as it is now. the green on the tk was rattle-can green by the po. under the green was a red bottom and white top as it was a fire/rescue tk at one time.
1961 chevy K10
Old 02-09-2016, 04:30 PM   #685
60sIron
60sIron's Avatar
Re: 61K10 build
Originally Posted by 61K10 View Post
I think i finally got all my parts for my ft axle project. correct bushing for the ft hubs (don't have to cut the outer axle down) started on my new brake lines for the new master cyl. I still need a 1 1/2" hole saw for Captain's mounting plate hole in the fire wall. this is the only mod that will need a plug is ever wanting to put everything back to stock.
pics--old needle bearing in hub and new bushing in hub
brake line on driver's side (you can see my frame is not blasted perfect) I did the best i could with my little blasted.
I need my skinny tires!
Hey Kimble I love following this tread! I look forward to starting on my K10. First I want to do a few thinks to my K20 Burb to make it a little more friendly to drive daily.
First is disc brakes. What bushing did you use? I'd rather not turn down my axles.
Second, why did the track change on the truck? I was under the impression that by converting the closed knuckle 44 the width stayed the same. This is why I've never considered an open knuckle 44 as they are wider.
Keep up the strong work, you motivate more people than you know!
Greg
60sIron is offline   Reply With Quote
Old 02-09-2016, 05:11 PM   #686
61K10
61K10's Avatar
Re: 61K10 build
Hi Greg-- the disc brake change only changes the ft track about 1/4" wider becouse of the caliper holders. the 1/2 ton the rear is narrower than the front from the factory. never really measured it, but is narrower with an HO rear.
the bushings i bought off e-bay--oilite bronze flange bushing 1 1/8id x1 5/8od x 1" and they fit perfect in the spindle. find an open knuckle dana axle for all the parts as it will be cheaper. even if just for the spindles and hubs. I didn't like the way the brakes were, even with everything new. hope the disc setup will satisfy me safety wise, and it can all go back to org if someone wants.
sneak pic of my skinny's and tool box. at 72" it's still a little short. good enough for a few tools and jack. Still need to build a headache rack.
kimble
1961 chevy K10
Old 02-22-2016, 01:33 PM   #687
61K10
61K10's Avatar
Re: 61K10 build
well i have my new brakes/clutch all installed---brakes work great but the power booster makes noise when putting on the brakes, like a vac leak? It's new. the clutch is another problem. I have Captian's firewall plate and clutch set-up. not enough adj to get the clutch so it doesn't engage right off the floor? seams the rod on the wilwood master moves some before it does anything---someday it will be done lol!
1961 chevy K10
Old 02-22-2016, 01:45 PM   #688
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
Nice job Kimble! truck looks good.
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 02-22-2016, 07:04 PM   #689
mattbert56
mattbert56's Avatar
Re: 61K10 build
Some day it will be done you say now we all know that's not true. Trucks lookin good man. Love the skinnys
Well that didn't go as planned.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
mattbert56 is offline   Reply With Quote
Old 02-22-2016, 08:27 PM   #690
pimpston65
pimpston65's Avatar
Re: 61K10 build
a daily driven show truck at its finest!!!
pimpston65 is offline   Reply With Quote
Old 02-22-2016, 09:16 PM   #691
61K10
61K10's Avatar
Re: 61K10 build
MR P--- it hasn't been a daily yet------everything i buy needs some modifying!! I guess i should just build some stuff myself--too old lol! AND if i get it safe it is by no means a show tk. your stuff is the stuff you don't don't to drive Mr-P. keep up the nos work.
1961 chevy K10
Old 02-22-2016, 10:50 PM   #692
pimpston65
pimpston65's Avatar
Re: 61K10 build
at least yours rolls, mine is a pile of parts!!! I just like the boxes the parts come in...
Old 02-23-2016, 03:44 AM   #693
argonaut
argonaut's Avatar
Re: 61K10 build
Haven't been on the website much lately, life happens, so I just caught up with your progress. Your comment about the hydraulic clutch is interesting to me because, though my pedal setup is different I'm also using a wildwood master of the correct bore diameter, along with a factory slave cylinder (1986 style) and mine engages right off the floor too. It is very irritating to me. But there really is no method of adjusting a hydraulic clutch.... let us know if you come up with something.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 02-23-2016, 01:52 PM   #694
61K10
61K10's Avatar
Re: 61K10 build
Jason--I actually adjusted it some by extending the linkage so the push rod went into the wilwood master(a little) and it helped as it moved the pedal of the floor some. Need to get a longer threaded rod for just a little more adj.
1961 chevy K10
Old 03-21-2016, 02:48 PM   #695
61K10
61K10's Avatar
Re: 61K10 build
still messing with my brake pedal to booster rod as it s a pita to adjust. ordered some parts to make a turn-buckle type rod for easy adjustment. changed the booster to a 9"dual instead of the single, and it make noise also--never ends lol!
1961 chevy K10
Old 03-22-2016, 10:37 PM   #696
aotte1
Re: 61K10 build
Kimble,
Very nice looking, understand how much time it takes to get the parts to work, and it seems to me the older the truck the harder it is sometimes. But we have learned not to rush, getting it right is more important.
And old drag racers parts bin has been my, new friend, on this subject for me. Using an old SFI blow proof bell housing, that SS drag racer gave up on for lighter one. It allows me to attach newer trans and keep mechanical clutch mechanism. Once getting it all welded up and machined will post more on it. Being from old parts bin, it can be affordable.
Trying to remember, is your hydraulic cylinder lever to bell housing fork adjustable? I have set- up out of '65 big truck, same bell housing as early 60s, and thinking the lever/ Rod and fork nut was adjustable??? Also, can you use a throw out bearing that has a different thickness, to help with adjustment too. ( stick drag racer have boxes full of bearings with different thickness for adjustment of clutch clearance.). Flywheel/ clutch shop that services drag racer should have them, here in louisville we use "Kentucky Clutch".
Les
Old 03-23-2016, 12:05 AM   #697
61K10
61K10's Avatar
Re: 61K10 build
Les-- being an old drag racer myself, yes parts and the knowledge of yester year helps a bunch. I have a buddy that still races at the age of 68 with a dragster--572 mopar B-1 on NOS--runs 6.95 at 195. to fast for me--
the adjust on my hyd clutch at the bell/housing is for the throw-out bearing only. it's ok as it's grabs not to far off the floor. can live with it. Building a brake pedal push rod now. will post up when i finish it.
Kimble
1961 chevy K10
Old 03-25-2016, 08:45 PM   #698
mattbert56
mattbert56's Avatar
Re: 61K10 build
lookin pretty sharp kimble! check your pm box!!!!
Old 04-01-2016, 01:03 PM   #699
aotte1
Re: 61K10 build
Kimble,
Starting to prepare the '79 Dana 44 for installation on the frame soon to be back home.
Question, on the front brake hoses you are using, what application are they for? And length? Do you remember what length your original drums were? Starting with '79s to see how they fit; disk calipers connection no problem, length and connection to frame fitting needs to be checked. Looked at the Doorman images of the '64 drum hose and '79 disk brake hose , the non-caliper ends look similar, not sure if threads are the same.
Your new Toyo 215x85x16 tires, what model are they? Are they radial? Have not found them on Toyo's web site.
Thanks,
Les
Old 04-01-2016, 01:18 PM   #700
61K10
61K10's Avatar
Re: 61K10 build
brake hoses are from a 1ton van and are 22"or23" long will look for the part#. thr tires are listed as m55's and are a 10ply radial and aren't cheap. BFG makes a tire that looks close and is I think 6 or 8 ply and way cheaper.
kimble
1961 chevy K10
