Old 06-09-2011, 05:11 AM   #51
rcbildr
rcbildr's Avatar
Re: Project "Doom-Buggy" Early '60's Buggy...
Are you going to reinforce the outer edge of the pan at all? A friend of mine is restoring his Manx style dune buggy he and his dad built when he was in high school and he recommended I do that with my pan. Several years ago he gave me a shortened type 4 pan...it had a body but my friend wanted it because is was the same type his buggy was. IIRC he recommended using something like 1" square tubing for the perimeter.
Also, are you going to keep it a swing arm rear suspension or convert it to IRS?
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 06-09-2011, 10:42 AM   #52
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I'll look into the reinforcement, but I really do not think it's neccesary.
Yeap, I'm keep the OG swing axle...my favorite, love the camber !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-06-2011, 09:02 PM   #53
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Updates?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-11-2011, 10:05 AM   #54
scotts62
One day...
scotts62's Avatar
Scott
93 crew cab build
Project 62
Old 09-11-2011, 10:24 AM   #55
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Ya tons !!
Well, not really ... totally lagging on this one.
The other day I grinded and sanded the tunnel welds, and made some templates out of cardboard for the floor.
My plasma is at the shop, so one day I'll cut out the diamond plate and weld it in...some day.
Currently I'm trying to score a CLEAN A$$ '62 SWB .... Shhh, dont tell the wifee
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-11-2011, 11:31 AM   #56
rcrahn
rcrahn's Avatar
Currently I'm trying to score a CLEAN '62 SWB .... Shhh, dont tell the wifee
Say what? give us the details?
rcrahn is offline   Reply With Quote
Old 09-11-2011, 12:33 PM   #57
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I didnt hear a thing, nope nothing!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-15-2011, 08:43 AM   #58
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Not much of an update ... walking by I grabbed the grinder, then sander and cleaned it up a bit ..........
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 09-17-2011, 07:10 PM   #59
67chevy1series
67chevy1series's Avatar
coming along nicely keep it up.
67chevy1series is offline   Reply With Quote
Old 05-27-2012, 01:05 PM   #60
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Well after 8 months .... I decided to get back on it .... Pics to follow ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-27-2012, 01:50 PM   #61
scotts62
One day...
scotts62's Avatar
Ah dang! Thought we had pics! Teaser!
Scott
93 crew cab build
Project 62
Old 06-10-2012, 01:43 PM   #62
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
YES ..... I AM BACK !!!
Finally, FINALLY got the floors welded in ... Again I used 1/8" diamond plate I had laying around at my shop. I actually gained about 2" of clearance in the rear floor board area by removing the OG pan. (rear seat foot area that hangs lower)
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 06-10-2012, 02:26 PM   #63
scotts62
One day...
scotts62's Avatar
Heck yeah looks good dude!!
Scott
93 crew cab build
Project 62
Old 06-10-2012, 02:56 PM   #64
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
While my buddy diassembles, cleans, reseals and details the otherwise temporary 1500cc....I'm back on pan...
Before tossing the OG pan, I drilled out the spot welds and removed the stock seat tracks...to locate on new floors...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 06-10-2012, 03:00 PM   #65
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 06-10-2012, 06:18 PM   #66
RockTonka
RockTonka's Avatar
Nice job on the floors, looks much better
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 06-14-2012, 10:53 AM   #67
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thanks ... I agree too !
Killed 3 birds too ... Nicer looking, more clearance, and used up that 4'x8' that was in my shop that was a PITA to keep moving !!
Actually, It was just layed it flat and driven over ...
Next up, is front bulkhead modification to allow earlier front beam to bolt up ...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 06-20-2012, 09:52 AM   #68
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
After having my wife help me lift the pan onto some saw horses, I started the mock-up of the early beam to the '68 pan. As you can see, the difference in tube spread from early to late....Also another shot of floor and seat tracks....
This extra bracing will also be smoothed out once tubes are closer together...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 02-04-2013, 02:41 PM   #69
inovermyhead
I know you've been busy w/those other projects but how is this one coming?
I've been going through your builds here lately, great work man!
81 GMC C15 RC SWB 5.3L 4L80E project
inovermyhead is offline   Reply With Quote
Old 02-07-2013, 09:52 PM   #70
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thanks man !!
Yes, I do have quite a few projects going.
Currently, pluggin away at my shop ... Working on everyone else's projects.
The pan of the buggy just needs a few work welds on the rear plate, and the tubes tack in place....
The nose still need to be modified as well.
These past weekend we have been cleaning my yard at home, to make room for my partners "complete" project, so I can move the Burban and Buggy to the shop ....
Stay tuned !
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-05-2013, 02:43 PM   #71
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Well I am back on it again ... I've been saving some money in order to finish her up.
I decided to jump back to by welding in some adjusters into the beam, before attacking the front bulkhead.
What a Nasty job of cleaning out the old grease !!!
I should of degreased before cuts ... But in a way, it help me out...
Used some 2x4 rect tubing to "jig" up the beam:
Tack weld some tabs in the middle:
2" marked out:
Beam after 2" removed. What you see in the tubes is YEARS of "grease jobs".....With a distinct smell only a VW entusiast can recognise....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-05-2013, 02:53 PM   #72
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I tacked a nut into the end of some tubing, and used a seal driver end to drive out the bushings, and grease ....
Venti size cup of grease....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-08-2013, 08:18 AM   #73
Low Elco
Glad for the update! I wanna see this, I know less than nothing about the VW's, but I think they're cool. Keep it up!
Low Elco is offline   Reply With Quote
Old 05-08-2013, 12:24 PM   #74
ERASER5
ERASER5's Avatar
I thought of this thread last Thursday. I stopped for lunch in Georgetown KY at a Chik-fil-A. As Iwalked by the drive thru, there was a '70s something dune buggy in line. It had an old "Sand Digger" decal on the front. The owner said it was an all original '70s buggy, even the the Torkthrust wheels.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 05-10-2013, 08:45 PM   #75
dug224
dug224's Avatar
Great project!...great to see the kids involved. Was a VW fan back in the 70's and owned a few. Moving to the beach soon. Next project will have to be one of these. dug
dug224 is offline   Reply With Quote
