09-01-2016, 11:00 AM | #701 |
motor exploder
Re: Jason's 70 Big Block SWB Project
Been a while since I checked in - all the details you've been working on/adding while waiting on the motor look nice! Good to hear you got the motor fired up with no issues. What cam are you running now? I'll keep my fingers crossed for you that the tranny goes in with no problems - you'll be washing vaporized rubber out of your rear wheelwells before long!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
09-01-2016, 08:45 PM | #702 | |
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
09-15-2016, 12:13 PM | #703 |
Things are about to happen around here!!!
09-15-2016, 12:24 PM | #704 |
That's a fine looking bullet and will look even better in between the frame rails! Almost time for those break-in butterflies.
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
09-15-2016, 02:08 PM | #705 |
I hope to have it settin between the frame rails by tomorrow. I have a little plumbing to finish up this evening on the new Wilwood master cylinder while I have room without the engine in. You're right about the butterflies, I sure hope everything is right this time
09-15-2016, 11:11 PM | #706 |
Ohh, the engine looks so nice, can't wait to hear it, must be excited.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
09-15-2016, 11:22 PM | #707 | |
It's in and bolted up, I'm going to bed now. I'll start hooking the wiring up and double checking everything in the morning.
09-15-2016, 11:25 PM | #708 |
Sleep, I don't think so, will be building it all night.
09-15-2016, 11:29 PM | #709 |
I know what your saying. I thought about pulling an all nighter so I could fire it up in the morning but I talked myself out of it. I'll just dream about it
09-15-2016, 11:39 PM | #710 |
Well one step closer and some time away helps all the other ideas and plans come to light, 427 SS, like the sound of that. Lucky guy.
09-16-2016, 08:19 AM | #711 |
Looks great Jason, you'll be back on the road in no time.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
09-16-2016, 08:31 AM | #712 |
Still Learning
Engine looks great Jason!
09-16-2016, 10:20 AM | #713 |
Looks good in there!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
09-16-2016, 12:03 PM | #714 |
Super nice man! Please put up a video once you've got it running.
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
09-16-2016, 06:37 PM | #715 | |
PITbut
I know this is super old, but who makes those? Cost? Board member?
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
09-17-2016, 06:53 PM | #716 | ||
Thanks Mike
Thanks Quote:
Here's the aluminum fan shroud I made yesterday, this should make it run a little cooler than was before
09-17-2016, 07:09 PM | #717 |
Well now that I have "go" power, I have no"stop" power!!!!!
The only thing I changed on the brake system is the master cylinder and booster. It's a Wilwood m/c and today we bled brakes for 2 hours and I have nothing, pedal still goes to the floor.... Anybody have this issue before???
09-17-2016, 07:53 PM | #718 |
Nice work Jason! Sounds like you need to adjust the brake pedal rod a little that goes to master cylinder. Should be a easy fix.
Scott |
09-17-2016, 07:54 PM | #719 |
^^^ The system is moving fluid but no brakes or no fluid moving through the system?
09-17-2016, 09:16 PM | #720 | |
The system is moving some fluid but it don't seem like very much, we bled for about 2 hours and the pedal never got firm.
09-17-2016, 09:47 PM | #721 |
Had a similar issue make sure bleeder screw on caliper is at top of caliper not bottom. My buddy did this and could never get a good pedal. He swapped calipers side to side and was corrected.
09-17-2016, 09:57 PM | #722 |
The bleeders are on top, I checked that during the "head scratching" today. The thing is it worked fine till I changed the m/c and booster. The calipers and drums on the rear have not been messed with that's what I'm not understanding. Like Scott said above, if the rod is not pushing the piston in far enough that makes sense. It just don't seem like it squirts the fluid as hard as it should.
09-17-2016, 11:09 PM | #723 |
Unbold master from booster and push on pedal see how far pedal moves before it makes contact with master cylinder piston.
09-18-2016, 08:19 AM | #724 |
Thanks, I'm going to check that today. That seems to make sense, the master and booster came disassembled so maybe the rod is not the right length.
09-18-2016, 09:29 AM | #725 |
Did you bleed the M/C first? If air is trapped in the pistons it can act like you describe.
