Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-18-2011, 09:57 PM   #51
Sir Fisher
Sir Fisher's Avatar
Re: Project: 1970 4x4 underway...
i picked up my new springs today!! woohoo, going to start installing axles and drive train; wish me luck!!
1970 Chevy K20 Custom Camper
1996 Chevy Impala SS
2008 Chevy Avalanche LT3
2003 Honda Accord EX
2001 Hewes Redfisher 16 Fighting Lady Yellow
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118
Sir Fisher is offline   Reply With Quote
Old 01-18-2011, 10:11 PM   #52
Sir Fisher
Sir Fisher's Avatar
Originally Posted by Chevymaniac View Post
I really dig that color of green you chose. I'am still not sure if i should piant mine green when the mods are all finished. My truck is the same factory color of green as yours was.
What did you use for painting the frame and what prep work did you do?
prep work?? just sand blasted and regular black paint... nothing special for the frame.
Old 01-19-2011, 11:28 PM   #53
Sir Fisher
Sir Fisher's Avatar
just ordered these motor mounts for my truck from Trans Dapt Performance Products; i went with these because i wanted to do without the crossmember, gives me better access to drop the pan if i needed to.
Old 02-12-2011, 12:39 AM   #54
Sir Fisher
Sir Fisher's Avatar
got the leaf spring situation under control and mounted them with the axles this week... got the motor mounted also, but need to shim it up about 3/4" it's sitting a little too low right now.
Old 02-12-2011, 12:47 AM   #55
Sir Fisher
Sir Fisher's Avatar
here are some more pics...
Old 02-12-2011, 12:57 AM   #56
Sir Fisher
Sir Fisher's Avatar
come to find out the steering arm is too short, need to find a way to make it longer, it's extended all the way out already... ohhhh, thinking makes my brain hurt!!!
the 15" rim i borrowed from my tire lady doesn't fit... i'm going to run down to the shop this weekend to see if she'll lend me some 16+ ones, so i can roll my truck around for the time being.
Old 03-03-2011, 07:16 PM   #57
sandking
.....I am working on it.....
sandking's Avatar
Nice build!!
Do you have a part number on these mounts you got from Trans Dapt?
Also, can you take pics of how they mount? Thanks
View my build thread HERE
sandking is offline   Reply With Quote
Old 03-04-2011, 05:22 AM   #58
barthmonster
subscribed. Fantastic color, very unique !
barthmonster is offline   Reply With Quote
Old 03-05-2011, 11:53 PM   #59
Sir Fisher
Sir Fisher's Avatar
Originally Posted by sandking View Post
Nice build!!
part number 4506; only have side pics right now, i'll take some better pics later this week for you.
Old 03-06-2011, 02:57 AM   #60
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Looks great! Out of curiosity, why did you get replace the full-floating rear axle and convert it from 8 to 6 lug? Most people are doing the exact opposite when upgrading their trucks.
DirtyLarry is offline   Reply With Quote
Old 03-06-2011, 03:55 AM   #61
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
i wanted to go with the open knuckles, the closed knuckles had horrible turning radius... i also had a good deal on my 6 lug axles, and the rims that i want were also 6 lug rims. i know it's heavier duty, but i'm not doing anything that'll require the heavy duty needs.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 03-07-2011, 11:51 AM   #62
sandking
sandking's Avatar
Are they a weld in, rigid mount? Thanks in advance for the pics.
Old 03-07-2011, 11:58 AM   #63
sandking
sandking's Avatar
Nevermind, I went on the website and looked at the pics. It looks like a bushing of some sort for flex. Thanks for the info.
Old 09-07-2011, 09:49 PM   #64
Sir Fisher
Sir Fisher's Avatar
wow, the last time i worked on my truck was march... i almost forgot that i was working on a project... just ordered some parts from lmc, so when those come in, maybe that'll motivate me to get off my butt and back onto the project at hand.
Old 09-07-2011, 11:29 PM   #65
Altec
Getcha Pull
Altec's Avatar
Get your steering arm issue worked out? Looks like the newer axle needs a longer coupler? Here is the one on my '73-'87.
http://i13.photobucket.com/albums/a2...t/IMAG0221.jpg
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 01-05-2012, 12:49 PM   #66
jpstaub
Are you concerned at all about generating structural problems in the frame by removing the cross member? If you hard mounted the engine you could consider it a structural member. But since you're soft mounting, I would think the biscuit mounts and studs are going to take a beating. To me it seems like the end result would be more frame flex than stock. Hopefully not enough to effect road manners but you never know.
In any event, I've taken on a '72 K10 conversion job (I'm finding out 4wd is more troublesome than 2wd) and am interested to see how your swap goes. After researching the issue at length, it looks like the LSX/4l60E/NP241 combination is the way to go in order to avoid a lot of adapter cost and complexity to get an LSX/4L60E to work with an NP203 or NP205.
Has anyone tackled NP241 shifting for manual versions? Going with an electronic NP241 would be slick but getting the whole works to operate correctly scares me a bit.
jpstaub is offline   Reply With Quote
Old 01-05-2012, 04:59 PM   #67
CTENTA1
Registered 1971 K5
Very nice bodywork/paint. That green is awesome.
CTENTA1 is offline   Reply With Quote
Old 05-21-2013, 06:27 AM   #68
ThreeQtr
Any updates?
ThreeQtr is offline   Reply With Quote
Old 11-04-2013, 07:57 PM   #69
Sir Fisher
Sir Fisher's Avatar
I am back; couldn't work on the truck in awhile, but I think I can manage to find some free time now. Started today installing the gas shocks but ram into a little problem; the upper mount is too wide and I don't know what to fill in the gap with. The lower mounts are fine.
Old 11-04-2013, 10:33 PM   #70
mjensen
mjensen's Avatar
Mine came with spacers.
Not a direct picture, but you should see the spacers I'm talking about.
Great looking truck by the way!!!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 11-04-2013, 11:59 PM   #71
swamp rat
swamp rat's Avatar
You could maybe stack some washers in there?
But actually looking at the picture i would almost be led to believe that the outer tang might have been bent outward? I would think the angle on the frame where the grade 8 washer is should match the angle on the tab, but look it over closely before any attempt to bent it, make sure the holes will still allow the bolt to pass thru if you do try to straighten it.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-05-2013, 12:02 AM   #72
swamp rat
swamp rat's Avatar
Looking back, to the best of my knowledge on the rims a minimum of 16" is required.. its why a lot of trucks had the 16.5 rims.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-05-2013, 11:49 PM   #73
Sir Fisher
Sir Fisher's Avatar
Thanks mjensen; I found the spacer and mounted it with no problems. But now i have a question on the rear mounting shocks; if I take off the strap that holds the shock it expands all the way out; but if I don't undo the strap it won't reach for me to secure it to the bottom bracket.
Old 11-05-2013, 11:54 PM   #74
mjensen
mjensen's Avatar
Glad it worked out. Yup...crack the strap and bolt it on
I found mine was easier to put it on the bottom bolt and push it down to the top bolt.
Mike
Old 11-06-2013, 09:18 PM   #75
Sir Fisher
Sir Fisher's Avatar
So everyone made fun of me for having my tow hooks on backwards but come to find out they won't go on the other way... so I guess I have to drill new holes or do without tow hooks...
