Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-13-2011, 06:39 PM   #51
lycominghunter
Re: 68 GMC 4x4 chassis being built to be a 70 4x4!
Awesome build man!
lycominghunter is offline   Reply With Quote
Old 02-20-2011, 09:22 AM   #52
Patsfan34
Patsfan34's Avatar
First round of parts and panels blasted, cleaned and ready for primer.
Patsfan34 is offline   Reply With Quote
Old 02-20-2011, 09:30 AM   #53
msgross
msgross's Avatar
Interesting that you had him blast parts before they were installed... Make sure to prime those hidden areas or they will rust very quickly... I had my cab blasted, them installed the new cab corners, floor and such... Someday i'll epoxy prime everything together and be ready for the body shop
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-20-2011, 11:35 AM   #54
Patsfan34
Patsfan34's Avatar
Mike it's definitely a "process". He wanted to get all the pickling solution off the rockers and cab corners and floor first so that's why he blasted them so the epoxy primer will stick better. Now he'll weld everything up, blast some areas again including all the welding seams and then shoot another round of primer.
Old 02-20-2011, 11:02 PM   #55
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Man that fresh metal looks so nice! Do you mind me asking what having all of it blasted cost?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-21-2011, 08:56 AM   #56
Patsfan34
Patsfan34's Avatar
It's tough to say exact cost on just the blasting cause he's doing all the metal fabricating and welding and then priming everything. Just to give you an idea on just the cab he's charging me $1200, which includes blasting the cab, cut out the old floor, rockers and cab corners. Then weld everything back in, fill the 4 trim hole and then prime everything. After much research I thought I was a fantastic deal for me.
Old 02-21-2011, 09:29 AM   #57
msgross
msgross's Avatar
Just the blasting alone would probably average $500-$600+ depending on the place. As long as he does good work that will require little to no bondo then $1200 seems fair. Is he going to fit the doors as well? make sure because if the floor is wrong you'll never get them on right...
The Garage:
Old 02-21-2011, 10:52 AM   #58
Patsfan34
Patsfan34's Avatar
Yup he's fitting the doors. He's actually in the process of bracing the cab today.
Old 02-21-2011, 01:01 PM   #59
swamp rat
swamp rat's Avatar
Dang $1200 is cheap for all that work..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-21-2011, 10:45 PM   #60
Mikey72
I have a 72 4x4 that was converted into a short bed but when they cut the frame they cut it in front of the rear cab mounts. So when i pulled the bed apart to replace the floor i noticed that on the drivers side the cab mount has been welded to the frame and it sits about 1/2 inch higher than the passenger which is only held on by two bolts that they drilled in. I'm wondering if you know the measurements for how high up the rear cab mount sits from the bottom of the frame to the bottom of the mount. Ive been looking around but havent founf anything yet. If you could help me out with this it would be awesome. Thanks again.
Mikey
Big_Mac
( )(_.)(._)( )
( ) \___/ ( )
Mikey72 is offline   Reply With Quote
Old 02-21-2011, 10:56 PM   #61
Patsfan34
Patsfan34's Avatar
I thought so as well.
Old 02-21-2011, 10:57 PM   #62
Patsfan34
Patsfan34's Avatar
Mikey
Mikey I'll be doing some odds and ends to the frame on Wednesday, I will take measurements for you and PM you.
Neil
Old 02-21-2011, 11:08 PM   #63
Mikey72
Neil, i really appreciate it. It seems like everytime i start a new project on this truck i run into smaller things that slows the process on the initial project. I guess thats way it normally goes though. Thanks again.
Big_Mac
( )(_.)(._)( )
( ) \___/ ( )
Old 02-21-2011, 11:25 PM   #64
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
That sounds pretty good, I know some people would charge that just for blasting.
Tony
Old 02-23-2011, 12:01 PM   #65
Patsfan34
Patsfan34's Avatar
Mikey, it's 1 inch from the top of the frame rail to the top of the drivers rear cab mount, or 4 3/4 inches from the bottom of the frame rail to the bottom of the mount. Good luck!
Old 03-21-2011, 11:02 AM   #66
Patsfan34
Patsfan34's Avatar
Cab almost finished. Coming out fantastic. Floor and cab corners welded in. Just need to finish the rockers and do a little more metal fab and it's almost done. I'm so happy with how it's coming out!
Old 04-03-2011, 01:02 PM   #67
Patsfan34
Patsfan34's Avatar
Rockers in and tunnel cut out with nuts welded under floor for easy mounting.
Old 04-05-2011, 02:12 AM   #68
vk_chevy
vk_chevy's Avatar
looks like you're making good progress,
just want make a quick comment, in the picture, it looks like the floor panel is only spot welded across the front, if that's the case, you need to finish welding it all the way across.
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 04-05-2011, 08:23 AM   #69
Patsfan34
Patsfan34's Avatar
vk chevy you are correct. There's still plenty of finish welding to do. Thanks for looking.
Old 12-24-2011, 12:46 AM   #70
Chevymaniac
Any more updates? It's been awhile since last post. You must have something to report.
Chevymaniac is offline   Reply With Quote
Old 12-24-2011, 05:37 PM   #71
msgross
msgross's Avatar
so the new floor was cut just below the factory spot weld area? Interesting approach, I used the factory spot weld area to reattach mine... nice progress...
The Garage:
Old 09-15-2014, 01:17 PM   #72
Patsfan34
Patsfan34's Avatar
For sale in the parts forum
