Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-08-2010, 09:25 AM   #51
rebel714x4
rebel714x4's Avatar
Re: Power Brake Booster Adapter Bracket
i got 2 questions has any body used a 88-98 set up yet. and how did that work out, and how do i order one
loaded like a freight train!! flyin like a jet plain!!! 1964 chevy 327 4 speed (sold) wtb 60-61 chevy (for me) 1972 gmc 250 straight six 82000 miles my new dd
rebel714x4 is offline   Reply With Quote
Old 04-09-2010, 12:10 AM   #52
Captainfab
60-66 Nut
I'll send you a PM regarding ordering.
Old 04-10-2010, 01:00 AM   #53
bubba327
HOW long until spring??
bubba327's Avatar
Bump ..... Thank you John, for a nice product
Here is a shot of a 75 impala booster and master mounted on Captainfab's mount bracket.. Worked out slick!
I used a S-10 bracket from mid 80s as it sat the combination valve squarely and directly under the master.The ears of the bracket were extended 1" to give more bending room for the lines between the master and the combination valve.
Size:  47.0 KB (that is the choke cable laying up across the booster)oops-- the bracket had not been painted yet either ...
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 04-10-2010, 02:05 AM   #54
Captainfab
60-66 Nut
That looks sweet, nice job Bruce. Thanks for the installed pic.
Old 05-27-2010, 09:37 PM   #55
luckylindy6
Hey Captain what powerbooster/master cynl would I need for my 66 1/2 ton c10, is your bracket set up so that with a certain combo the push rod and everything will line up right w/out fab'in the push rod or drilling holes?
luckylindy6 is offline   Reply With Quote
Old 05-27-2010, 11:34 PM   #56
Captainfab
60-66 Nut
The vacuum boosters that will work with my booster brackets are listed in post #1. As for what master cylinder, that depends on what brake setup you are running. Do you have drums/drums, disc/drums or disc/disc's. My brackets are a direct bolt on to the firewall, no holes to drill. You will however need to lengthen the booster pushrod to reach the brake pedal arm.
Old 08-24-2010, 06:34 PM   #57
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Thanks Captin,
i got the adapter yesterday!
very pleased with it... my only down fall i bought the wrong brake booster.
i will be hitting you up later for that powersteering plate
Sick5 is offline   Reply With Quote
Old 08-24-2010, 10:47 PM   #58
Captainfab
60-66 Nut
Thanks for the compliment
Just let me know when you're ready for power steering.
Originally Posted by Sick5 View Post
Thanks Captin,
Old 09-14-2010, 09:15 AM   #59
edszuk
Hey CaptinFab,
I just gathered all the brakes off of an 80 2 wheel drive suburban do you know if your bracket would fit this power booster? thanks.
edszuk is offline   Reply With Quote
Old 09-14-2010, 11:35 PM   #60
Captainfab
60-66 Nut
No the '73-'87 pickup,Suburban and Blazer boosters will not work with my bracket. It is not needed with those boosters as they have brackets riveted to the booster. To use that booster you will have to drill some holes in your firewall.
My booster brackets work with the boosters listed at the beginning of this thread, and bolt to your firewall using existing holes. This is also a cleaner looking installation IMO.
Originally Posted by edszuk View Post
Hey CaptinFab,
Old 12-31-2010, 12:48 AM   #61
towersddg9
towersddg9's Avatar
Hey Captfab need to get one of your booster adapters for my 65 in powdercoat
could you tag me back with info on payment
towersddg9 is offline   Reply With Quote
Old 01-01-2011, 12:32 AM   #62
Captainfab
60-66 Nut
PM sent......
Old 01-07-2011, 09:31 PM   #63
towersddg9
towersddg9's Avatar
Originally Posted by Captainfab View Post
PM sent......
John, booster bracket on the porch when I got home, looks great and shipped fast, that is a great design and I had to have it
Old 01-07-2011, 11:42 PM   #64
Captainfab
60-66 Nut
Thanks for the compliment, I'm glad you're happy with it. Post up some pics when you get it installed.
Old 08-29-2011, 06:45 PM   #65
Slowtruk
Slowtruk's Avatar
"Boosters with this pattern are commonly found on S10's and full size pickups, Suburbans, Blazers and Tahoes from 1988 to at least 1998."
I see this statement and have some Q's.
1. So I take it I need a booster from these years? Also, a master cylinder from any of these years and applications?
2. The only other thing needed for this installation (besides your bracket) is to couple the rods together?
3. Dumb question but where does the vaccum hose coming from the booster attach to on the engine?
Then I'd just have to run my brake lines and then Ill have power brakes?
I'm sending you a PM about your power steering bracket we talked about in the other thread yesterday.
Slowtruk is offline   Reply With Quote
Old 08-29-2011, 06:50 PM   #66
Slowtruk
Slowtruk's Avatar
pretty pathetic as it is now...
Old 08-29-2011, 11:56 PM   #67
Captainfab
60-66 Nut
You do not have to use the master that came on the booster you are going to use. Most GM dual reservior master cylinders will bolt up. I would recommend using one that is close in application to what you are using the rest of the braking system from
That and a proportioning valve, and run your brake lines.
You will need to connect it to manifiold vacuum on your engine. Where that may be depends on what engine you are running
You will have to bleed the brake system, then yes you should have power brakes.
I returned your PM
Old 09-01-2011, 12:05 PM   #68
HEI451
Captain,
Would you please be so kind as to contact me off the board, at my shop e/mail, please. I have parts/pricing questions about your booster/master adapters.
info@davessmallbodyheis.com
Thank you, sir.
HEI451 is offline   Reply With Quote
Old 09-01-2011, 11:13 PM   #69
Captainfab
60-66 Nut
Dave.
I will send you an email a little later.
John
Originally Posted by HEI451 View Post
Captain,
Thank you, sir.
Old 09-08-2011, 11:25 PM   #70
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
My buddy gave me a booster/master off the shelf from an old order that was never picked up....
Just noticed it a three bolt mounting.
Not even sure what it was designed for, gonna run the number.
Looks like I'm going to have to fab something else ...
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-08-2011, 11:43 PM   #71
Captainfab
60-66 Nut
That's wierd. I've not seen one with 3 mounting studs on it. Looks like it has a universal pushrod on it....just threaded with a jamb nut.
Old 09-09-2011, 12:05 AM   #72
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I know, right ?
The price was right, so I'm gonna make it work ...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-11-2011, 10:32 PM   #73
Caudillo64
Caudillo64's Avatar
How Can I buy a adapter Bracket? I live in California.
Caudillo64 is offline   Reply With Quote
Old 09-11-2011, 11:09 PM   #74
Captainfab
60-66 Nut
I'll send you a PM with payment details.
Old 09-12-2011, 07:27 AM   #75
Caudillo64
Caudillo64's Avatar
Payment Sent Thanks.
