Old 06-10-2011, 01:22 AM   #51
bluex
bluex's Avatar
Re: TR65 LS2 T56 Engine Swap 65 C10
Well if you decide to go shoot me a PM and I'll make sure I'm there. I'll be in the junky looking truck in my avatar...
bluex is offline   Reply With Quote
Old 06-10-2011, 08:21 AM   #52
Scot_Douglas
Scot_Douglas's Avatar
My goodness - I just saw this thread. You do outstanding work. Love it!
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 07-09-2011, 02:20 PM   #53
glos55
glos55's Avatar
You certainly have talent!! Your workmanship is outstanding!!!
glos55 is offline   Reply With Quote
Old 07-09-2011, 04:41 PM   #54
bluex
bluex's Avatar
He's also a super nice guy and that truck is even better looking in person than in the pictures. Its very clean and neat for a daily driven classic!!
Old 07-30-2011, 01:09 AM   #55
enick72
enick72's Avatar
nice
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline   Reply With Quote
Old 07-30-2011, 11:06 AM   #56
Dinos63
chevy only
Dinos63's Avatar
nice work!! wow
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 07-30-2011, 12:04 PM   #57
towersddg9
towersddg9's Avatar
Very Cool, question, where did you get the duel elec fan asmbly, and what size apx are the fans Thanks
towersddg9 is offline   Reply With Quote
Old 07-30-2011, 05:28 PM   #58
TR65
TR65's Avatar
Thanks for the kind words guys! The truck is a real pleasure to drive with the LS2 and 6 speed.
BlueX - Good to hear from you, hope all is well, and thanks.
Towers, Here is the fan setup I run. I fabbed a frame out of aluminum angle and mounted it with the existing holes for the old fan shroud. It is nice having 2 fans since the ECM decides if it needs one or two. Never calls for 2 unless sometimes when the AC is running. The fans pull 12 amps each.
Would be a lot cheaper to salvage electric fans from the junk yard though.
http://www.a1electric.com/Merchant2/..._Code=30102052
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 07-30-2011, 06:49 PM   #59
towersddg9
towersddg9's Avatar
TR
Thanks good info
Old 07-28-2012, 01:12 PM   #60
laynrockers
laynrockers's Avatar
Thank you for taking the time to write up your LS swap like you did. I just got my LY5 and 4l60E yesterday so i am going back through all the threads and you deserve more props then your getting. Great job and thanks for the attention to detail
laynrockers is offline   Reply With Quote
Old 07-29-2012, 01:13 PM   #61
TR65
TR65's Avatar
Thanks Kris.
Good luck on your project. I feel good every time the LS motor cranks up.
TR
1965 C10 SWB Fleet
Two owner
Old 08-13-2012, 11:58 PM   #62
1enick72
1enick72's Avatar
Great thread, truck and very nice work. Thanks for the details and pictures. I am in process of doing a LT1/T5 swap and have been working on a crossmember brake bracket combo like what you have made. I will now combine what I have worked out and some ideas from yours and hopefully make something work well. Where did you get your tank from? I currently have a TPI engine with a return running the stock sending unit and tank. The fumes are killing me so I need to do something.
65 short step
edited by staff
1enick72 is offline   Reply With Quote
Old 08-14-2012, 08:46 PM   #63
TR65
TR65's Avatar
Thanks!
I can say that after a couple of years of use the e-brake setup has worked perfectly.
My tank is from Rick's Hot Rod Shop. Very expensive. It is a very nice piece. 4" below the frame at the back, 5-1/2" below the frame at the front. Can't see it. Fully baffled for the EFI pump which was included.
Good luck with your build!
TR
1965 C10 SWB Fleet
Two owner
Old 12-16-2012, 09:03 PM   #64
pine trees
good job. you are a fabricating wizard
pine trees is offline   Reply With Quote
Old 01-22-2013, 05:54 PM   #65
ljackson
ljackson's Avatar
Very clean install, Thanks for the thread.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 01-22-2013, 07:18 PM   #66
Arekusu
Arekusu's Avatar
Hello, I've had this thread bookmarked for a while. Love the truck / swap.
I am wondering though, your goal was 20+ MPG on the way to work (which I assume is highway) did it meet the goal? What did the truck end up getting? It's all steel and 60's aerodynamics.. but the 6-speed should have helped a little.
I swapped an 87 Rx7 to an LS1 , T-56 and get 27 ish MPG highway at 80 mph on flat land.. so I'm asking cause I wouldn't mind finding an ok truck and doing an LQ4 swap on it.
Great fab and great threat!
Alex
Arekusu is offline   Reply With Quote
Old 01-23-2013, 12:30 AM   #67
TR65
TR65's Avatar
Thanks for the kind words men.
Alex,
I have posted the mpg story on some of the mpg threads. After careful measurements, Odometer calibrated with GPS, same gas station parked the same way at the same pump etc. I can't get but an average of 17.5 mpg. I have a C6 Vette with exactly the same final drive ratio, both run 70 mph at 1800 RPM. Basically the same engine. On the same circuit same speeds back and forth to work the Vette gets a true 21 mpg. That huge difference I believe is due to aerodynamics. Our trucks are rolling billboards.
So I was disappointed but the truck is a great ride and I drive it every day in good weather, the Vette is the bad weather car.
TR
1965 C10 SWB Fleet
Two owner
Old 01-23-2013, 03:28 AM   #68
Arekusu
Arekusu's Avatar
I smiled when you said the Vette is the bad weather car. Thanks for the info! Ya I had a feeling the aero. was going to inhibit it a bit. Thanks again!
Old 01-23-2014, 11:40 PM   #69
Andy4639
Old member
Andy4639's Avatar
Cool Re: TR65 LS2 T56 Engine Swap 65 C10
[COLOR="Purple"]
That's funny right there.
This is some right up! Man you should be very proud! I can't wait to see this truck in person! My hat is off to you sir. Great job on a great truck and write up about it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 05-30-2014, 04:57 PM   #70
greg65
greg65's Avatar
subscribed
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 07-17-2014, 10:48 AM   #71
boynton
boynton's Avatar
Great write up one of the best I've read.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 08-29-2014, 11:37 AM   #72
BlueRidgeMountainDew
BlueRidgeMountainDew's Avatar
Awesome work, clean and nice, really like the truck and your craftsmanship. Well Done
BlueRidgeMountainDew is offline   Reply With Quote
Old 08-29-2014, 10:20 PM   #73
TR65
TR65's Avatar
Thanks for the kind words Blue,
I grew up in Stanley, NC. Not so far from you.
TR
1965 C10 SWB Fleet
Two owner
Old 03-23-2016, 04:16 AM   #74
roOstersan
roOstersan's Avatar
Another great thread. The attention to detail you have is what I envision for my own project, the skill, however, is lacking! But I won't give up! That's for the great info and detailed explanation. It is much appreciated.
roOstersan is offline   Reply With Quote
Old 04-01-2016, 04:11 AM   #75
Paul Y
As others have said, great thread! The detail is helping me with my LS swap.
A question if you don't mind, on drivability.
I would love a "close ratio" T56 but looks like I am going to have to settle for a wide. Therefore, how do you find the gearbox in the truck? Can it pull 5th and 6th comfortably or does it feel uncomfortable? What rear end ratio are you running and height of tyres?
My LS is just a 5.3 so will be slightly differant in hp to your LS2 but would be good to hear your experiences.
Many thanks.
P.
Paul Y is offline   Reply With Quote
