Old 04-01-2016, 01:39 PM   #701
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 61K10 build
One Sharp looking truck there.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-02-2016, 01:02 PM   #702
61K10
61K10's Avatar
Re: 61K10 build
Thanks TJ--yours will be there soon. As you know they are a never ending project lol!
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-03-2016, 10:46 AM   #703
aotte1
Re: 61K10 build
Kimble,
Thanks for looking up the front brake hose information.
Would you mind sharing your decision to buy the Toyo tires, their benefits as tires for a driver vs other tires.
Les
aotte1 is offline   Reply With Quote
Old 04-03-2016, 01:50 PM   #704
61K10
61K10's Avatar
Re: 61K10 build
Les--I liked the tread design and nothing on the side walls. Kinda old school-stock looking to me. The 10ply is a little much for me but probably won't bother the ride, as the tk rides like a old covered wagon anyway lol. For my 16x6" rims i wanted the 215x85's as they fit the rims perfect. Also my rims are from a trailer parts comp. they are black power coated at $65 a piece and free shipping. They have a DOT stamp on them also. The lug stud holes are for 1/2" studs so for 7/16" you need heavy duty lug nuts (shown earlier in my build). wheels are like smoothies, no side vent slots.
Just some info--------
Kimble
1961 chevy K10
Old 04-24-2016, 01:07 PM   #705
61K10
61K10's Avatar
Re: 61K10 build
Well i bought some new disc brake parts as my e-bay stuff was not up to my standards. a little rusty--seal surface worn and nicks on the spindles. you get the idea, ok parts but not the best. Rockauto had some new big bearing hubs (only six) for $32.95 ea. with lug studs. I couldn't pass them up as thery are tuff to find new. Made in the big C of course. well i then needed new big bearing spindles (g2) and of course new Big China rotors from summit. bearings and caliper holders as mine from e-bay were pretty rusty. I assembled everything and will put them away for now. I just like new stuff. some pics----
1961 chevy K10
Old 04-25-2016, 01:10 AM   #706
argonaut
argonaut's Avatar
Re: 61K10 build
Oooooo pretty!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 05-08-2016, 09:18 PM   #707
aotte1
Re: 61K10 build
Kimble,
Getting the frame together, and starting to check the ride height of the frame.
The way it sits now the ride height measures from the bottom of the front and rear cab mounts ( where the top of the bottom cushion mounts).
Front is 27 3/4" to floor; and
Rear is 32.1" to floor.
How does this compare to yours, not sure how different the '61 to '64 measurements are.
Do you know if the factory frame specifications have numbers for the ride height from the frame. Have seen some copies here, however, could not read the numbers. Going to check out the GM Heretige Center.
Thanks,
Les
Old 05-08-2016, 11:48 PM   #708
aotte1
Re: 61K10 build
Kimble,
Just checked the GM Heritage Center, vehicle kits.
Looked up '64 K10 and found some information.
Will get to check it out tomorrow on the frame, and see where my ride height may be compared to stock. Have some temporary rear springs in now. The rear is higher then the front as it looks now.
Also got my set of Toyo tires too.
Les
Old 05-09-2016, 01:29 PM   #709
61K10
61K10's Avatar
Re: 61K10 build
Les---my rear springs have 2 more leafs that adds about 3/4". Did you go with 235/85? My 215's are a little over 30" tall (funny they are about the same as my 31-10.50-15's) my 215's are on 6" rims and the 31's are on 8" rims. So tire height will change ride to some extent. will measure mine just for info to compare to.
1961 chevy K10
Old 05-09-2016, 08:31 PM   #710
aotte1
Re: 61K10 build
Kimble,
Yes, went with 235x85x16s, They will be good for now, and they are the same size as on '03 GMC, which will need new tires in the future. They are a little wider then the 215's which look more original. The 235 are 32" inches tall.
How level does your set? Not familiar with these 4x4s when they were new. Certain photos of original 4x4 trucks look like the rear is higher, not sure if this is correct.
How is the front axle upgrade coming?
Les
Old 05-10-2016, 01:23 PM   #711
61K10
61K10's Avatar
Re: 61K10 build
Les--I might of measured mine different than you did. from the floor to the top of the frame mount. 22" front and 28" rear. my tk does sit higher in the rear. (remember i have 2 more leafs). the ride height will come down with the tk together with all the weight. we can compare when yours is together. will try and take a side pic today for ya.
my ft axle is all done, just finished with the new p/brake pedal rod set up. going to mess with my clutch adj set-up today. clutch is grabbing right off the floor. (hyd clutch)
kimble
1961 chevy K10
Old 05-10-2016, 01:26 PM   #712
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 61K10 build
Those are some nice disc brakes. Outta stop real nice.
Old 05-10-2016, 02:03 PM   #713
61K10
61K10's Avatar
Re: 61K10 build
I hope so TJ, will find out soon. I like your Demon carb. I ran one on my 56 Nomad for years with no trouble.
1961 chevy K10
Old 05-10-2016, 05:00 PM   #714
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 61K10 build
Thanks, Summit charged me enough for it. lol
Old 05-10-2016, 06:47 PM   #715
aotte1
Re: 61K10 build
Kimble,
Thanks for the measurements. Photos of the '64 cab mounts are below. Photos with IPhone not positioned correctly lol. Interested to see your '61s and if the same?
Les
Old 05-10-2016, 06:52 PM   #716
aotte1
Re: 61K10 build
Rear cab body mount
Old 05-10-2016, 07:51 PM   #717
61K10
61K10's Avatar
Re: 61K10 build
les--my ft mount is different, but the back looks the same.
1961 chevy K10
Old 05-10-2016, 08:22 PM   #718
aotte1
Re: 61K10 build
Your front and rear cab mounts positions, vertical location, relative to your frame look similar, if not the same, as the '64. What do you think?
Thanks for post your photo. Do you think your ride height, front is pretty much stock, with rear up a little? I am getting some origional rear springs from Chris, as mine were mostly rebuilt ones, with lots of different leafs added.
Next will do some more measurements on the '64 frame/ cab on roll around stand to see where the ride height may end up.
Thanks,
Les.
Old 05-11-2016, 12:12 PM   #719
61K10
61K10's Avatar
Re: 61K10 build
Les--Yes, they look like the top of the frame mounts of both yrs are close to the middle of the frame in the front. (where the cushion sits) Back looks the same. I also have the org springs in the ft and the back (plus 2 leafs in the back as i have stated). Isn't there a reg and a heavy duty spring? 5leaf and a 6 leaf?
1961 chevy K10
Old 05-12-2016, 05:04 PM   #720
61K10
61K10's Avatar
Re: 61K10 build
Finally got my clutch adj. where i like it. (as long as it stay's adj.there) PART of the problem was the dumb-A$$ doing the adjustment. Not going to say who lol!
1961 chevy K10
Old 05-12-2016, 06:55 PM   #721
aotte1
Re: 61K10 build
What do you think was the issue, besides the mechanic!
Air in system?
Old 05-12-2016, 10:26 PM   #722
aotte1
Re: 61K10 build
Kimble,
Checked the GM Heritage Center, vehicle kits for '61, '64. and '66, about how many leafs the front and rear springs have, if my review is complete.
Front- all years have 5 leafs.
Rear- '61 K10 has 6 leafs: K20 has 8 leafs; '64 and '66 have 6 leafs for both
K10 and K20, with multiple different spring ratings.
I would say this is close but not absolute, would need to review the vehicle kits in more detail. Their are a lot of different models and options. They due list standard and HD spring ratings for the rear, all 6 leafs,'64 and '66. Also optional rear HD shocks too, did not see any optional front HD shock. Different models had different shocks.
Would say this is general information, with different models and options things may be different.
Old 05-13-2016, 01:30 PM   #723
61K10
61K10's Avatar
Re: 61K10 build
Les --no air in the system. read the book wrong awhile ago. never looked at it this time around) my return spring on the clutch t/o bearing arm was pretty week. added a 2nd spring) the manual says 5/32" clearance between the arm and the slave push rod with the t/o bearing just touching the p/plate fingers) i had way more. I adj. like the manual said and it works great, and what a difference between my old brake set-up and the power-disc set-up.
1961 chevy K10
Old 05-14-2016, 03:16 PM   #724
61K10
61K10's Avatar
Re: 61K10 build
Finally got the tk back on the road. The new disc brakes are night and day from the power/drums set-up i had. It was worth the $$$ and time spent adding them to the closed knuckle axle. Now about the steering with the 4deg shims added to the ft axle. It has much more feel and not wanting to wander as it did before. Another plus! Need to drive it some more of course. also need to run it in 4h to get the ft ring & pinion broke in some. I actually used it as a tk, went to ACE and got some dirt/potting soil for my garden. It still makes a nice gear wine going down the road under power and deceleration, but free wheeling it's quiet. old sm420 and a 221 i guess!
A pic for you TJ---a working tk lol.
1961 chevy K10
Old 05-14-2016, 03:19 PM   #725
argonaut
argonaut's Avatar
Re: 61K10 build
Awesome Kimble! I'm glad your hard work paid off. And that your putting it to work like you should be!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
