Old 11-10-2011, 08:48 AM   #51
rs72z
rs72z's Avatar
Re: crew cab short bed build " clifford"
These pics are not very good but here ya go. I will plate the inside after i final weld. I need to bring the bed home before i cut the rear. I guesse the 1 ton rear frames are diffrent than a 1/2 ton? If i cut 6 inches off the rear my bumper will have to have holes cut through the rear hangers? Someone know if this is right?
rs72z is offline   Reply With Quote
Old 11-10-2011, 08:51 AM   #52
rs72z
rs72z's Avatar
rear of frame
Old 11-12-2011, 02:23 PM   #53
scottco
scottco's Avatar
Are you going to box or fish plate the frame??
scottco is offline   Reply With Quote
Old 11-12-2011, 04:11 PM   #54
rs72z
rs72z's Avatar
Fish plate. May do the inside and outside. I will be pulling some with it. I don't know if it will be necessary to do both. What do y'all think?
Old 11-12-2011, 08:10 PM   #55
scottco
scottco's Avatar
Part of me would like to weld it up and dress it out so its not visible but I know it needs more strength. I will box mine and clean it up nice. It could also have a fish plate behind it. I just want a clean look. I know frames flex some, Just don't want cracks.....
Old 11-12-2011, 08:25 PM   #56
scottco
scottco's Avatar
These are some plates I have made for boxing in the frame.....
Old 11-13-2011, 09:00 AM   #57
mrhino
Following along!
mrhino is offline   Reply With Quote
Old 11-13-2011, 10:56 AM   #58
rs72z
rs72z's Avatar
So you are going to box just the area where the frame was shortened at?
Old 11-13-2011, 11:09 AM   #59
scottco
scottco's Avatar
Yes.. and a few inches on each side... Open to all suggestions....lol
Old 11-15-2011, 04:01 PM   #60
rs72z
rs72z's Avatar
Bed ready for first prime. Just need to get right fender in and fitted.
Old 11-15-2011, 05:27 PM   #61
Mattman2010
Mattman2010's Avatar
Cant wait to see how this turns out, I have a cclb dually that I am wanting to cut down to a swb. Not sure if I would want to make it a dually or just go single wheel.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 11-15-2011, 05:31 PM   #62
Igorsgonemadd
What are your plans for the suspension. Lowering it, or stock ride height?
Igorsgonemadd is offline   Reply With Quote
Old 11-15-2011, 05:55 PM   #63
rs72z
rs72z's Avatar
Getting pretty anxious myself. I'm taking vacation the week after Thanksgiving, with nothing planned but working on the truck.
Keep it a dually, the ones i have seen are sweet!!
Old 11-15-2011, 05:59 PM   #64
rs72z
rs72z's Avatar
I plan on lowering it. Looking at hangers and shackles for the rear and 3" spindles for the front. I want it to be low enough to look good but not so low that it's not functional. Bags are not in the budget, i don't think that i have mentioned that this is a budget build.
Old 11-15-2011, 06:53 PM   #65
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
From what I've researched, you don't need to cut as much off the rears as the half tons because the 1 ton frames were shorter from the factory back there. I wondered the ame thing on mine. Also, did you just measure 1/2" back from the front bed mounting hole, make a mark, and then remove 14" from there back?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-15-2011, 06:58 PM   #66
rs72z
rs72z's Avatar
I measured back 7 inches from from the rear cab mount, that put me about a inch behind the front bed bolt hole.
Old 11-15-2011, 08:03 PM   #67
Dieselwrencher
Did you just go 7" back from the rear edge of the cab mount, or 7" from center? (I'm reading it like 7" from the rear edge of the cab mount but just want to be sure) Thanks for the help. I'm going to try to cut mine down soon.
Ryan
Old 11-15-2011, 08:06 PM   #68
rs72z
rs72z's Avatar
Yes rear edge.
Old 11-15-2011, 08:31 PM   #69
Dieselwrencher
Thanks!
Ryan
Old 11-16-2011, 09:01 AM   #70
rs72z
rs72z's Avatar
No problem.
Plans are to take the truck to work this weekend to shoot the firewall so i can get started getting the engine and trans in.
I will set the bed on while it's there so i can figure out how much needs to come off of the rear of the frame. I will post up after i figure it out.
Old 11-16-2011, 11:02 AM   #71
Igorsgonemadd
Don't forget the pictures!! This is exactly what I plan on doing to mine. Shortbed, 5.3, 4l60, and a 6/8 drop. So I'm watching this build close......
Old 11-16-2011, 12:04 PM   #72
rs72z
rs72z's Avatar
Will do. Are you doing a dually or single wheel?
Old 11-16-2011, 12:22 PM   #73
Igorsgonemadd
Definately keeping it dually. I havent decided on wheels yet. Probly just stock 16's. Semis are not really in the budget. Plus I don't know if I wanna mess with the adapters and all the added weight.
Old 11-16-2011, 12:28 PM   #74
rs72z
rs72z's Avatar
Got any pics of it?
Old 11-16-2011, 12:36 PM   #75
Mattman2010
Sounds like you should be able to get a lot of work done on it then. I have thought about keeping it a dually, but mine is 4x4 and lifted duallys just don't look as good as a srw. Plus I have seen one or two lifted short bed dually 4x4s and they look unproportional.
Build Thread
Build Thread
Thread
