Old 06-11-2013, 06:50 PM   #51
obijuan
Re: NP 205 Rebuild and Info
The 205 is one of the easiest things ive ever done on an r&r. I have done, nearing 15 of em id say, for people afraid of em. Its just parts. Same thing with a th400. Take it apart. See whats inside. Youd be amazed at the simplicity.
obijuan is offline   Reply With Quote
Old 06-11-2013, 06:57 PM   #52
jbclassix
Junk Yartist
jbclassix's Avatar
Originally Posted by jaros44sr View Post
Is there any info. on the seals and how they are installed for the adapter that bolts to the trans? Seems this is where mine is leaking
Help?
Thanks for taking the time jbclassix
On this one that I built there is an o-ring on the input shaft of the t-case that seals to the inside of the adapter sleeve, and there is a plain encased seal in the adapter housing that seals to the outside of the adapter sleeve. I am going to finish rebuilding the t-case soon.
Originally Posted by jjzepplin View Post
There are also two regular type seals that are in the adapter for the coupler outer seals. The inner is the o ring. This keeps fluid from your trans from going into your t-case.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 06-11-2013, 11:41 PM   #53
jaros44sr
jaros44sr's Avatar
Sounds good guys, thanks for the help
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-26-2013, 12:57 AM   #54
jbclassix
Junk Yartist
jbclassix's Avatar
Wow. 2 years later...
Tips for the Yokes. I sleeved both. I use green lock-tite on them to prevent seepage between the parts. i apply RTV sealant to the inside of the yokes, and not the shaft. This way you will not be pushing RTV into the case.
10 spline front yoke repair sleeve part number (federal mogul 99174)
32 spline rear yoke repair sleeve part number (federal mogul 99212)
Spline washer seal. important piece. Only works on the 32 spline yokes in my opinion.
Torque for the rear yoke is 150lbft.
repeat steps for the front yoke. The front has a dust shield.
I will show pictures of the early style adapter for reference.
-Jeremy
Rebuilding an NP205
Old 07-04-2013, 07:32 PM   #55
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Do you happen to have any pics of the adapter seals? Mine is the o ring style on the trans to adaptor and idea on the case to adaptor seal? My trans was leaking atf into the t case so here I am..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-04-2013, 08:27 PM   #56
jjzepplin
jjzepplin's Avatar
Auto Zone had mine in stock. They look just like wheel seals and the coupler just sits centered on them. They seal the outer part of the coupler while the inner is sealed by the "o" ring. Case to adapter gasket can be bought on ebay for a couple bucks.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-04-2013, 09:12 PM   #57
obijuan
Old 07-04-2013, 09:13 PM   #58
obijuan
Those are the three seals you will need. Small oring is for the inside of the coupler. Big oring is for the trans to adapter. Regular lipped seal is outside of coupler.
Old 07-04-2013, 10:29 PM   #59
FRENCHBLUE72
PROJECT 7DEUCE
I found all the seals with the exception of the small o Ring seal to the shaft
MEMBER #6377
Project "7DEUCE"
Old 07-04-2013, 10:56 PM   #60
obijuan
Comes in my gm 205 gasket kits.
Old 07-06-2013, 01:07 AM   #61
jbclassix
Junk Yartist
jbclassix's Avatar
I have 2 lip seals in my adapter. The larger one obijuan doesnt have pictured i cannot find a PN for. For autos i recommend putting some silicone on the inside of the coupler like i did the yokes.
-Jeremy
Rebuilding an NP205
Old 07-09-2013, 07:28 PM   #62
jbclassix
Junk Yartist
jbclassix's Avatar
Here is what I have for seals.
there are 2 lip seals inside the 1st gen adapter.
here are the 2 lip seals.
transmission side
transfer side
here you can see where the 2 lip seals ride on the coupler
here you can see the sealing surface the o-ring on the t-case input shaft seals against. Make sure this side of the coupler is on the t-case side. Also, clean the splines on the coupler, and put some silicone on it. This will act as a back-up to the o-ring.
-Jeremy
Rebuilding an NP205
Old 07-16-2013, 06:35 PM   #63
jaros44sr
jaros44sr's Avatar
Thanks for the added information, should come in handy....
SAFETY FIRST
AS usual, off topic
Jim
Old 07-20-2013, 11:43 PM   #64
jbclassix
Junk Yartist
jbclassix's Avatar
Bad image of 32 spline front output shaft
-Jeremy
Rebuilding an NP205
Old 07-21-2013, 04:31 PM   #65
79Betty
79Betty's Avatar
Jbclassix. One helluva write up. When i tore mine apart it didn't have the spacer on the rear output. Now that i out it together the input from the tranny shaft slides back and forth. I've got it all torqued down but don't wantto put it in because when slid out it grinds horribly. When in farther it spins smooth as silk. Any ideas?
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 07-21-2013, 04:54 PM   #66
jbclassix
Junk Yartist
jbclassix's Avatar
are you talking about the input shaft in the t-case or the coupler? If it is the input shaft for the t-case, the outer snap ring on the input bearing prevents the input from going back into the case, and the transmission-to-transfer-case adapter prevents the input from sliding forward, out of the case.
-Jeremy
Rebuilding an NP205
Old 07-21-2013, 04:59 PM   #67
79Betty
79Betty's Avatar
Yes the input from tranny. So the "slop" iis supposed to be there?
Old 07-21-2013, 09:13 PM   #68
jbclassix
Junk Yartist
jbclassix's Avatar
Yes. It is. On the spacer on the rear output, was your shoulder longer? Your speedo gear will be loose if it is supposed to have a spacer and doesn't.
-Jeremy
Rebuilding an NP205
Old 07-21-2013, 09:19 PM   #69
79Betty
79Betty's Avatar
I noteced it would move back on the sleeve. Could i just use a thick washer as a spacer?
Old 07-21-2013, 10:01 PM   #70
jbclassix
Junk Yartist
jbclassix's Avatar
You will actually need that spacer. The yoke, spacer, and gear keep the output shaft riding on the bearings where they are supposed to. but let me triple check that. I have an output assembly I need to rip into anyway.
-Jeremy
Rebuilding an NP205
Old 07-30-2013, 12:19 AM   #71
jbclassix
Junk Yartist
jbclassix's Avatar
Newer case with a staked idler shaft on the rear side to prevent rotation.
-Jeremy
Rebuilding an NP205
Old 08-21-2013, 01:54 AM   #72
'63GENIII
'63GENIII's Avatar
Killer write up Jeremy! Thanks for the read. After reading this thread, I was able to completely disassemble, clean and reseal the divorced dodge 205 that is replacing the old T221 in my '63. It came out great.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-21-2013, 11:20 AM   #73
61K10
61K10's Avatar
63GENIII--does the dodge use the same mounting as the 221?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-22-2013, 03:03 AM   #74
'63GENIII
'63GENIII's Avatar
Sent a PM. Didn't want to hijack but yes it fits
Chris
'63 k15 long step
Old 09-05-2013, 08:33 AM   #75
gmjim4x4
Do you have a part number for the larger seal needed for the front output after you put the speedy sleeve on ? I have the 30 spline output shaft and yoke, but I am guessing that the outside diameter is the same as your 10 spline ? How long should I let the silicone sit on the inside of the yoke before I put it on the shaft? Nice write up and very helpful. Thanks
gmjim4x4 is offline   Reply With Quote
